    [Plugin] UCS Manager
    34 Posts 10 Posters 13.3k Views 10 Watching
    • T
      tommy.jhd
      Hi TIG
      UCS manager is now loading without error - when located in standard plugins location, and in alternate locations.
      However the following errors appear on use:
      Error: #<NoMethodError: undefined method list_all_ucs' for DBUR_Ucs:Module> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/DBUR_UcsManager/DBUR_UcsManager.rb:61 Error: #<NameError: uninitialized constant DBUR_Ucs::SaveUCSTool> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/DBUR_UcsManager/DBUR_UcsManager.rb:40 C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/DBUR_UcsManager/DBUR_UcsManager.rb:61:in call'
      Error: #<NameError: uninitialized constant DBUR_Ucs::RestoreUCSTool>
      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/DBUR_UcsManager/DBUR_UcsManager.rb:47
      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/DBUR_UcsManager/DBUR_UcsManager.rb:40:in call' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/DBUR_UcsManager/DBUR_UcsManager.rb:40 Error: #<NoMethodError: undefined method erase_ucs' for DBUR_Ucs:Module>
      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/DBUR_UcsManager/DBUR_UcsManager.rb:54
      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/DBUR_UcsManager/DBUR_UcsManager.rb:47:in `call'
      As requested
      Sketchup.find_support_file('Plugins')
      ..and...
      DBUR_Ucs::TR
      {"Existing UCS: "=>"Existing UCS: ", "Save a User Coordinates System"=>"Save a User Coordinates System", "Origin: "=>"Origin: ", "Select UCS"=>"Select UCS", "List User Coordinates Systems"=>"List User Coordinates Systems", "Save UCS"=>"Save UCS", "Restore a User Coordinates System"=>"Restore a User Coordinates System", "Y Axis: "=>"Y Axis: ", "Delete a User Coordinates System"=>"Delete a User Coordinates System", "Unnamed"=>"Unnamed", "Pick UCS origin"=>"Pick UCS origin", "New UCS name: "=>"New UCS name: ", "Z Axis: "=>"Z Axis: ", "Name: "=>"Name: ", "List UCS"=>"List UCS", "UCS Manager"=>"UCS Manager", "X Axis: "=>"X Axis: ", "Restore UCS"=>"Restore UCS", "Save and restore User Coordinates Systems"=>"Save and restore User Coordinates Systems", "Select existing UCS"=>"Select existing UCS", "UCS main dialog"=>"UCS main dialog", "Delete UCS"=>"Delete UCS", "No UCS in this model."=>"No UCS in this model."}
      Thank you again (sorry for taking a few day to test and get back to you)
      T
        This is weird...
        I'll do some more investigations...
          Here's an update http://sketchucation.com/pluginstore?pln=DBUR_UcsManager_v1_0_0 Some of its encrypted 'class' methods have been adjusted so they might now [hopefully] work better with earlier versions of SketchUp...
          • T
            tommy.jhd
            Exactly the same error messages, I'm afraid.
            Would you like me to PM you them? (rather than saturating the thread with error messages)
              Please copy+paste these three lines [one at a time] into the Ruby Console and report the three results...
              ` load('DBUR_UcsManager.rb')
              load('DBUR_UcsManager/DBUR_UcsManager.rb')
              Sketchup.load('DBUR_UcsManager/dbur_ucs.rbs')`
              Then, in that same session, retry using the tool...
              • T
                tommy.jhd
                true
                C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/DBUR_UcsManager/DBUR_UcsManager.rb:29: warning: already initialized constant TR
                true
                false
                Tool replies same error messages as before
                Original version replies: true, true, false - with no elaboration or warnings
                  I'll PM you a possible solution...
                  • L
                    lord anubis
                    And gents, did you solve it?
                      Djé 0
                      It would be a great improvement if we could choose the orientation of the three axes and not only the origin point, like the native "placer" tool.
                      • Didier BurD
                        Didier Bur
                        Hello,
                        Yes, that's true.
                        I've just updated the plugin some days ago, and I wondered if I had to code what you want, and I did'nt did it.
                        I'll take your wish into account soon.
                        Regards,
                        DB
                        • Didier BurD
                          Didier Bur
                          Hi Djé,
                          Version 1.1.0 of the plugin is now availbale.
                          • the UCS Origin now takes the current UCS for moving it
                          • a new tool lets you define a new UCS (just like the native SU tool)
                          Download it at the Plugin Store (also soon at the EW):
                          https://extensions.sketchup.com/extension/13e533c2-ebf7-4d86-805f-59dd2254564b/axes-manager
                          Regards,
                          DB
                          • 2 / 2
