    The Nadesico A
    194 Posts 10 Posters 84.9k Views 10 Watching
    • Bryan KB
      Thanks L i am! πŸ‘
      • Bryan KB
        Once again, impossible geometry for the rear upper decks. This is going to take a while.
        • tuna1957T
          tuna1957
          Stick with it. You’ll get there. πŸ‘
          • Bryan KB
            Thanks tuna. πŸ‘
              He is right of course mate. Just ignore the pressure of being the resident spaceship constructor on on you go bit by bit. Better than the telle(Vision). πŸ‘
              • Bryan KB
                Here are the miles of hidden geometry. I had to force so many angles to make this thing work, plus Fredo's Tools on Surface, Curviloft and Joint Push/Pull.
                Plus a lot of intersecting shapes to get the shape I wanted and then stray line clean up. This is why I waited to use any smoothing until I was absolutely sure of each shape.
                A crazy, insane design of a spaceship. The artists were off their rockers! But damn it looks good!
                • Bryan KB
                  Thanks Mike. πŸ‘
                  Resident spaceship constructor. You know, I've not noticed there haven't been a lot of spaceships shown here in recent times. That's kind of odd. Hmmm.
                  OK. I think I've got the shape right and I'm going for it. Could not have done this without Fredo's Joint Push/Pull and Tools on Surface. Yes, the outboard rear pods really do look like that. I've spent hours now looking at the videos and not even the animators knew how to make the shape flow in that area. Yet, that's how it works. The geometry says it can only work that way.
                  Starting to really shape up now. Lots of Erase+CTRL clean up as I become sure of the shapes. Next, rebuild the rear upper deck pod things in the middle.
                  • Bryan KB
                    LOL! Crap. The rear upper deck outboard pods are still not "quite" right.
                    Damn close though. Easy fix. (yeah, I say that now...)
                    • Bryan KB
                      Better. Also added more detailing to upper decks.
                      • Bryan KB
                        Tweaked the outboard rear upper deck pods some more. I think that's about it for the pods.
                        Now to start on the middle pod things.
                        • Bryan KB
                          Annnnd this is the point where I start muttering to myself and giggling at nothing as I slide into madness.
                          The upper deck outboard pods ARE STILL NOT RIGHT! I now can see what's wrong with them and it's going to need a complete rebuild of that section. The final result will give me much cleaner geometry, but damn, why couldn't I see this earlier? Oh I remember. No consistency in the drawings.
                          Back to the drawing board! πŸ˜› 😐 πŸ˜†
                            You are moving forwards mate. Lovin' it tbh. πŸ‘
                            • Bryan KB
                              Thanks Mike.
                              OK, almost got it. Just little more line clean up.
                              • Bryan KB
                                Upper deck, middle, rear, pods shaping up. Lots of Erase+Crtl on the build lines. It took me two hours to figure how to make them. And for some reason, SU was really uncooperative today.*
                                I also narrowed the outboard pods inner cone things a little more. Just selected the two rear faces and scaled.
                                *Ah, a major Windows update was pending. That will do it.
                                  πŸ˜„ πŸ‘
                                  • Bryan KB
                                    Thanks Mike! πŸ‘
                                    • Bryan KB
                                      Very subtle change, but this makes the rear of the upper deck outboard pods point straight back as they should. It also cleaned up a lot of the geometry.
                                      The problem was finding the break in the angle from the sides of the upper deck. Once I saw it, I was able to make the change, but I did not see that break until the other day.
                                      NOW it looks like it is supposed to.
                                      Now, maybe, I can start on those middle pod things. Also added a little more upper deck details.
                                      • Bryan KB
                                        I was going to do more under the top deck, but saw the outer rear pods were off again.
                                        I did manage to add more detail to the upper middle pods after I made the corrections.
                                        • Bryan KB
                                          Overview to date.
                                          • tuna1957T
                                            tuna1957
                                            Epic Bryan. I’d be stabbing my self in the head with an ice pick about now… πŸ˜‰ πŸ‘
                                            • 7 / 10
