    [Plugin] Parametric Modeling - v0.0.7 - 03 June 2021
    86 Posts 31 Posters 120.9k Views 31 Watching
    • samuel_tS Offline
      samuel_t
      @traupmann said:
      The disabling of the Layer Organizer worked for all of the provided schemas but two. The files are below.
      Decking on Pedastals Results.skp
      Curved Shelf Result.skp
      Sorry for the very late reply.
      "Decking on Pedastals" appears empty.
      "Curved Shelf" appears incomplete.
      For both, I don't know why...
      @traupmann said:
      Here is a schema I developed
      Arch.skp
      Bravo and thank you for this great schema! I'll include it in the next Parametric Modeling plugin version.
      https://i.ibb.co/gTq3rS0/Sketch-Up-Parametric-Arch.gif
      @traupmann said:
      Can you advise how to pass schema files?
      Inside Nodes Editor, right-click in void. Select "Export schema to a file". Share exported .shema file 😄
        sketchucationgreg
        Thank you Samuel for this awesome extension. I spotted this a few years ago and tried a few things out of interest but didn't get far. I returned last week after getting frustrated with the native dynamic component editor. Thanks for your great modifications since it is a very useful tool now. Well done.
        Thanks also to Traupmann for the Arch schema. I changed the numbers a bit but got a Bug Splat after a few minutes.
        I'm building a schema with some similar components and found two strange things
        1. The components often disappear in SketchUp upon modifying the schema. Adding and deleting nodes sometimes makes them reappear.
        2. Some nodes do not appear to be calculating but seem to have correct formula in them (see attachment)
        Blank cells
        • samuel_tS Offline
          samuel_t
          Greg, I'm happy to hear this plugin is useful! 😄
          Does this happen when you are typing a formula?
          1. Some nodes do not appear to be calculating but seem to have correct formula in them (see attachment)
          The preview in Math nodes such as Divide can be empty. This is a known issue. It's only a display bug.
          Can you please send me your .skp or .schema file?
            sketchucationgreg
            Hi Samuel. Thank you for looking at my post.
            Yes.
            Thanks so much for letting me know that Samuel. I wasn't sure what to do next with that one.
            Schema attached.
            • samuel_tS Offline
              samuel_t
              Hi Greg,
              Yes.
              Looks like a bug... Maybe the Parametric Modeling plugin tries to redraw the parametric entities while the schema is in a inconsistent state (incomplete formula).
              Schema attached.
              I don't see a .schema file attached to your post. You can send me a .skp file or maybe a .schema.zip file.
                sketchucationgreg
                Hi Samuel,
                The permanent disappearance of the model seemed to correct itself after I cleaned up my model and developed my schema further, and opened and closed SketchUp a few times along the way. I started it within a model where I had been playing around with the native DC editor so it could have been a conflict of sorts there.
                I have attached the files which I think were form that version in any case but please don't feel like you need to investigate this one further.
                I really enjoyed using the interface this time. I think I saw a request for incorporating the follow me tool. I think that would be a really powerful enhancement but I realise that might mean adding some line drawing function.
                Thanks once again Samuel. I can't wait to find another excuse to take this for another test run.
                Parametric lantern DC6 Da shape metal.zip
                  lelam11234
                  Hi Samuel
                  I'm using this your plugin. I see it very usefully for my job. And I'm used to work the plugin "VizPro". It has a few of useful features. Such as:
                  1. Choose many nodes to move, copy, and container (merge node)
                  2. Have a node to access into group (edge, face, point,...)(node Brep in Vizpro)
                  3. Have a node to draw point, arc, line, circle, polygon
                  4. Have a node to input list style
                    This is only my suggest. I'm looking forward to see them in your new version
                    Thank you for your job
                  • W Offline
                    WhiteShadow
                    facing hardship with 2 things, it will be awesome if anyone can help
                    first problem:
                    made a box
                    to copy node, 6 copies
                    to move node, moved some distance
                    now, i have something line this:
                    how do i make a solid group of all these copies?
                    another problem:
                    is there a way to randomly move copied opjects between a set range (distance between 2 boxes can be anything from 3 to 10, random distance between every copy)? if yes, how?
                    eg:
                    instead of getting
                    how can i get
                      The calculate node accepts math formula so something like...
                      rand(value,value)
                      ...would output a random value. I'm not sure if that random value can be applied to the copies though.
                      If you right click the Node Editor and choose Export Scheme you could share it
                      • W Offline
                        WhiteShadow
                        Yes, rand (min, max) works for giving random value but the distance between every 2 blocks can't be randomised by it, there must be some other way or something I'm missing completely
                          Have you used the Import Scheme to load some of Sam's sample files to study the workflow?
                          That's what I did to understand the possibilities of Node Editor.
                          • samuel_tS Offline
                            samuel_t
                            @whiteshadow said:
                            first problem:
                            made a box
                            Do you mean put many groups in one group? If yes, there's a "Make group" node for that purpose. Then check Outliner panel...
                            @whiteshadow said:
                            another problem:
                            eg:
                            instead of getting
                            how can i get
                            There's at least a way. Look at this "Random Gap" parametric schema, attached below to this post:
                            https://i.ibb.co/dM5GPLX/Random-Gap.png
                            It's no yet documented but "Move" node accepts formulas to set dynamically X, Y and Z positions.
                            In formula: x + a + rand(b,c)
                            x is X position of Box in loop
                            a is Self Width of every Box
                            b is Min Gap between Boxes
                            c is Max Gap between Boxes
                            Random Gap.schema.zip
                              beuzleclair78
                              Bonjour Samuel,
                              J'ai découvert ce plugin et c'est vraiment performant !! Bravo pour le développement et les mises à jours !
                              Je l'utilise pour un projet personnel.
                              Par contre, je bloque sur l'opération "Soustraire"...
                              Comme l'exemple, je dois percer une plaque mais je dois répéter l'opération ...
                              J'ai essayé plusieurs pistes en regroupant ou en concaténant ...sans succès !
                              Je veux bien une aide pour simplifier le processus car j'ai une pièce a fabriquer avec nombreux trous !
                              Merci,
                              • E Offline
                                efeme75
                                Bonjour Samuel,
                                Congratulations for your excellent plugin!
                                Is there an undocumented feature here or do I miss something?
                                I draw two boxes both with default dimensions, except for the second one with width = 0.5. I connect each output of the DRAW BOX nodes to the inputs of an INTERSECTION node and obtain a 0.5-wide box. I then connect the output of the INTERSECTION node to the input of a MOVE node with 5 in x direction. No problem so far, I get my 0.5-wide box at location (5,0,0).
                                Now I connect the output of the first DRAW BOX node to the input of a MOVE node with -8 in x-direction without changing anything else in the above setup. Why is my 0.5-wide box now at location (-3,0,0)? It seems that the intersection between the two boxes is first computed, moved by -8 and then moved by 5 by the last MOVE node. BTW, it seems that if I connect the output node of the second DRAW BOX node to the input of a MOVE node nothing changes.
                                Thanks for your help!
                                Francois
                                PS: File in attachment
                                Parametric.skp
                                  Marion barray
                                  Hello,
                                  Is it possible to select object already built in the model ?
                                  • 5 / 5
