    How to slide a slice of the object
    5 Posts 2 Posters 5.0k Views 2 Watching
      Drachenbauer
      The block in the attached screenshot is divided into three slices.
      How can i move the middle one sideways without tilting the wals of the top and bottom slices?
      it should generate horizontal faces at the steps instead.
      everything should stay one volume object
      I think about something like the push-pull, but for all faces of the middle slice together the same time as one structure, at one side in and at another out.
      I want to recreate the rail and gap structures of the little plastic pieces in a sliding puzzle, that make them slide, but not fall out.
        click on the picture
        You need to make three separate objects so the geometry doesn't stick together.
          Drachenbauer
          But i want it as a single solid group at the end of modeling.
          Edit:
          now i first grouped the middle slice, moved it, where i wanted it to stick out and exploded the group to reconnect it with the rest.
          so i had just to do a few little fixes to turn it back into a solid.
            Explode the three objects afterward. Or use Outer shell to combine them into one. Or you could model it with the center shifted in the first place. Since the geometry sticks together, moving the faces will distort the other geometry.
            Another option would be to use Vector Push/Pull from Joint Push/Pull.
              Drachenbauer
              here is now my result.
              I created a few more of them now to also show how they can interlock now.
