    [Plugin][Code]SKMtools,Material/ImageTools
    178 Posts 37 Posters 308.9k Views 37 Watching
    • B
      blueman2
      Thanks Tig,
      I think I see where I was making a mistake, I could not find the trimmed files. I expected them to appear where the original image was. When I expanded the view, I saw them sitting off to the side.
      However, now I'm having trouble getting this onto the face of the object so that I can push/pull. I did redo this one more time and requested that the component he stood up. That worked well but then could not accurately get it onto the face. Any tips for doing this?
      Thanks again
        If you had told it to make the image-trimmed component stand up it'd be easier to see, and you could then move it into the face, using Move and perhaps Rotate if appropriate.
        Since the edges if the facets in the instance are hidden and you'll be PushPulling later I suggest you edit it and Select All, them use Entity-Info to remove and Hidden attributes...
        Once it's in place explode the instance and it should 'merge' into the surface, letting you PushPull its faces as desired...
        • boofredlayB
          boofredlay
          @tig said:
          IMPORTANT NOTICE!
          There has been a lone report of these tools not working - with a '.jar' file 'opening' rather than 'running'!
          Many of these tools use small Java '.jar' executable files that do specific tasks like zip/unzip and image manipulation.
          I have found that I can reproduce this weirdness IF I let a 'zip/unzip' application like AlZip or WinRar 'poach' the '.jar' file-type as one that it will open. If so then when Ruby tries to 'open' a '.jar' file instead of it 'executing' in Java [like it should], it 'opens' in the decompression application...
          The solution = look at your WinRar etc settings and ensure '.jar' is NOT one of its file-types for opening... 😒
          Hi TIG. Hope you are well.
          Sorry for another "it's not working for me" post but that is what this is.
          I installed the plugin through Extensions Manager, saved a new file, imported an image and run the image trimmer script and get the dots at the bottom and then it blips and nothing happens.
          I think I made sure the .jar files open with java like you mention above but I guess I have done something wrong.
          I have attached the SketchUp file I am working with if it helps.
          Thanks for any help.
          MAN0004.skp
          • boofredlayB
            boofredlay
            Hmm. I made sure 7zip and Express Zip File Compression were not associated with .jar files. These are the only zip programs on this machine that I can tell.
              I guess I've never looked to see if any zip utilities are associated with them. I guess I should.
                Hi Eric,
                I know I'm not TIG but I tried your file and it trimmed just fine. Actually more quickly than I expected.
                MAN0004.skp
                  Some decompression apps 'hijack' .jar files and then Java can't open them.
                  Check that none of your compression apps is doing that.
                  Find one of the .jar files and right-click to see what's set to open it...
                  Use Open with... from the context-menu and choose Java and set it to always open .jar files.
                  Of course you also need to Java installed on your computer !
                  Double check for that...
                  • boofredlayB
                    boofredlay
                    Yeah I installed Java prior to posting this and associated .jar with it. Not sure if I did it correctly but you can see the icon next to the .jar files as Java.
                      Looks OK, but of course a ZIP app could be hijacking it too ?
                      If you right-click on a .jar file what is listed to 'Open' it ?
                      What is listed for it in 'Open with...' ?
                      • boofredlayB
                        boofredlay
                        It seems to be opening with Java...
                          Your .jar / Java set up seems fine.
                          Dave R got your image to trim OK - so did I.
                          So something is wrong on your side ??
                          Any Ruby Console error messages ?
                          • boofredlayB
                            boofredlay
                            Sorry for the late reply, super busy lately.
                            This is what I get after I run the script.
                            Error: #<Errno::ENOENT: No such file or directory @ rb_sysopen - C:\Eric Miscellaneous\TrimmedImages\15098587-PcbMIOCd[Edges].dat>
                            C:/Users/elay/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/SKMtools/ImageTrimmer.rb:277:in readlines' C:/Users/elay/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/SKMtools/ImageTrimmer.rb:277:in make_edges'
                            C:/Users/elay/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/SKMtools/ImageTrimmer.rb:201:in process_image' C:/Users/elay/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/SKMtools/ImageTrimmer.rb:170:in initialize'
                            C:/Users/elay/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/SKMtools/ImageTrimmer.rb:834:in new' C:/Users/elay/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/SKMtools/ImageTrimmer.rb:834:in block in <top (required)>'
                              Does it make C:\Eric Miscellaneous\TrimmedImages\15098587-PcbMIOCd[Edges].dat but fails to find it, or does it fail to make it ?
                              Not making it at all points to perhaps an issue with the PNG itself [e.g. all pixels have some transparency], but if you use the PNG referred to previously it should be processed OK...
                              Failure to find or make it at all suggests a permissions issue...
                              Have you installed SketchUp properly ?
                              You can fix it and not compromise installed extensions etc, thus...
                              Close SketchUp
                              Find the relevant SketchUp installer's exe file - usually in your Downloads folder - but you might have moved it...
                              Select the installer's exe file's icon, right-click > context-menu > Install as administrator...
                              In the dialog that will open choose 'Repair'
                              SketchUp is now [re]installed with proper permissions...
                              Restart to see if that helped...
                              Otherwise, check that the folder 'Eric Miscellaneous' has no restrictive permissions set, which could be preventing the ability to write files to it via SketchUp / Java...
                              Try running the SKP from a clearly 'neutral' location - e.g. your 'Desktop'... the subfolder of files needed in the processing is always made with the SKP itself...
                              • boofredlayB
                                boofredlay
                                I did as you directed and still no joy.
                                Oh well. I hate for you to keep messing with this. I will just continue on trimming manually.
                                Thanks for all the help even though we did not get it resolved.
                                  If you ever get a clue what's up let me know...
                                  I'm at a loss...
                                  • B
                                    blajnov
                                    • E
                                      Efik_CZme Newcomers
                                      Hi guys,
                                      same problem here as boofredlay. Trimming doesnt work for me in exactly the same way. I followed the whole quest-line of repair instructions. Also no change and the tool still doesn't work.
                                      I super appreciate the fact, that there is somebody trying to make the tools, that SketchUp team is ignoring. Damn the trimming itself would save hundred hours of work... As boofredlay says..:
                                      "Back to manual trimming."
                                        Share the image you're trying to trim so we can see if there's something that can be done.
                                        • E
                                          Efik_CZme Newcomers
                                          Dave R:
                                          Wow. Thanks for the quick reply. I didn't expect that.
                                          The whole story, here we go:
                                          • I downloaded the plugin from this website.
                                          • Installed it through the extension manager.
                                          • At first use, I got the message "Open .jar with" so I selected SketchUp... As I didn't know better.
                                          • Through youtube tutorials, I realized I don't have installed java (shameful I know)
                                          • Installed the latest Java version.
                                          • Associated .jar with java.
                                          • Tried again
                                          • Got myself to the point of "Making Edges files"
                                          • Through the process the SketchUp freeze.
                                          • Went through other chats searching for solutions, until I got here and followed the whole TIG/BOOFREDLAY consultation and followed the proposed steps.
                                          • No change. I tried with multiple different .png , Including the simplest black circle. No change.
                                          I attached some explanatory pictures, including the last one. Sorry for the national language in programs (Neodpovídá = Not Responding)
                                          The last PNG I used.
                                            I imported your image into SketchUp 2022 and ran Image Trimmer. It worked just fine. It actually went a little faster than I expected.
                                            Clearly this isn't an issue with SketchUp 2022 or with Image Trimmer.
                                            Did you install SketchUp correctly? That requires right clicking on the downloaded installer and choosing Run as administrator from the Context menu.
                                            • 8 / 9
