    Clothworks no arrows to move pins on axis
    13 Posts 7 Posters 1.1k Views 7 Watching
      ratcliffe1009 Newcomers
      Hello,
      I've just started using clothworks- the paid version. I've been following you tube tutorials on how to drape over objects, I can pin things but can move the pins. there are no coloured arrows appearing on the axis to move them like in the you tube video and manual.
      I'm a beginner!
      Can anyone help?
      my screenshot
      screenshot of you tube tutorial
        You move them when the simulation is running.
          I still don't get any axis arrows when the simulation is running
            What version of Mac OS? What graphics card?
              If you hover the cloth you can drag it.
              Hover the model space and click drag to box select the pins.
                Studio Ilona Laurijsse
                Hi there,
                I have the exact same problem:
                • I have a licensed plug-in
                • The license is activated
                • All pins are selected
                • The simulation is running[/list]
                Still no axis arrow are showing.
                I work on an iMacPro 2017
                MacOS Ventura 13.2.1
                and also on a MacBookPro 2018
                MacOS Ventura 13.3.1
                Same issue.
                Mac automatically updates the latest drivers of NVIDIA, so this shouldn't be the problem.
                But what then?
                I hope anyone can help.
                  @studio ilona laurijsse said:
                  Hi there,
                  What happens if you right click on the pin?
                    Send a mail to clothworks@sketchucation.com and Anton will see it.
                      kikidancer
                      Hi there, hello from Paris !
                      I have exactly the same problem on Mac OS Monterey,
                      Apple M1- 32 go ram
                      I can't drag the pin's
                      I have try all the key of my keyboard..
                      no result
                        Hi there, hello from Broadford !
                        Just send an email to clothworks@sketchucation.com with your issue. I can't test as I don't have a m1 mac.
                          Anton_S
                          Apple M1- 32 go ram
                          no result
                          The arrows are only available if you activate your license file.
                          To purchase and activate a lisense, see here: https://antonsynytsia.github.io/manuals/ClothWorks/license_manual_v174.pdf
                          Thanks,
                          Anton
                          • F Offline
                            Flakie12
                            I am having the same issue.
                            IMACPro on Sonma 14.1.2
                            I also have a PC copy and have the same issue.
                            I am tying to create a tent structure ceiling and need to pull up pins up to create the peaks in the tent.
                              Have you purchased a license for Clothworks and have you activated it? As was mentioned in the post immediately before yours, you must have a Clothworks license for this feature to be available.
