    2.3k Posts 515 Posters 2.3m Views 520 Watching
      BrendanOB
      @rich o brien said:
      FredoCorner and RoundCorner are different beasts.
      Use your license file to validate RoundCorner
      Thanks for the quick reply.
      The issue is that i am trying to validate round corner, but it keeps telling me it is the wrong license file. I've triple checked that it is the right file i am using, directly from my license download page, it simply does not work for me.
        You have updated all your extensions to the latest releases?
        Sketchucation Tools | SketchUcation
        (sketchucation.com)
        SketchUp Plugins | PluginStore | SketchUcation
        SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
        (sketchucation.com)
        What Error Message do you get?
        • H Offline
          hsg02045
          Hello, I want to know how to remove license seats from not available desktop.
          I reset my desktop but it keep license sits.
          • TIGT Online
            Make sure you have the latest version of the SketchUcation Toolset installed to have the newest licensing set up.
            Also login to SCF and visit https://sketchucation.com/webshop/my-licences.php
            • W Offline
              wulaozhao
              how to buy Fredo6Bundle2022 license (8 plugins): $40?
              • TIGT Online
                Use this link:
                https://sketchucation.com/purchase-smart.php?plugin=Fredo6Bundle2022
                The cost varies between Premium members and others....
                  mavie
                  Okay, I don't get an error message, but I can't get in to the license insertion window (suddenly all my Fredo extensions are not working, "trial license expired" but I got a new computer, had them all up and running for a couple months and now nothing works. all is valid, perpetual license. trying to use tools on surface, everything, actually. arggghhhh.
                  I can't get around a message in the license validation window that tells me I need to update sketchucation. I am up to date. on everything. I just want to be able to input my license info. went into my licenses at sketchucation and it said all is up to date, etc...I looked for a long time for this same problem, didn't see this exact circumstance. any ideas?
                    Can you share screenshots of the ExtensionStore dialog and SCF Global License dialog?
                    https://i.imgur.com/OGN66tO.png
                    Also any error messages
                      mavie
                      Thanks, Rich. Here's requested screenshot
                      sketchucation-fredo 2022-11-04 at 9.27.04 AM.png.pdf
                        build
                        @miguelmars said:
                        Hii !! I'm having trouble activating my fredo corner license have a pup that says:
                        Error in the License Validation
                        Request to Sketchucation: ERROR_F09
                        License File for another plugin - Please check if you are trying to activate the correct license
                        You may want to check your MyLicenses page on Sketchucation and download the right license file for this plugin
                        Do you want to open your MyLicenses page on Sketchucation?
                        I buy the fredo6bundle, what can I do to activate it? Thanks in advance
                        Was this solved? I have the same error and cannot activate the extensions.
                          mavie
                            @build
                            Update Sketchucation Tools to 4.2.9
                            (sketchucation.com)
                            @mavie
                            Are you running Sketchucation Tools 4.2.9 aand the latest LibFredo?
                            (sketchucation.com)
                              anthonypope
                              LICENSING STOPPED WORKING EVEN THOUGH I HAVE PURCHASED A LICENSE.
                                (sketchucation.com)
                                • TIGT Online
                                  Anthony
                                  As Rich says ensure that you have the newest version of the SketchUcation toolset installed [it has the latest SCF license code etc]
                                  The error message you show suggests that the license file you are trying to validate mismatches with the extension itself...
                                  A common mistake is to confuse Fredo's RoundCorner and FredoCorner extensions, which are different things and need two separate licenses...
                                  The FredoCorner one has its own license and it is not included in any 'bundle' deals...
                                  If it's a Fredo extension issue also ensure you have the latest LibFredo installed.
                                  Also remember that on a MAC you must restart SketchUp to ensure everything is properly synced after the extensions and Lib are installed...
                                  As the error message says you can also check your licenses on our MyLicenses page...
                                    sincop
                                    Hello there, this is George from Beirut-Lebanon. I am trying to purchase the Fredo tools bundle (40usd) using my debit card, but the problem is that paypal doesn't exist in my country unfortunately so even the debit/credit card option (operated by paypal) won't work....is there a western union wire transfer option...because i really need the extensions for my workflow
                                    • Y Offline
                                      yoannaa
                                      Hi! I bought a Fredo RoundCorner perpetual plugin, but I have a message saying my trial is expired...can you help me with this please?
                                      Thank you πŸ˜„
                                      • TIGT Online
                                        Have you received the license file ?
                                        Have you validated it in the extension's menu ?
                                        Do you have the latest versions of the extension, LibFredo and the SketchUcation toolset installed ?
                                        Restart SketchUp after installing all of them to ensure everything syncs...
                                        If you look in MyLicenses on this site what does it say ?
                                          Big_Boss
                                          @fredo6 said:
                                          This post explains how to license some extensions published on Sketchucation.
                                          Hello, Fredo6
                                          As you can understand from the posts under the topic; PAYPAL is not available in some countries. In this case, we cannot benefit from many plugins even though we are willing to pay for them.
                                          I request you to find a permanent solution to this situation. We request you and sketchucation.com admins and moderators to use another payment tool to help us reach and use Fredo6Bundle2022 - A bundle of 8 plugins.
                                          We have been waiting for four or five months with the hope of a solution. Except for PAYPAL, if necessary, give me an IBAN number and we can transfer the plugins to it. See; We can easily get SUbD and Vertex Tools from https://evilsoftwareempire.com/. I'm looking forward to a solution similar to this and at least a promising response to this post. We hope to get back to these plugins that we have been using for years. Take care of yourselves.
                                            paddyclown
                                            Hi, I'm not sure if this is the correct place for this post, so apologies in advance if this needs moving.
                                            Despite having been able to use various of Fredo6's superb tools in the past, including after having bought a licence on both SU2021 & 22, I am currently experiencing problems...
                                            I check my licence status, let's say for Joint push pull, & it says i'm ok, but wen I try to use the tool, nothing works.
                                            & Yes, I've updated to the latest versions of both plugin & LibFredo, plus my SketchUcation plugin is also the latest version. I've tried on both 21 & 22, to no avail.
                                            This is also true for Curviloft and Tools on surface etc...
                                            Anyone have any ideas (BTW, the old free version of Joint PP works for some reason)
                                            Thanks in advance.
                                            PT
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 65
                                            • 115
                                            • 116
                                            • 63 / 116
