    The Nadesico A
    194 Posts 10 Posters 78.5k Views 10 Watching
    • Bryan KB Offline
      Aft indentation created. Will add the weird vent/fin/grill things next.
      • Bryan KB Offline
        Top rear grill thing complete. Made as a separate component, one side only, then duplicated. I'll stop here and double check my proportions. I already see the lower hull is too wide at same location as the top grills.
        • Bryan KB Offline
          Back to this in a few days. Doing some brain salad surgery on my laptop. Much needed maintenance.
          • Bryan KB Offline
            Rear grill things completed.
            • Bryan KB Offline
              Forward nacelle struts cleaned up. Intersected main hull and then deleted excess lines that were inside the main hull and filled in the faces. It's not "perfect", but upper and lower pods will hide most of the details later. But is IS flush with the hull now.
              • Bryan KB Offline
                Progress to date.
                • tuna1957T Offline
                  tuna1957
                  Great progress πŸ‘ Looking forward to seeing it in a render.
                  • Bryan KB Offline
                    Thanks tuna. πŸ‘
                    • Bryan KB Offline
                      Go sidetracked on the artist studio render. But I learned a lot from it!
                      Let's see, what part to model next? The rear engines I think...
                      • Bryan KB Offline
                        First rough block of the rear engines.
                        Same technique as before. One component, replicated 4 times for each pod. I'll add the missing gap sections after I finalize the main pods.
                        Now for the fiddling... first I'll get the outlines and mass shaped up.
                        • Bryan KB Offline
                          Thanks tuna. Thanks L i am. πŸ‘
                          • Bryan KB Offline
                            2 more views.
                            • Bryan KB Offline
                              Rear engines shaping up somewhat.
                              Just a reminder that everything to date is still just blocking out. Even the front nacelles. I just did a little extra on those to give me an idea of what I need to do once the blocking was done, but even they need more attention. Once the mass shapes are good, I will go back and smooth everything out with more faces. So there are many more stages to go after the block-outs are done.
                              Months I tell you! πŸ˜†
                              • Bryan KB Offline
                                Forgot to mention I will be using Curviloft for final cleanup and smoothing.
                                I will be sure to show how I use it. I've already tested it and it's going to work beautifully.
                                But I have to finish the block-out shapes first. So it will be some time before I get to that stage.
                                  πŸ‘
                                  Want one. Hasda be would never be the same but, I could live with that very easily....... 🀣
                                  • Bryan KB Offline
                                    @mike amos said:
                                    :thumb:
                                    πŸ‘ πŸ‘
                                    • tuna1957T Offline
                                      tuna1957
                                      Excellent progress πŸ‘ Funny side note…. when I see the title of your post my brain says Nabisco and I start looking for the cookies πŸ˜†
                                      • Bryan KB Offline
                                        Thanks tuna!
                                        LOL, yeah I had the same problem when I started watching the show. πŸ˜†
                                        More engine pod updates.
                                        • Bryan KB Offline
                                          Correctly positioned the engine pods. Made basic pod struts as component, then used strut for equal placement.
                                          • Bryan KB Offline
                                            Geometry clean up to make the surface flat for the side pod thing to come.
                                            • 4 / 10
