    The Nadesico A
    194 Posts 10 Posters 64.0k Views 10 Watching
    • Bryan KB Offline
      Thanks tuna. Thanks L i am. πŸ‘
      • Bryan KB Offline
        2 more views.
        • Bryan KB Offline
          Rear engines shaping up somewhat.
          Just a reminder that everything to date is still just blocking out. Even the front nacelles. I just did a little extra on those to give me an idea of what I need to do once the blocking was done, but even they need more attention. Once the mass shapes are good, I will go back and smooth everything out with more faces. So there are many more stages to go after the block-outs are done.
          Months I tell you! πŸ˜†
          • Bryan KB Offline
            Forgot to mention I will be using Curviloft for final cleanup and smoothing.
            I will be sure to show how I use it. I've already tested it and it's going to work beautifully.
            But I have to finish the block-out shapes first. So it will be some time before I get to that stage.
              πŸ‘
              Want one. Hasda be would never be the same but, I could live with that very easily....... 🀣
              • Bryan KB Offline
                @mike amos said:
                :thumb:
                πŸ‘ πŸ‘
                • tuna1957T Offline
                  tuna1957
                  Excellent progress πŸ‘ Funny side note…. when I see the title of your post my brain says Nabisco and I start looking for the cookies πŸ˜†
                  • Bryan KB Offline
                    Thanks tuna!
                    LOL, yeah I had the same problem when I started watching the show. πŸ˜†
                    More engine pod updates.
                    • Bryan KB Offline
                      Correctly positioned the engine pods. Made basic pod struts as component, then used strut for equal placement.
                      • Bryan KB Offline
                        Geometry clean up to make the surface flat for the side pod thing to come.
                        • tuna1957T Offline
                          tuna1957
                          Looks like good progress πŸ‘
                          • Bryan KB Offline
                            Overview time again!
                            • Bryan KB Offline
                              Rear engine pod rough-in (block out) almost done.
                              Note the other geometry changes again on pods.
                              • Bryan KB Offline
                                Rear engine side pods created. Pure fiddly work here. Had to create the faces line by line. I stared with the inner face on the engine pod itself and worked my way out. After many false starts. πŸ˜†
                                Then made into component and copied, then flipped for the other side.
                                Again, note the very slight geometry changes on the rest of the pod.
                                  Very sharp mate, looking forward to some renders. πŸ‘
                                  • Bryan KB Offline
                                    Thanks as always Mike! πŸ‘
                                    • Bryan KB Offline
                                      2 more views.
                                      • Bryan KB Offline
                                        Rear engine pods block-out completed. Also testing smoothing using Erase+ctrl on lines. Did not change geometry at this stage.
                                        Not committed to this smoothing just yet. Just testing. It might be good for some places where Curviloft might not be needed.
                                        Man did I have to fiddle with those rear hook things. Total different shape than the front ones.
                                        • tuna1957T Offline
                                          tuna1957
                                          Nice πŸ‘ now I’ll go quietly wait in my corner for the renders πŸ˜†
                                          • Bryan KB Offline
                                            ...but your children may be grown by the time I finish this one. πŸ˜†
                                            I was doing some other preliminary smoothing tests and, man, have I got trouble. Curviloft worked great on the nose of the front nacelles, but another section toward the rear of the front nacelles are going to require complete rebuilds.
                                            No problem though. I'm really learning new things on this one. πŸ‘ It's also the cleanest complex build I've done to date. Minimal stray line to hunt down and erase, that sort of thing.
                                            • 4 / 10
