    The Nadesico A
    194 Posts 10 Posters 56.7k Views 10 Watching
    • Bryan KB Offline
      Other views. No progress today.
      • Bryan KB Offline
        Smoothed out the bridge. Had to completely rebuild. Used Curviloft skin countours. It's done, just needs detailing.
        Added the bubble to the main hull. It's a group within the component. (it's too small and I've already enlarged it)
        Fiddled with the overall shape of the upper decks. Smoothed out (Erase+Ctrl) and narrowed the front of the neck. Erase+Ctrl'd the remaining hull lines, except the very top.
        • Bryan KB Offline
          Blocking out the top decks. Same old issues. Odd angles and shapes. No decent references.
          • tuna1957T Offline
            tuna1957
            It looks like the finish line is in sight πŸ‘ πŸ‘
              ^ It does indeed and a fine conclusion it will be. πŸ‘
              • Bryan KB Offline
                πŸ˜† πŸ˜† For the block out, yes. The details? Maybe another month. πŸ˜† πŸ˜†
                • Bryan KB Offline
                  Thanks Mike and tuna, but the level of detail is going to take a while. Here is a sample.
                  • Bryan KB Offline
                    Still working on the block out of the upper decks.
                    • Bryan KB Offline
                      Fiddle, fiddle. Closer and closer.
                      • Bryan KB Offline
                        I'll set up a better animation tomorrow.
                        • Bryan KB Offline
                          The animation will have to wait. Brain frazzled from working on the upper decks.
                          For the same reason I'm taking a break from figuring out the upper decks, so I just did some inner detailing. Inset the main beam muzzle and resized the inner front pylon nacelle mounts. Also added the black panels to the front nacelle struts. They will also get more detail in the future.
                          • Bryan KB Offline
                            I really do love the shape of this ship. 4 months (four?! damn) of working on it and I still like looking at it.
                            • Bryan KB Offline
                              Not a lot to see. Still pushing and pulling vectors and lines and even redrawing lines for the upper decks. It's getting there. A little more sleeker and smoother.
                              Took a stab at the upper deck rear pods. Meh. Better, but I'll have to remake them.
                              • tuna1957T Offline
                                tuna1957
                                Waiting patiently for the big finish πŸ‘
                                • Bryan KB Offline
                                  Thanks tuna!
                                  Almost ready to commit on upper decks.
                                  • Bryan KB Offline
                                    Overview to date. YAY! It's halfway finished!
                                    Did I mention the remaining detailing? Yeah, that's the other half.
                                    • Bryan KB Offline
                                      The overall shape of the upper decks is now good. Committing to detailing. There will still be some fiddling with the overall shape as I add details, but the general shape is now good.
                                      There are still 4 more sections to create. The two mecha hangers on top of the forward pylon struts and the two landing pods underneath the forward pylon struts. Both of which will be an individual section, made into components, then copied and flipped.
                                      THEN the final detailing. But first, rough in the details of the upper decks.
                                      • Bryan KB Offline
                                        Oops, the bridge was to big. Way too big. Fixed. Simple scale down.
                                        • Bryan KB Offline
                                          Taking a break and re-watching the series again for more insight to the upper decks and future detailing.
                                          The rear of the upper decks is still not quite right. No major changes required, but certainly more tweaking of proportions is needed.
                                          Now that I have gotten this far, I see from the anime that everything so far is spot on with only tiny variations in the details, which is also not consistent from episode to episode. So no problems there.
                                          The final detailing though... holy moly. Yeah, months to go yet.
                                            Hi Bryan, The time you are spending on that reflects your level of integrity. I happened to get hold of a 3D model of that craft and it does not hold a candle to your, as yet, unfinished model πŸ‘ πŸ˜‰
                                            • 6 / 10
