    [Plugin] Parametric Modeling - v0.0.7 - 03 June 2021
    86 Posts 31 Posters 116.7k Views 31 Watching
      sketchucationgreg
      Hi Samuel. Thank you for looking at my post.
      @samuel_t said:
      Does this happen when you are typing a formula?
      Yes.
      @samuel_t said:
      The preview in Math nodes such as Divide can be empty. This is a known issue. It's only a display bug.
      Thanks so much for letting me know that Samuel. I wasn't sure what to do next with that one.
      @samuel_t said:
      Can you please send me your .skp or .schema file?
      Schema attached.
      • samuel_tS Offline
        samuel_t
        Hi Greg,
        @sketchucationgreg said:
        The components often disappear in SketchUp upon modifying the schema. Adding and deleting nodes sometimes makes them reappear.
        Yes.
        Looks like a bug... Maybe the Parametric Modeling plugin tries to redraw the parametric entities while the schema is in a inconsistent state (incomplete formula).
        Schema attached.
        I don't see a .schema file attached to your post. You can send me a .skp file or maybe a .schema.zip file.
          sketchucationgreg
          Hi Samuel,
          The permanent disappearance of the model seemed to correct itself after I cleaned up my model and developed my schema further, and opened and closed SketchUp a few times along the way. I started it within a model where I had been playing around with the native DC editor so it could have been a conflict of sorts there.
          I have attached the files which I think were form that version in any case but please don't feel like you need to investigate this one further.
          I really enjoyed using the interface this time. I think I saw a request for incorporating the follow me tool. I think that would be a really powerful enhancement but I realise that might mean adding some line drawing function.
          Thanks once again Samuel. I can't wait to find another excuse to take this for another test run.
          Parametric lantern DC6 Da shape metal.zip
            lelam11234
            Hi Samuel
            I'm using this your plugin. I see it very usefully for my job. And I'm used to work the plugin "VizPro". It has a few of useful features. Such as:
            1. Choose many nodes to move, copy, and container (merge node)
            2. Have a node to access into group (edge, face, point,...)(node Brep in Vizpro)
            3. Have a node to draw point, arc, line, circle, polygon
            4. Have a node to input list style
              This is only my suggest. I'm looking forward to see them in your new version
              Thank you for your job
            • W Offline
              WhiteShadow
              facing hardship with 2 things, it will be awesome if anyone can help
              first problem:
              made a box
              to copy node, 6 copies
              to move node, moved some distance
              now, i have something line this:
              how do i make a solid group of all these copies?
              another problem:
              is there a way to randomly move copied opjects between a set range (distance between 2 boxes can be anything from 3 to 10, random distance between every copy)? if yes, how?
              eg:
              instead of getting
              how can i get
              • Rich O BrienR Online
                The calculate node accepts math formula so something like...
                rand(value,value)
                ...would output a random value. I'm not sure if that random value can be applied to the copies though.
                If you right click the Node Editor and choose Export Scheme you could share it
                • W Offline
                  WhiteShadow
                  Yes, rand (min, max) works for giving random value but the distance between every 2 blocks can't be randomised by it, there must be some other way or something I'm missing completely
                    Have you used the Import Scheme to load some of Sam's sample files to study the workflow?
                    That's what I did to understand the possibilities of Node Editor.
                    • samuel_tS Offline
                      samuel_t
                      @whiteshadow said:
                      first problem:
                      made a box
                      Do you mean put many groups in one group? If yes, there's a "Make group" node for that purpose. Then check Outliner panel...
                      @whiteshadow said:
                      another problem:
                      eg:
                      instead of getting
                      how can i get
                      There's at least a way. Look at this "Random Gap" parametric schema, attached below to this post:
                      https://i.ibb.co/dM5GPLX/Random-Gap.png
                      It's no yet documented but "Move" node accepts formulas to set dynamically X, Y and Z positions.
                      In formula: x + a + rand(b,c)
                      x is X position of Box in loop
                      a is Self Width of every Box
                      b is Min Gap between Boxes
                      c is Max Gap between Boxes
                      Random Gap.schema.zip
                        beuzleclair78
                        Bonjour Samuel,
                        J'ai découvert ce plugin et c'est vraiment performant !! Bravo pour le développement et les mises à jours !
                        Je l'utilise pour un projet personnel.
                        Par contre, je bloque sur l'opération "Soustraire"...
                        Comme l'exemple, je dois percer une plaque mais je dois répéter l'opération ...
                        J'ai essayé plusieurs pistes en regroupant ou en concaténant ...sans succès !
                        Je veux bien une aide pour simplifier le processus car j'ai une pièce a fabriquer avec nombreux trous !
                        Merci,
                        • E Offline
                          efeme75
                          Bonjour Samuel,
                          Congratulations for your excellent plugin!
                          Is there an undocumented feature here or do I miss something?
                          I draw two boxes both with default dimensions, except for the second one with width = 0.5. I connect each output of the DRAW BOX nodes to the inputs of an INTERSECTION node and obtain a 0.5-wide box. I then connect the output of the INTERSECTION node to the input of a MOVE node with 5 in x direction. No problem so far, I get my 0.5-wide box at location (5,0,0).
                          Now I connect the output of the first DRAW BOX node to the input of a MOVE node with -8 in x-direction without changing anything else in the above setup. Why is my 0.5-wide box now at location (-3,0,0)? It seems that the intersection between the two boxes is first computed, moved by -8 and then moved by 5 by the last MOVE node. BTW, it seems that if I connect the output node of the second DRAW BOX node to the input of a MOVE node nothing changes.
                          Thanks for your help!
                          Francois
                          PS: File in attachment
                          Parametric.skp
                            Marion barray
                            Hello,
                            Is it possible to select object already built in the model ?
                            • 2 / 5
