    Complex rotations with robot arms not working
    13 Posts 3 Posters 497 Views 3 Watching
    • Rich O BrienR Online
      Are you using Kinematic Constraints so the child follows parent?
      • N Offline
        North2001 Newcomers
        I have the model in Groups, so the whole robot is a group and then the components are in subsequent groups inside the main group. I have done it the way I saw a youtuber group robot arms
          Try it with Kinematics. Fredo has a video on his channel that covers it.
          • N Offline
            North2001 Newcomers
            Just tried using Kinetics and I can't get it to work either as kinetics are always on but as I have 6 different movements that all need different constraints it isnt working. I have also tried turning them on and off when I need but that doesn't seem to work either
            • ntxdaveN Offline
              ntxdave
              Have you looked at Animator? It will allow you to animate groups and subgroups at the individually.
              Press F1...thank me later
              • N Offline
                North2001 Newcomers
                Yes that's what I was doing before looking at Kinematics. I have sort of learned that its good until there's too many movements with rotation's which is what I'm finding here and didn't know if anyone had come across the same issue and solved it
                  I'm presumed it was a question about Animator as it is asked in Animator forum.
                  The strategy of grouping everything to inherit the parent group move can result in unwanted results. Kinematic Constraints added to the MASTER then the SLAVES can move as desired.
                  • ntxdaveN Offline
                    ntxdave
                    Interesting. Is there a link to a kinmetric plugin? I did not see on in this forum.
                      Animator has a Kinematic Constraint feature...
                      https://i.imgur.com/2YVGeIQ.png
                      ...with various methods to apply it
                      https://i.imgur.com/b95YE0f.png
                      There is no separate plugin needed
                      • ntxdaveN Offline
                        ntxdave
                        Thanks, Rich. I cannot do anything any more and did not remember that. I need to go educate myself about kinematic (like what the heck it really is/what does it do).
                          Basically its a chain. If A moves tell B and C to follow it but keep their position in relation A the same (unless instructed differently).
                          Same principle when you drink beer.
                          • ntxdaveN Offline
                            ntxdave
                            DUH! πŸ˜„
