    Lotus 49
    17 Posts 5 Posters 5.0k Views 5 Watching
    • ntxdaveN Offline
      ntxdave
      I have to ask, is this a photo you are using for reference or you model? If it is your model, I am blown away!
      Press F1...thank me later
      • tuna1957T Online
        tuna1957
        I want to see more πŸ˜’ πŸ‘
          Thanks folks, it's a model, no more than ten percent on.
          • Bryan KB Offline
            That's the model? I also thought it was photo reference.
            This is going to be good! πŸ‘
              Thanks, I hope so. Like you I get memory issues slowing stuff down.
                That looks really exiting Mike, what renderer are you using?
                  Thanks mate, Twilight V2 Pro. Slow process.
                    Hi Mike
                    You may already have some texture but here are some PBR textures, https://www.sketchuptextureclub.com/textures/search-textures?n=S&m=S
                    I usualy find if the texture are applied in the render engine and not in SU it maps correctly
                      Ta mate. πŸ‘
                      • Bryan KB Offline
                        Don't keep us hanging! This was one of my favorite cars! Really looking forward to progress updates!
                          I finally found a decent rev counter (Smith's instruments 12,000rpm) so hopefully I can move on with the dashboard/instruments. Engine details have been tough to find with depictions stated to be for 1967 actually referencing a 1973 engine which is wrong for this car. The 1973 car has the low mounted 'Wings'..
                            Well, trying to clean up inside the jam jar, annoying. Starting to run into some serious glitches which I will have to work at to clear.
                            • tuna1957T Online
                              tuna1957
                              Progress is a good thing πŸ‘
                              • Bryan KB Offline
                                Better and better. Nice! πŸ‘
                                  Lovely work Mike πŸ‘ πŸ‘
                                    Thanks folks, getting closer to the correct geometry for the centre cab. I guess number 20 is the charm.
