    How to change shortcuts?
    11 Posts 5 Posters 495 Views 5 Watching
      koliboti
      Hi, My Shift key on my laptop has broken 😒 and I want to change the PAN shortcut. The actual Shift + middle mouse button (the wheel button) shortcut to a new shortcut: Ctrl + mouse wheel button. But in the Windows -> Preferences -> Shortcuts I can not change... If I export the shortcuts to Preferences.dat file, there is no Pan command line in the file.... How can I change the shortcut??? Thank You.
      Preferences.dat file:
      [Accelerator]
      Count=37
      0 0 0 Z selectZoomTool:
      0 0 1 Z viewZoomExtents:
      0 0 0 A selectArcTool:
      0 0 0 E selectEraseTool:
      0 0 0 B selectPaintTool:
      0 0 0 P selectPushPullTool:
      0 0 0 R selectRectangleTool:
      0 0 0 Space selectSelectionTool:
      0 0 0 L selectLineTool:
      0 0 0 K View/Edge Style/Back Edges
      0 0 0 M selectMoveTool:
      0 0 0 T selectMeasureTool:
      0 0 0 F selectOffsetTool:
      0 0 0 Q selectRotateTool:
      0 0 0 S selectScaleTool:
      0 0 0 W File/Export/2D Graphic...
      0 0 0 U selectDimensionTool:
      0 0 0 D Edit/Unhide/All
      0 0 0 C Tools/Solid Tools/Trim
      0 0 0 H editHide:
      0 0 0 G Edit/Make Group
      0 0 0 I Edit/Item/Explode
      0 0 0 NumPad+ Camera/Parallel Projection
      1 0 0 Right Edit/Item/Text Position/Outside End
      1 0 0 Left Edit/Item/Text Position/Outside Start
      1 0 0 G Extensions/Chris Fullmer Tools/Loose to Groups
      0 0 0 J Extensions/Hide All Unselected
      0 0 0 V Edit/Item/Slice Model at Section
      0 0 0 N Edit/Item/FixIt 101
      0 0 0 Y Edit/Item/Reverse
      0 0 0 O Edit/Item/Texture/Position
      1 0 0 L Extensions/Extrude lines, vector by 2 points [TIG'd]
      1 0 0 M Extensions/Mirror Selection
      0 0 0 X View/Elevation 45 Shadows/Left
      1 0 0 R Edit/Delete Sections
      0 0 1 S selectSectionPlaneTool:
      0 0 1 X Edit/Item/Convert to xLine
        samodelkin_77
        100 = ctrl
        001 = shift
        010 = alt
        000 = non prefix
          koliboti
          @samodelkin_77 said:
          100 = ctrl
          001 = shift
          010 = alt
          000 = non prefix
          And the ''middle mouse button (the wheel button click)'' have any code???
            samodelkin_77
            not any buttons of mouse i cant to make shortkey in sketchup..
            maybe some more programmers now how to code this/// sorry
            • TIGT Online
              The H is the default key press for Pan - so I suspect that you have set a shortcut that overwrote it.
              You could redo the shortcut in preferences or assign another using a modifier - it does not need to be 'shift' ??
                Are both Shift keys broken?
                  koliboti
                  Please see the attached file :) It is possible to do this?
                    koliboti
                    Only the left Shift, but I want to use the left Ctrl key.
                    • TIGT Online
                      You'd need to use say Ctrl+H to run Pan the mouse-button presses are not accessible to Shortcuts.
                        koliboti
                        Thank you very much. I am grateful for your help.
                          rv1974
                          Buy a 5+ button mouse and assign shift to one of a side button
