    [Plugin] Parametric Modeling - v0.0.7 - 03 June 2021
    86 Posts 31 Posters 121.4k Views 31 Watching
      sketchucationgreg
      Hi Samuel,
      The permanent disappearance of the model seemed to correct itself after I cleaned up my model and developed my schema further, and opened and closed SketchUp a few times along the way. I started it within a model where I had been playing around with the native DC editor so it could have been a conflict of sorts there.
      I have attached the files which I think were form that version in any case but please don't feel like you need to investigate this one further.
      I really enjoyed using the interface this time. I think I saw a request for incorporating the follow me tool. I think that would be a really powerful enhancement but I realise that might mean adding some line drawing function.
      Thanks once again Samuel. I can't wait to find another excuse to take this for another test run.
      Parametric lantern DC6 Da shape metal.zip
        lelam11234
        Hi Samuel
        I'm using this your plugin. I see it very usefully for my job. And I'm used to work the plugin "VizPro". It has a few of useful features. Such as:
        1. Choose many nodes to move, copy, and container (merge node)
        2. Have a node to access into group (edge, face, point,...)(node Brep in Vizpro)
        3. Have a node to draw point, arc, line, circle, polygon
        4. Have a node to input list style
          This is only my suggest. I'm looking forward to see them in your new version
          Thank you for your job
        • W Offline
          WhiteShadow
          facing hardship with 2 things, it will be awesome if anyone can help
          first problem:
          made a box
          to copy node, 6 copies
          to move node, moved some distance
          now, i have something line this:
          how do i make a solid group of all these copies?
          another problem:
          is there a way to randomly move copied opjects between a set range (distance between 2 boxes can be anything from 3 to 10, random distance between every copy)? if yes, how?
          eg:
          instead of getting
          how can i get
          • Rich O BrienR Online
            The calculate node accepts math formula so something like...
            rand(value,value)
            ...would output a random value. I'm not sure if that random value can be applied to the copies though.
            If you right click the Node Editor and choose Export Scheme you could share it
            • W Offline
              WhiteShadow
              Yes, rand (min, max) works for giving random value but the distance between every 2 blocks can't be randomised by it, there must be some other way or something I'm missing completely
                Have you used the Import Scheme to load some of Sam's sample files to study the workflow?
                That's what I did to understand the possibilities of Node Editor.
                • samuel_tS Offline
                  samuel_t
                  @whiteshadow said:
                  first problem:
                  made a box
                  Do you mean put many groups in one group? If yes, there's a "Make group" node for that purpose. Then check Outliner panel...
                  @whiteshadow said:
                  another problem:
                  eg:
                  instead of getting
                  how can i get
                  There's at least a way. Look at this "Random Gap" parametric schema, attached below to this post:
                  https://i.ibb.co/dM5GPLX/Random-Gap.png
                  It's no yet documented but "Move" node accepts formulas to set dynamically X, Y and Z positions.
                  In formula: x + a + rand(b,c)
                  x is X position of Box in loop
                  a is Self Width of every Box
                  b is Min Gap between Boxes
                  c is Max Gap between Boxes
                  Random Gap.schema.zip
                    beuzleclair78
                    Bonjour Samuel,
                    J'ai découvert ce plugin et c'est vraiment performant !! Bravo pour le développement et les mises à jours !
                    Je l'utilise pour un projet personnel.
                    Par contre, je bloque sur l'opération "Soustraire"...
                    Comme l'exemple, je dois percer une plaque mais je dois répéter l'opération ...
                    J'ai essayé plusieurs pistes en regroupant ou en concaténant ...sans succès !
                    Je veux bien une aide pour simplifier le processus car j'ai une pièce a fabriquer avec nombreux trous !
                    Merci,
                    • E Offline
                      efeme75
                      Bonjour Samuel,
                      Congratulations for your excellent plugin!
                      Is there an undocumented feature here or do I miss something?
                      I draw two boxes both with default dimensions, except for the second one with width = 0.5. I connect each output of the DRAW BOX nodes to the inputs of an INTERSECTION node and obtain a 0.5-wide box. I then connect the output of the INTERSECTION node to the input of a MOVE node with 5 in x direction. No problem so far, I get my 0.5-wide box at location (5,0,0).
                      Now I connect the output of the first DRAW BOX node to the input of a MOVE node with -8 in x-direction without changing anything else in the above setup. Why is my 0.5-wide box now at location (-3,0,0)? It seems that the intersection between the two boxes is first computed, moved by -8 and then moved by 5 by the last MOVE node. BTW, it seems that if I connect the output node of the second DRAW BOX node to the input of a MOVE node nothing changes.
                      Thanks for your help!
                      Francois
                      PS: File in attachment
                      Parametric.skp
                        Marion barray
                        Hello,
                        Is it possible to select object already built in the model ?
                        • 5 / 5
