    The Nadesico A
    194 Posts 10 Posters 52.6k Views 10 Watching
      πŸ˜„ πŸ‘
      • Bryan KB Offline
        Thanks Mike! πŸ‘
        • Bryan KB Offline
          Very subtle change, but this makes the rear of the upper deck outboard pods point straight back as they should. It also cleaned up a lot of the geometry.
          The problem was finding the break in the angle from the sides of the upper deck. Once I saw it, I was able to make the change, but I did not see that break until the other day.
          NOW it looks like it is supposed to.
          Now, maybe, I can start on those middle pod things. Also added a little more upper deck details.
          • Bryan KB Offline
            I was going to do more under the top deck, but saw the outer rear pods were off again.
            I did manage to add more detail to the upper middle pods after I made the corrections.
            • Bryan KB Offline
              Overview to date.
              • tuna1957T Offline
                tuna1957
                Epic Bryan. I’d be stabbing my self in the head with an ice pick about now… πŸ˜‰ πŸ‘
                • L Online
                  πŸ‘
                  I hear you Tuna 🀣
                  I expect it is the challenge that keeps you going Bryan. Do you have plans for it once it is finished?
                    Simply stunning mate. A demonstration of persistance and very nicley done.
                    • Bryan KB Offline
                      @l i am said:
                      πŸ‘
                      I hear you Tuna 🀣
                      Thank tuna.
                      Thanks L i am.
                      Thanks Mike.
                      Yeah, I've managed to stop the muttering and giggling. πŸ˜†
                      No solid plans. I'll post the model here for anyone who wants it. Maybe do an anime style scene like my Junji Okubo robots I did in the past. I'll also put it up on the Warehouse. Maybe send an email to the designers.
                      What I've learned about making and manipulating custom meshes has been invaluable. I wish I had learned this years ago.
                      Still more geometry to go. Maybe a few more weeks at most.
                      • Bryan KB Offline
                        Blocking in the launch hangers. Easiest shape yet.
                        Taking a break from the underside of the upper deck.
                        Also noticed the front nacelles and support struts were too far back. Moved forward. Scaled the struts inward, then intersected with hull and deleted extra interior geometry.
                        Again, as they were both components, all I had to do was modify one.
                        Also noticed the black hook things were too short. Selected all four and scaled longer.
                        • Bryan KB Offline
                          The "frame" (what they call Gundams in non-Gundam franchise animes) that I used to scale up my line drawing in the beginning. Found in the Warehouse.
                          All this work and time and still matching scale. PHEW! I was worried by this time I would be off scale and have to enlarge or shrink the whole thing. Nope. It's good.
                            πŸ‘ Persistence is paying off mate. πŸ‘ πŸ˜„
                            • Bryan KB Offline
                              Thanks Mike! πŸ‘
                              • Bryan KB Offline
                                Hanger pods completed except for small detailing.
                                • Bryan KB Offline
                                  To scale.
                                  • Bryan KB Offline
                                    Better quality jpg overview.
                                    • L Online
                                      πŸ‘ πŸ‘ πŸ‘
                                      • Bryan KB Offline
                                        Thanks L i am! πŸ‘
                                          Thanks for passing that along. Nicely done mate.
                                          • Bryan KB Offline
                                            Antennas created.
                                            I learned... something incredible when making the base of the antennas. You can Push/Pull+Ctl (new extension) then scale, then... ROTATE JUST THE SELECTED FACE ON ANY EDGE! Even if it's oval!
                                            But you have to hold the Down Arrow key when it's a weird shape and an even weird angle.
                                            I would have never been able to construct this line by line. I literally stumbled across this.
                                            Still had to twiddle the lines points to get it flat on the surface, but this easily saved hours!
                                            • 4 / 10
