    The Nadesico A
    194 Posts 10 Posters 84.9k Views 10 Watching
    • Bryan KB
      @l i am said:
      :thumb: πŸ‘ πŸ‘ πŸ˜„
        Very sharp but you put a lot into them. Definitely very nice to see mate. πŸ‘Š πŸ‘
        • Bryan KB
          Thanks Mike!
          • Bryan KB
            Very rough scale and block-out of neck and upper decks.
            I now see I have a main hull problem as well. It is too vertical. Damn glad I left that extra fore to aft hull line in. I can change the geometry without messing up the previous work... too much. sigh
            So fix the hull first and then move back to the neck and upper decks.
              Lots of progress on this, going really nicely mate. πŸ‘
              • Bryan KB
                Thanks Mike! πŸ‘
                • Bryan KB
                  Minor tweaks. Trying to tighten things up a little. Refining the shapes. Double checking lines and positions for the future details before I start on the upper decks shapes.
                  • Bryan KB
                    Tweaking the neck geometry.
                    • Bryan KB
                      Upper deck was too long in the back.
                      Sloped the main hull a little bit more. Still needs a bit more slope on upper and lower hull. So, so glad I did not detail the main hull yet.
                      • Bryan KB
                        Roughing the bridge. It's close, but not round enough.
                        • Bryan KB
                          Other views. No progress today.
                          • Bryan KB
                            Smoothed out the bridge. Had to completely rebuild. Used Curviloft skin countours. It's done, just needs detailing.
                            Added the bubble to the main hull. It's a group within the component. (it's too small and I've already enlarged it)
                            Fiddled with the overall shape of the upper decks. Smoothed out (Erase+Ctrl) and narrowed the front of the neck. Erase+Ctrl'd the remaining hull lines, except the very top.
                            • Bryan KB
                              Blocking out the top decks. Same old issues. Odd angles and shapes. No decent references.
                              • tuna1957T
                                tuna1957
                                It looks like the finish line is in sight πŸ‘ πŸ‘
                                  ^ It does indeed and a fine conclusion it will be. πŸ‘
                                  • Bryan KB
                                    πŸ˜† πŸ˜† For the block out, yes. The details? Maybe another month. πŸ˜† πŸ˜†
                                    • Bryan KB
                                      Thanks Mike and tuna, but the level of detail is going to take a while. Here is a sample.
                                      • Bryan KB
                                        Still working on the block out of the upper decks.
                                        • Bryan KB
                                          Fiddle, fiddle. Closer and closer.
                                          • Bryan KB
                                            I'll set up a better animation tomorrow.
                                            • 6 / 10
