    [Plugin] SPGears
    93 Posts 41 Posters 197.9k Views 41 Watching
      Here's v1.4 RBZ, which fixes a tiny typo in a file-path setting up the extension...
      https://sketchucation.com/pluginstore?pln=SPGears_mjg
      • kenK
        ken
        Thanks, TIG
        I have been chasing why I couldn't install this plugin. It kept appearing in the SketchUcation Extension Manager as Disabled Extensions and I couldn't change the setting.
        And maybe I missed the text, but it would help, if there was some indication where plugin/extensions are located.
        Again, thank you
        Ken
          If you use the built-in Extension Manager you should be able to enable an extension, however an old extension like this is not 'signed' - so you will need the Extension Manager's settings 'Loading Policy' to be 'Unrestricted'...
          Most plugins have 'usage notes' explaining where to find and use the tools...
          In the case of this particular one it's spelled out in the first post of this thread...
          Menu Item : Plugins -> SPGears - in newer versions of SketchUp that menu was re-titled 'Extensions'...
          • kenK
            ken
            Tig
            I used the extension manager and I had it to load unsigned plugins.
            Still, it would end up in the disabled section and I couldn't move it from there. Tried many times and many ways.
            However, I got it running now.
              antwal
              hi all,
              this plugin working with sketchup 2021? i have installed it but when try generate gear with default settings i receive the message "Diametral = 1.5" and not working, how can resolve this problem?
              Thanks.
                SPGears works fine in SketchUp 2021 for me.
                What do you do after you get that message? It's not an error. It's just information.
                Click on the picture
                • G
                  GregorS
                  It is now 2022 perhaps things have changed som even though I am using SU2017 Make.
                  I used to draw involute gears by hand, tracing a profile from "geargenerator.com" at a large scale and using arcs with suitable radii for the various sections, pushing into appropriate thickness and 3D printing in PLA made eminently usable gears.
                  One 'bug' that I have seen with SPGears 1.4 on Windows is a klipping plane phenomenon that is baffling. Only at a limited zoom factor is the generated gear visible and neither Zoom All nor Zoom Selected manage to make the gear appear. Perspective or Parallel projection makes no difference.
                    I'm not seeing that when using this extensions. Share a .skp file so we can see what you are getting.
                      dennipeter
                      @antwal said:
                      hi all,
                      Thanks.
                      I too get the same "Dimetral" pop up box, and no gear seems to get created after that.
                        Radim
                        Hello,
                        how can I define the height of the tooth?
                          This extension models involute gear teeth. Their height is determined by the extension. Since the teeth are created as components separate from the body of the gear, you could edit the tooth component to change its height.
                            Doiiu
                            Hello!
                            Could you please check this:
                            I need to 3D print so need mm instead of inches
                            Pitch is in mm, but Face is in inches; typing mm is not working because of floating value
                            I read that I can change this in .rb file,
                            And find out that SPGears do not exist neither in Manager or in Plugin folder..
                            Any options I can try?
                            Thank you!
                              While you wait for this to be fixed you might have a look for other plugins to make gears. I have an ancient one (that still works fine in SU2023) called DH Involute Gear. It only creates a 2D gear shape but you can then use Push/Pull to extrude it to the desired height. It has the benefit of creating the entire gear shape as a single face instead of greating the teeth as separate objects.
                              click on the picture
                              If you want to edit this plugin yourself look for MJGrundman_SPGears. Both the .rb and the folder have that name.
                              FWIW, I generally find it better to model for 3D printing using meters for the units. Enter millimeters as if they are meters. Export the .stl with units set to meters and import into the slicer in millimeters.
                                Doiiu
                                Thank you very much!
                                quick search didn't show me DH Involute Gear,
                                however I just take faces and push them to desired thickness
                                It was obvious and I don't know why I didn't do this from the very beginning
                                Sorry I was stupid
                                  It might be that the old DH Involute Gear is no longer available. I've had it so long I don't recall where I got it from.
                                  Although the fix is easy enough, I wouldn't say you're being stupid. It's reasonable that all those dimensions should be in the same units.
                                  Another thing you might want to consider if you are printing standard types of gears is that you can find CAD files for gears that you could import into SketchUp.
                                    jumpjack
                                    In case this amazing plugin is still maintained, I'd have a couple of suggestions to improve it, in order of implementation difficulty:
                                    • add an option to add a line representing the axis of the gear: it makes it easier to align them (easy?)
                                    • add an option to keep the teeth size constant while changing the teeth number, else gears with different number of teeth will not match; for example, if I create a 200t gear and a 20t gear, I then must manually reduce size of 20t to 1/10 to make teeth match (complex)
                                    • add worm+gear support (hard)
                                      @jumpjack said:
                                      In case this amazing plugin is still maintained ...
                                      It doesn't appear to be but who knows? In the meantime at least your first request can easily be dealt with.
                                      As it is now the group is created with the origin and blue axis centered on the gear. Simple enough to open the group for editing and draw an edge for the gear axis. Or convert the group to a component. When you drag the component in from the Components panel you'll have hold of it by its origin making it simple enough to place. You could quickly set the component to glue to a face if you want to determine its orientation, too.
                                      FWIW there are better options for modeling gears and worms if you need more than a simple representation of the gear. Maybe for 3D printing, for example.
                                      Are you still using SketchUp 2013 Make as your profile indicates?
                                        jumpjack
                                        Yes, man ually creating the axis is easy.... but it's boring if you are building a mechanism with many gears.
                                        I am still using SU2013, sometimes SU2014... but sometimes also SU8 πŸ˜„ because it's the only one authorize to run on my office PC, who knows why...
                                        The keypoint is I need to use MSPhysics, which does not work in 64 bit versions.
                                        But maybe the situation changed? Does it exist a physics simulator plugin (and a gear generator plugin) for 64 bit versions?
                                        • robertWanR
                                          robertWan
                                          The plugin works, but when starting SU8 I get:
                                          "Error Loading File MJGrundman_SPGears.rb
                                          uninitialized constant MJGrundman::SPGears::EXTENSION"
                                          Any conflict with another plugin? I've had it on another computer before with no problems.
                                          Robert
                                          • robertWanR
                                            robertWan
                                            But if... someday. There are a lot of parameters here, but 2D.
                                            https://evolventdesign.com/pages/spur-gear-generator
                                            Robert
                                            • 4 / 5
