    The Nadesico A
    194 Posts 10 Posters 60.6k Views 10 Watching
    • Bryan KB Offline
      Back to this in a few days. Doing some brain salad surgery on my laptop. Much needed maintenance.
      • Bryan KB Offline
        Rear grill things completed.
        • Bryan KB Offline
          Forward nacelle struts cleaned up. Intersected main hull and then deleted excess lines that were inside the main hull and filled in the faces. It's not "perfect", but upper and lower pods will hide most of the details later. But is IS flush with the hull now.
          • Bryan KB Offline
            Progress to date.
            • tuna1957T Offline
              tuna1957
              Great progress πŸ‘ Looking forward to seeing it in a render.
              • Bryan KB Offline
                Thanks tuna. πŸ‘
                • Bryan KB Offline
                  Go sidetracked on the artist studio render. But I learned a lot from it!
                  Let's see, what part to model next? The rear engines I think...
                  • Bryan KB Offline
                    First rough block of the rear engines.
                    Same technique as before. One component, replicated 4 times for each pod. I'll add the missing gap sections after I finalize the main pods.
                    Now for the fiddling... first I'll get the outlines and mass shaped up.
                    • Bryan KB Offline
                      Thanks tuna. Thanks L i am. πŸ‘
                      • Bryan KB Offline
                        2 more views.
                        • Bryan KB Offline
                          Rear engines shaping up somewhat.
                          Just a reminder that everything to date is still just blocking out. Even the front nacelles. I just did a little extra on those to give me an idea of what I need to do once the blocking was done, but even they need more attention. Once the mass shapes are good, I will go back and smooth everything out with more faces. So there are many more stages to go after the block-outs are done.
                          Months I tell you! πŸ˜†
                          • Bryan KB Offline
                            Forgot to mention I will be using Curviloft for final cleanup and smoothing.
                            I will be sure to show how I use it. I've already tested it and it's going to work beautifully.
                            But I have to finish the block-out shapes first. So it will be some time before I get to that stage.
                              πŸ‘
                              Want one. Hasda be would never be the same but, I could live with that very easily....... 🀣
                              • Bryan KB Offline
                                @mike amos said:
                                :thumb:
                                πŸ‘ πŸ‘
                                • tuna1957T Offline
                                  tuna1957
                                  Excellent progress πŸ‘ Funny side note…. when I see the title of your post my brain says Nabisco and I start looking for the cookies πŸ˜†
                                  • Bryan KB Offline
                                    Thanks tuna!
                                    LOL, yeah I had the same problem when I started watching the show. πŸ˜†
                                    More engine pod updates.
                                    • Bryan KB Offline
                                      Correctly positioned the engine pods. Made basic pod struts as component, then used strut for equal placement.
                                      • Bryan KB Offline
                                        Geometry clean up to make the surface flat for the side pod thing to come.
                                        • tuna1957T Offline
                                          tuna1957
                                          Looks like good progress πŸ‘
                                          • Bryan KB Offline
                                            Overview time again!
                                            • 4 / 10
