    The Nadesico A
    194 Posts 10 Posters 78.5k Views 10 Watching
    • Bryan KB Offline
      Very rough scale and block-out of neck and upper decks.
      I now see I have a main hull problem as well. It is too vertical. Damn glad I left that extra fore to aft hull line in. I can change the geometry without messing up the previous work... too much. sigh
      So fix the hull first and then move back to the neck and upper decks.
        Lots of progress on this, going really nicely mate. πŸ‘
        • Bryan KB Offline
          Thanks Mike! πŸ‘
          • Bryan KB Offline
            Minor tweaks. Trying to tighten things up a little. Refining the shapes. Double checking lines and positions for the future details before I start on the upper decks shapes.
            • Bryan KB Offline
              Tweaking the neck geometry.
              • Bryan KB Offline
                Upper deck was too long in the back.
                Sloped the main hull a little bit more. Still needs a bit more slope on upper and lower hull. So, so glad I did not detail the main hull yet.
                • Bryan KB Offline
                  Roughing the bridge. It's close, but not round enough.
                  • Bryan KB Offline
                    Other views. No progress today.
                    • Bryan KB Offline
                      Smoothed out the bridge. Had to completely rebuild. Used Curviloft skin countours. It's done, just needs detailing.
                      Added the bubble to the main hull. It's a group within the component. (it's too small and I've already enlarged it)
                      Fiddled with the overall shape of the upper decks. Smoothed out (Erase+Ctrl) and narrowed the front of the neck. Erase+Ctrl'd the remaining hull lines, except the very top.
                      • Bryan KB Offline
                        Blocking out the top decks. Same old issues. Odd angles and shapes. No decent references.
                        • tuna1957T Offline
                          tuna1957
                          It looks like the finish line is in sight πŸ‘ πŸ‘
                            ^ It does indeed and a fine conclusion it will be. πŸ‘
                            • Bryan KB Offline
                              πŸ˜† πŸ˜† For the block out, yes. The details? Maybe another month. πŸ˜† πŸ˜†
                              • Bryan KB Offline
                                Thanks Mike and tuna, but the level of detail is going to take a while. Here is a sample.
                                • Bryan KB Offline
                                  Still working on the block out of the upper decks.
                                  • Bryan KB Offline
                                    Fiddle, fiddle. Closer and closer.
                                    • Bryan KB Offline
                                      I'll set up a better animation tomorrow.
                                      • Bryan KB Offline
                                        The animation will have to wait. Brain frazzled from working on the upper decks.
                                        For the same reason I'm taking a break from figuring out the upper decks, so I just did some inner detailing. Inset the main beam muzzle and resized the inner front pylon nacelle mounts. Also added the black panels to the front nacelle struts. They will also get more detail in the future.
                                        • Bryan KB Offline
                                          I really do love the shape of this ship. 4 months (four?! damn) of working on it and I still like looking at it.
                                          • Bryan KB Offline
                                            Not a lot to see. Still pushing and pulling vectors and lines and even redrawing lines for the upper decks. It's getting there. A little more sleeker and smoother.
                                            Took a stab at the upper deck rear pods. Meh. Better, but I'll have to remake them.
                                            • 6 / 10
