    The Nadesico A
    194 Posts 10 Posters 49.8k Views 10 Watching
    • Bryan KB Offline
      Still working on the block out of the upper decks.
      • Bryan KB Offline
        Fiddle, fiddle. Closer and closer.
        • Bryan KB Offline
          I'll set up a better animation tomorrow.
          • Bryan KB Offline
            The animation will have to wait. Brain frazzled from working on the upper decks.
            For the same reason I'm taking a break from figuring out the upper decks, so I just did some inner detailing. Inset the main beam muzzle and resized the inner front pylon nacelle mounts. Also added the black panels to the front nacelle struts. They will also get more detail in the future.
            • Bryan KB Offline
              I really do love the shape of this ship. 4 months (four?! damn) of working on it and I still like looking at it.
              • Bryan KB Offline
                Not a lot to see. Still pushing and pulling vectors and lines and even redrawing lines for the upper decks. It's getting there. A little more sleeker and smoother.
                Took a stab at the upper deck rear pods. Meh. Better, but I'll have to remake them.
                • tuna1957T Offline
                  tuna1957
                  Waiting patiently for the big finish πŸ‘
                  • Bryan KB Offline
                    Thanks tuna!
                    Almost ready to commit on upper decks.
                    • Bryan KB Offline
                      Overview to date. YAY! It's halfway finished!
                      Did I mention the remaining detailing? Yeah, that's the other half.
                      • Bryan KB Offline
                        The overall shape of the upper decks is now good. Committing to detailing. There will still be some fiddling with the overall shape as I add details, but the general shape is now good.
                        There are still 4 more sections to create. The two mecha hangers on top of the forward pylon struts and the two landing pods underneath the forward pylon struts. Both of which will be an individual section, made into components, then copied and flipped.
                        THEN the final detailing. But first, rough in the details of the upper decks.
                        • Bryan KB Offline
                          Oops, the bridge was to big. Way too big. Fixed. Simple scale down.
                          • Bryan KB Offline
                            Taking a break and re-watching the series again for more insight to the upper decks and future detailing.
                            The rear of the upper decks is still not quite right. No major changes required, but certainly more tweaking of proportions is needed.
                            Now that I have gotten this far, I see from the anime that everything so far is spot on with only tiny variations in the details, which is also not consistent from episode to episode. So no problems there.
                            The final detailing though... holy moly. Yeah, months to go yet.
                              Hi Bryan, The time you are spending on that reflects your level of integrity. I happened to get hold of a 3D model of that craft and it does not hold a candle to your, as yet, unfinished model πŸ‘ πŸ˜‰
                              • Bryan KB Offline
                                Thanks L i am! πŸ‘
                                • Bryan KB Offline
                                  Once again, impossible geometry for the rear upper decks. This is going to take a while.
                                  • tuna1957T Offline
                                    tuna1957
                                    Stick with it. You’ll get there. πŸ‘
                                    • Bryan KB Offline
                                      Thanks tuna. πŸ‘
                                        He is right of course mate. Just ignore the pressure of being the resident spaceship constructor on on you go bit by bit. Better than the telle(Vision). πŸ‘
                                        • Bryan KB Offline
                                          Here are the miles of hidden geometry. I had to force so many angles to make this thing work, plus Fredo's Tools on Surface, Curviloft and Joint Push/Pull.
                                          Plus a lot of intersecting shapes to get the shape I wanted and then stray line clean up. This is why I waited to use any smoothing until I was absolutely sure of each shape.
                                          A crazy, insane design of a spaceship. The artists were off their rockers! But damn it looks good!
                                          • Bryan KB Offline
                                            Thanks Mike. πŸ‘
                                            Resident spaceship constructor. You know, I've not noticed there haven't been a lot of spaceships shown here in recent times. That's kind of odd. Hmmm.
                                            OK. I think I've got the shape right and I'm going for it. Could not have done this without Fredo's Joint Push/Pull and Tools on Surface. Yes, the outboard rear pods really do look like that. I've spent hours now looking at the videos and not even the animators knew how to make the shape flow in that area. Yet, that's how it works. The geometry says it can only work that way.
                                            Starting to really shape up now. Lots of Erase+CTRL clean up as I become sure of the shapes. Next, rebuild the rear upper deck pod things in the middle.
                                            • 3 / 10
