    The Nadesico A
    194 Posts 10 Posters 84.9k Views 10 Watching
    • Bryan KB
      Upper deck was too long in the back.
      Sloped the main hull a little bit more. Still needs a bit more slope on upper and lower hull. So, so glad I did not detail the main hull yet.
      • Bryan KB
        Roughing the bridge. It's close, but not round enough.
        • Bryan KB
          Other views. No progress today.
          • Bryan KB
            Smoothed out the bridge. Had to completely rebuild. Used Curviloft skin countours. It's done, just needs detailing.
            Added the bubble to the main hull. It's a group within the component. (it's too small and I've already enlarged it)
            Fiddled with the overall shape of the upper decks. Smoothed out (Erase+Ctrl) and narrowed the front of the neck. Erase+Ctrl'd the remaining hull lines, except the very top.
            • Bryan KB
              Blocking out the top decks. Same old issues. Odd angles and shapes. No decent references.
              • tuna1957T
                tuna1957
                It looks like the finish line is in sight πŸ‘ πŸ‘
                  ^ It does indeed and a fine conclusion it will be. πŸ‘
                  • Bryan KB
                    πŸ˜† πŸ˜† For the block out, yes. The details? Maybe another month. πŸ˜† πŸ˜†
                    • Bryan KB
                      Thanks Mike and tuna, but the level of detail is going to take a while. Here is a sample.
                      • Bryan KB
                        Still working on the block out of the upper decks.
                        • Bryan KB
                          Fiddle, fiddle. Closer and closer.
                          • Bryan KB
                            I'll set up a better animation tomorrow.
                            • Bryan KB
                              The animation will have to wait. Brain frazzled from working on the upper decks.
                              For the same reason I'm taking a break from figuring out the upper decks, so I just did some inner detailing. Inset the main beam muzzle and resized the inner front pylon nacelle mounts. Also added the black panels to the front nacelle struts. They will also get more detail in the future.
                              • Bryan KB
                                I really do love the shape of this ship. 4 months (four?! damn) of working on it and I still like looking at it.
                                • Bryan KB
                                  Not a lot to see. Still pushing and pulling vectors and lines and even redrawing lines for the upper decks. It's getting there. A little more sleeker and smoother.
                                  Took a stab at the upper deck rear pods. Meh. Better, but I'll have to remake them.
                                  • tuna1957T
                                    tuna1957
                                    Waiting patiently for the big finish πŸ‘
                                    • Bryan KB
                                      Thanks tuna!
                                      Almost ready to commit on upper decks.
                                      • Bryan KB
                                        Overview to date. YAY! It's halfway finished!
                                        Did I mention the remaining detailing? Yeah, that's the other half.
                                        • Bryan KB
                                          The overall shape of the upper decks is now good. Committing to detailing. There will still be some fiddling with the overall shape as I add details, but the general shape is now good.
                                          There are still 4 more sections to create. The two mecha hangers on top of the forward pylon struts and the two landing pods underneath the forward pylon struts. Both of which will be an individual section, made into components, then copied and flipped.
                                          THEN the final detailing. But first, rough in the details of the upper decks.
                                          • Bryan KB
                                            Oops, the bridge was to big. Way too big. Fixed. Simple scale down.
                                            • 6 / 10
