    The Nadesico A
    194 Posts 10 Posters 52.5k Views 10 Watching
    • tuna1957T Offline
      tuna1957
      Waiting patiently for the big finish πŸ‘
      • Bryan KB Offline
        Thanks tuna!
        Almost ready to commit on upper decks.
        • Bryan KB Offline
          Overview to date. YAY! It's halfway finished!
          Did I mention the remaining detailing? Yeah, that's the other half.
          • Bryan KB Offline
            The overall shape of the upper decks is now good. Committing to detailing. There will still be some fiddling with the overall shape as I add details, but the general shape is now good.
            There are still 4 more sections to create. The two mecha hangers on top of the forward pylon struts and the two landing pods underneath the forward pylon struts. Both of which will be an individual section, made into components, then copied and flipped.
            THEN the final detailing. But first, rough in the details of the upper decks.
            • Bryan KB Offline
              Oops, the bridge was to big. Way too big. Fixed. Simple scale down.
              • Bryan KB Offline
                Taking a break and re-watching the series again for more insight to the upper decks and future detailing.
                The rear of the upper decks is still not quite right. No major changes required, but certainly more tweaking of proportions is needed.
                Now that I have gotten this far, I see from the anime that everything so far is spot on with only tiny variations in the details, which is also not consistent from episode to episode. So no problems there.
                The final detailing though... holy moly. Yeah, months to go yet.
                • L Online
                  Hi Bryan, The time you are spending on that reflects your level of integrity. I happened to get hold of a 3D model of that craft and it does not hold a candle to your, as yet, unfinished model πŸ‘ πŸ˜‰
                  • Bryan KB Offline
                    Thanks L i am! πŸ‘
                    • Bryan KB Offline
                      Once again, impossible geometry for the rear upper decks. This is going to take a while.
                      • tuna1957T Offline
                        tuna1957
                        Stick with it. You’ll get there. πŸ‘
                        • Bryan KB Offline
                          Thanks tuna. πŸ‘
                            He is right of course mate. Just ignore the pressure of being the resident spaceship constructor on on you go bit by bit. Better than the telle(Vision). πŸ‘
                            • Bryan KB Offline
                              Here are the miles of hidden geometry. I had to force so many angles to make this thing work, plus Fredo's Tools on Surface, Curviloft and Joint Push/Pull.
                              Plus a lot of intersecting shapes to get the shape I wanted and then stray line clean up. This is why I waited to use any smoothing until I was absolutely sure of each shape.
                              A crazy, insane design of a spaceship. The artists were off their rockers! But damn it looks good!
                              • Bryan KB Offline
                                Thanks Mike. πŸ‘
                                Resident spaceship constructor. You know, I've not noticed there haven't been a lot of spaceships shown here in recent times. That's kind of odd. Hmmm.
                                OK. I think I've got the shape right and I'm going for it. Could not have done this without Fredo's Joint Push/Pull and Tools on Surface. Yes, the outboard rear pods really do look like that. I've spent hours now looking at the videos and not even the animators knew how to make the shape flow in that area. Yet, that's how it works. The geometry says it can only work that way.
                                Starting to really shape up now. Lots of Erase+CTRL clean up as I become sure of the shapes. Next, rebuild the rear upper deck pod things in the middle.
                                • Bryan KB Offline
                                  LOL! Crap. The rear upper deck outboard pods are still not "quite" right.
                                  Damn close though. Easy fix. (yeah, I say that now...)
                                  • Bryan KB Offline
                                    Better. Also added more detailing to upper decks.
                                    • Bryan KB Offline
                                      Tweaked the outboard rear upper deck pods some more. I think that's about it for the pods.
                                      Now to start on the middle pod things.
                                      • Bryan KB Offline
                                        Annnnd this is the point where I start muttering to myself and giggling at nothing as I slide into madness.
                                        The upper deck outboard pods ARE STILL NOT RIGHT! I now can see what's wrong with them and it's going to need a complete rebuild of that section. The final result will give me much cleaner geometry, but damn, why couldn't I see this earlier? Oh I remember. No consistency in the drawings.
                                        Back to the drawing board! πŸ˜› 😐 πŸ˜†
                                          You are moving forwards mate. Lovin' it tbh. πŸ‘
                                          • Bryan KB Offline
                                            Thanks Mike.
                                            OK, almost got it. Just little more line clean up.
                                            • 7 / 10
