[Plugin] LordOfTheToolbars - v2.7b - 07 Apr 24
Hey Fredo
I have changed a shortcut key to SHIFT H but problem persists.
I opened the Ruby console and got no message when closing a pallet but I did get the attached message on start up of sketchup.
It means nothing to me, hopefully you can understand it.
Thanks for your helpMike
I have cleaned out a few unused shortcut keys. There are now just 5 shortcuts for LOTT, and I noticed that the four that are not working properly also don't show up in the 'menu' window as shown by the screen shot. The only pallet that shows up in the orange custom shortcuts and the menu window is "Often used" and that was created a long time ago. the other 4 pallets and shortcuts were created yesterday and are the ones causing issuesCheers
The warning in the console is for TTLib. It is harmless and not related to LOTT.
I cannot reproduce the problem with shortcuts. In my environment, I can just define them and they work.
Do you have the latest version of LibFredo6 and LOTT installed?
I have version 13.2a and 2.2a installed and when I check using your 'check for updates everything is green and up to date. I will uninstall both Library and LOTT and reinstall them. see if that works.
Will let you know. Thanks -
How are you checking? The current version of LibFredo6 is 13.4a.
Thanks for the input
I checked using Fredo 'Check for update command' It said it was all up to date?
I just uploaded the latest version and problem persists
I have uninstalled LOTT and am about to reinstall it.
Will report back soonCheers
Did you quit SketchUp and restart it to make sure all extensions were loaded correctly?
Did you install SketchUp correctly? That requires right clicking on the installer and selecting run as administrator.
Yes I quit SU every time I make a change.
When I installed SU I did not right click and run as administrator. I did not know that was a thing.
SU is on my personal computer. How do I fix that, Do I have to uninstall SU.. If I do that will I lose all my settings and plugins.Thanks again for your help
Quit both SketchUp and LayOut. find the downloaded installer in your Downloads folder or get it from sketchup.com/download/all. Right click on the installer, choose Run as administrator, and when prompted, choose Repair.
As for your settings and extensions, no, you will not lose them.
OMG I FIXED IT
As usual the problem was at my end.
So I figured out if you exclude the palette name from showing in the Vignette strip then the palette will not disappear once a tool is selected if you launched the palette with a shortcut key. If I select 'icon' or 'abbreviation' when setting up the favourite then the palette acts as expected and disappears once the tool is picked.
I am not sure if this is a deliberate function or an oversite. The reason I removed them from showing in the Vignette strip was to reduce clutter when moussing across for other pallets, I have them as shortcuts which I have mapped to the space mouse so I click on one of those keys when I need the palette. My work around is to assign a single letter to the abbreviation and position them at the end of the vignette strip.
I feel like a bit of a muppet for not making the connection sooner. There is nothing like beating your head against a brick wall to induce a bit of clarity!!
Thank you for your efforts in resolving this.Mike
conflict with v-ray 6.0
Hi. The plugin asks to update, but the version is up to date. What to do?
when will the final version be released
i can't use it now -
when will the last version be out I can't use now i need urgent support
NEW RELEASE: LordOfTheToolbars v2.3a - 31 Oct 22
Requirements
- LibFredo6: v13.4a or above
- Sketchup version: SU2017 and above
LordOfTheToolbars 2.3a includes
- Bug fixing
- Extension of validity
DO NOT FORGET TO UPGRADE TO LibFredo6 v13.4a or above
Home Page of LordOfTheToolbars for information and Download.
Dear Fredo,
First of all many thanks for everything you are doing, I rely on your software and innovation more than on what the entire Trimble company does. For this exact reason I was wondering if there was the possibility to just buy LOTT as you made possible for other extensions of yours.
These continuous updates are a problem because every time you make a change I have to update all the machines straight away otherwise nothing works (this time, by the way, the plugin dos not seem to load every time). I would much rather pay to update the plugin when I am ready to do so.
Nicola
@debbio said:
Dear Fredo,
First of all many thanks fro everything you are doing, I rely on your software and innovation more than on what the entire Trimble company does. For this exact reason I was wondering if there was the possibility to just buy LOTT as you made possible for other extensions of yours.
I am not sure I understand. Paying for the plugin will not change the question of plugin updates (and potential bugs)...
Hello Fredo
I have noticed that regularly my LOTT toolbars don't appear when loading SU.
It seems it's related to updates.
While I understand that you update your plugins on a regular basis, it's very annoying that essential tools get stuck each time you make an update.
I need to have a guess and try Extension Manager updates (nope), a Sketchucation tools update (nope), a manual reinstall of the LOTT plugin (overwriting) via sketchucation tools (YES)...
At least you could give us a hint when the LOTT toolbars don't appear anymore.
When I don't have a wifi connexion it's a nightmare, I need to open all my plugins toolabr again to have access to the tools I use on a daily basis (and clutter my UI as in the past).Thanks for the cool essential addon!
YES optimaforever! That is exactly the problem I was talking about and your solution seems to have been working, so far at least.
I really hope Fredo that we don't come of as entitled, obviously you are giving us all these great tools (most of the times for free!) and we are off course not in a position to demand anything.
The problem, as optimaforever hinted, is that we, or at least I, rely so much on all your plugins that when they don't work is a huge issue, and that's why I immediately bought all your plugins the minute that I could, donated to you a little bit for all the others, and we are still FAR from even.
For that reason, I was just wondering if you are planning to make a paid version even just for the privilege of not having the plugins (especially LoTT!) disappear all of a sudden every once in a while.
Thanks a lot again.
Nicola
It seems it's related to updates.Are you still using SketchUp 2017 Pro as indicated in your profile?
Was SketchUp installed correctly? That requires right clicking on the downloaded installer and selecting Run as administrator. If not, there would be issues with folder permissions that could prevent extensions from installing/updating correctly.
I've never had any issues with any of Fredo6's extensions updating and loading correctly. I made sure to install SketchUp correctly on my machines.
