    The Nadesico A
    194 Posts 10 Posters 78.5k Views 10 Watching
      Simply stunning mate. A demonstration of persistance and very nicley done.
      • Bryan KB Offline
        @l i am said:
        @tuna1957 said:
        Epic Bryan. I’d be stabbing my self in the head with an ice pick about now… πŸ˜‰
        πŸ‘
        I hear you Tuna 🀣
        I expect it is the challenge that keeps you going Bryan. Do you have plans for it once it is finished?
        Thank tuna.
        Thanks L i am.
        Thanks Mike.
        Yeah, I've managed to stop the muttering and giggling. πŸ˜†
        No solid plans. I'll post the model here for anyone who wants it. Maybe do an anime style scene like my Junji Okubo robots I did in the past. I'll also put it up on the Warehouse. Maybe send an email to the designers.
        What I've learned about making and manipulating custom meshes has been invaluable. I wish I had learned this years ago.
        Still more geometry to go. Maybe a few more weeks at most.
        • Bryan KB Offline
          Blocking in the launch hangers. Easiest shape yet.
          Taking a break from the underside of the upper deck.
          Also noticed the front nacelles and support struts were too far back. Moved forward. Scaled the struts inward, then intersected with hull and deleted extra interior geometry.
          Again, as they were both components, all I had to do was modify one.
          Also noticed the black hook things were too short. Selected all four and scaled longer.
          • Bryan KB Offline
            The "frame" (what they call Gundams in non-Gundam franchise animes) that I used to scale up my line drawing in the beginning. Found in the Warehouse.
            All this work and time and still matching scale. PHEW! I was worried by this time I would be off scale and have to enlarge or shrink the whole thing. Nope. It's good.
              πŸ‘ Persistence is paying off mate. πŸ‘ πŸ˜„
              • Bryan KB Offline
                Thanks Mike! πŸ‘
                • Bryan KB Offline
                  Hanger pods completed except for small detailing.
                  • Bryan KB Offline
                    To scale.
                    • Bryan KB Offline
                      Better quality jpg overview.
                        πŸ‘ πŸ‘ πŸ‘
                        • Bryan KB Offline
                          Thanks L i am! πŸ‘
                            Thanks for passing that along. Nicely done mate.
                            • Bryan KB Offline
                              Antennas created.
                              I learned... something incredible when making the base of the antennas. You can Push/Pull+Ctl (new extension) then scale, then... ROTATE JUST THE SELECTED FACE ON ANY EDGE! Even if it's oval!
                              But you have to hold the Down Arrow key when it's a weird shape and an even weird angle.
                              I would have never been able to construct this line by line. I literally stumbled across this.
                              Still had to twiddle the lines points to get it flat on the surface, but this easily saved hours!
                              • Bryan KB Offline
                                You're welcome and thanks!
                                • Bryan KB Offline
                                  Underneath upper deck detail update. I may have overdone it, but there is still one more key element to add.
                                  I can't even begin to describe the teasing and twisting I did on this detail.
                                  • tuna1957T Offline
                                    tuna1957
                                    When do you start putting in the rivets? πŸ˜† πŸ˜‰ Looks like your around third heading for home ! πŸ‘
                                    • Bryan KB Offline
                                      Front, under hanger landing blocks roughed in. Second main element under upper deck completed (the vertical cylinder thing). Forward indented the underside of the upper deck and scaled the pods things forward. All major module blocks are completed.
                                      FINALLY! πŸ˜†
                                      Now on to the detailing after I take a few days to look it over before committing.
                                      • ntxdaveN Offline
                                        ntxdave
                                        The details in your model just keep getting interesting. Sure will be neat to see the final model and a rendering. πŸ‘
                                        Press F1...thank me later
                                        • Bryan KB Offline
                                          Thank ntxdave!
                                          There is a lot of detail on this design yet to come. I've just got the big stuff completed. However, it's mostly greeble after I finalize the landing pods and neck shapes.
                                          • Bryan KB Offline
                                            Still pushing around the shape of the under-pods.
                                            • 8 / 10
