    Scaling a component doesn't change identical components
    5 Posts 2 Posters 107 Views 2 Watching
      Alohaa
      If I scale the star, defined as component, located outside the rectangle, it doesn't affect the identical ones inside the rectangle and I don't understand why.
      The reason why I want to scale it: I want to mill it out with a 3mm cutter and the direction of the tips are narrower than 3mm, so the cutter can't get there and the star becomes too small.
      Kind regards
      Alohaa
      P.S.: I must correct myself: I have just tried again and now the changes are also transferred to the others! But why weren't they applied before?
      Scaling a star.skp
        You aren't opening the star component for editing and scaling the geometry inside. Do that so you are changing the component's definition.
        Click on the picture
          Alohaa
          My postscript and your message overlapped!
          I did edit the star outside the rectangle, otherwise I wouldn't have been able to change anything.
          Or isn't it that what you mean?
            Did you click on the picture and watch the GIF?
              Alohaa
              Ok, I didn't notice that it was a GIF. So, everything is clear.
              I just experienced that when I change something in the drawing, and have to open the component, the other ones are modified, too...because I have to open the component.
