    [Plugin] LordOfTheToolbars - v2.9c - 20 Dec 24
    481 Posts 92 Posters 355.8k Views 91 Watching
    • panixiaP Online
      panixia
      @laurent002 said:
      Bonjour,
      J'ai installé LordOfTheToolbars sur la version 2023, mais il semble qu'il ne trouve pas le chemin pour accéder aux menus, y a-t-il une procédure manuel pour lui indiquer le chemin ? Il semble que je n'ai pas trouvé comment faire. Du coup je me suis remis à la version 2022 faute de pouvoir retrouver mon organisation fonctionnel. Faut-il attendre une mise à jour ou est-ce qu'il y a un moyen de rendre fonctionnel l'accès aux menus.
      Merci
      Tout est expliqué en anglais dans les derniers posts précédant celui-ci
        AISmebel
        Hi. I'm ashamed that I can't figure out how it works. Maybe someone will record a training video?)))
        • fredo6F Offline
          There are videos in the first post of this thread. There are others on YouTube.
            AISmebel
            Hi Fredo. Perhaps you misunderstood me. I wanted to see a video in which, with the help of a script from the author of panixida, it will be possible to use the command menu. The menu is a very convenient tool, its absence does not allow me to switch to SU2023.
              laurent002
              Hello,
              I have installed LordOfTheToolBars on sketchup 2023, but there is no access to any menus tools. Only icons. It means that i can't creat icons, anything.
              The most interresting thing about your plugin.
              What can I do to fixe or modify to fixe that link problem.
              Thanks for your help.
              • fredo6F Offline
                @laurent002 said:
                Hello,
                Yes. Menu disappeared due to change of UI framework for Su2023 on Windows (on Mac this is still available). No workaround possible, unless Trimble provides new API methods.
                • panixiaP Online
                  panixia
                  @laurent002 said:
                  Hello,
                  Not exactly the same, but you can achieve similar result with this workaround.
                  http://sketchucation.com/forums/viewtopic.php?f=323&t=73776&view=unread#p687744
                    Julien 2
                    Thanks for the suggestion, I will give a try 😉
                    • H Offline
                      HouseOfBOP
                      I seem to have lost the Quick Command finder. I'm using Sketchup 2021 pro, and have the latest LibFredo and LOTT. I've tried reinstalling LOTT and have Sketchup installed as admin.
                      Is there any way to reset the position of where the quick command finder dialog pops up - or have I broken something?
                      Thanks v much
                      T
                      • H Offline
                        HouseOfBOP
                        I seem to have lost my Quick Command Finder pop up. I'm all up to date, Sketchup installed as admin, and have reinstalled LOTT.
                        Is there a way to reset where the popup pops up - or have I missed or broken something? I'm on 2021 Pro.
                        • fredo6F Offline
                          Do you have several monitors?
                          • H Offline
                            HouseOfBOP
                            I'm on a laptop with an extra screen. I disconnected the second screen when I was trying to retrieve the popup. No luck though.
                            • fredo6F Offline
                              Could you do the following
                              1. Open the Ruby Console
                              2. Launch the LOTT Find dialog
                              3. Copy paste the following command in the Ruby console and press Enter
                                Traductor::ChromiumWdlg.check_instance_displayed("LOTT_MiniFindDialog", true).set_position(0, 0)
                              The Find dialog should go to the position top left corner of your screen.
                              • H Offline
                                HouseOfBOP
                                That solved it. Thanks so much.
                                Take care
                                T
                                  AISmebel
                                  Hi Fredo. Please tell me, is the operation of "menu" in SketchUp 2023 expected to be restored in the future? Is there any news?
                                  • fredo6F Offline
                                    It fully depends on the Sketchup developers. I filed the requests some time ago.
                                    But, frankly, no idea....
                                      AISmebel
                                      Your plugin is amazing, I can't imagine further use of SU without it. Ot perfectly optimizes the workspace, "menu" is an integral part of it. Maybe we can help? I suggest, just like you, to make a request to the developers of SU.
                                      • N Offline
                                        NF_TM
                                        Thanks again for all your great plugins!
                                        I have a question on LordOfTheToolbars. 2.4a
                                        I am using Mac (mac OS Montrey).
                                        1. I would like to use skp2023 but the icon hover does not work.
                                          I was able to use skp2022 with no problem.
                                        2. I am using V-ray, but I cannot customize the icons.
                                          V-ray does not appear in the master toolbar manager...
                                        I would like to ask if this can be improved in the settings.
                                        Thank you in advance for your confirmation.
                                          Avex
                                          Hey, I'm having an issue installing in SU2021. It says "Could not unzip archive".
                                          Don't know why nor what to do.
                                            How are you trying to install it?
                                            What operating system? Please complete your forum profile.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 24
                                            • 25
                                            • 15 / 25
