    1.5k Posts 477 Posters 4.0m Views 477 Watching
      Even scaled up, the tiny radius on the round overs creates some bad geometry. Make a reasonable radius and it works. I used 10 in.
        jtri
        Dave
        Thanks for you quick reply but I am unable to duplicate your results. Maybe the screen shot can help
        Jeff
        • fredo6F Offline
          It all depends on your geometry.
          As it has been generated by Curviloft, I imagine it is triangulated. Just turn on Hidden Geometry to verify it.
          In that case, I am afraid that RoundCorner will have difficulty to perfrom its task, whatever the scale is. Sorry for that. Another algorithm is needed to handle those cases.
            Did you try with a larger radius? I used 10 in., not 5 in.
            Edit to add: I redrew the shape rather than trying to reconstruct yours. I didn't use Curviloft so I didn't have the triangulation.
              jtri
              Thanks so much for the help!
                riuslyp
                I had some trouble in using this plugin. The object I had rounded seemed like useless afterwards, I could not move nor color it, or anything else since my SU 2013 would crash if I do that. Before rounding, I have set the offset etc to the appropriate value. Could someone advice me what to do? I have also installed the newest LibFred
                  Can you share an example?
                  What is your graphics card? Are it's drivers up to date?
                    riuslyp
                    I use AMD A8-7410 APU with AMD Radeon R5 Graphics, 2200 Mhz, 4 Core(s), and yes, my graphic card is up to date.
                    I was just trying to round a cube and I wanted to move it, but my SU then suddenly crashed. I had also tried to uncheck the 'hardware accelerator' but for no use.
                    • fredo6F Offline
                      Are you really running SU2013 (as your profile indicates)?
                      • V Offline
                        VancoD
                        Thanks for the plug-in Fredo. It seems to do a fine job.
                        My issue is not in getting the tool to work - my issue is what is happening you my shape after the round-over.
                        What I'm working on is not a complex shape - it's essentially a rectangle 15x100x455 mm. The top face has a radius of 254mm into it. It's a long box with a grove in it 😄
                        My issue is that after I round all my edges the "entities" in SketchUp are basically lost. I now have an amorphous rectangle shape and I've lost all the "dimensional attributes" to all the elements/faces - I cannot submit this to a manufacturer for production with the dimensional data visible as I'd like to.
                        I am arguably very new to SketchUp - have I missed something obvious here - perhaps some sort of layering or overlay where I can apply the round-over and still have all the "square" reference data in place?
                        EDIT:
                        Well - I can use the dimensions tool to indicate the dimensions, and that's technically "good enough" for my need. But I'm still curious to know if there's a way to keep that entity data in place.....
                          How about sharing the SKP file so we can see exactly what you've got and give you some guidance?
                          • fredo6F Offline
                            That's not a problem with the plugin. If you were doing the rounding manually, you would have the same problem. You need to modify the faces affected by the rounding and create new facets.
                            So, it's more the sequence in your workflow. Do the rounding first (and other editing tasks) and then put the decoration (dimensions, textures, ...)
                            • 9 Offline
                              99hash
                              Hi Fredo,
                              Absolutely amazing plugin, I am new to Sketchup and am busy playing with some designs to see if it is worth buying a 3d printer, no point in getting a printer if I cannot create designs to print. This plugin works perfectly for external corners but I cannot seem to get this to work on internal shapes. For example I have cube with a hole through it and would like the edge of the hole rounded. When I use this tool it just erases the hole completely. Is this normal behavior or am I being stupid?
                              Thank you for all this work you have put in your tool
                              Nick
                              • fredo6F Offline
                                @99hash said:
                                Hi Fredo,
                                Nick
                                This is a small inconvenience in the current version.
                                Just select the face occulting the hole and erase it. It should reveals the rounding of the hole.
                                  Steuart
                                  often when I use Round Corner it crashes Sketchup. If I am working and then click on round corner it almost always crashes. Then when I re-open SU and try using Round Corner it works fine. I have the same problem in SU17 and SU18. I am using a mac on the latest MacOS. (it has been happening for a long time in various versions of MacOS) Any solution to this? The only solution i have found is to close SU and reopen it, which is very frustrating if I am doing a lot of Round Corner. Thanks
                                  • fredo6F Offline
                                    Actually, first time I hear about these crashes from users, and also that this has happened before.
                                    I would suggest you give the list of the other plugins you run in your environment, as some are known to be in conflict with RoundCorner (and other plugins).
                                      Steuart
                                      Hi Fredo, Thanks for fast reply. I have: Advanced Camera Tools, Dynamic Components, Sandbox, Trimble Connect (no idea what any of those do), plus your LibFredo6, Curviloft (looks great - only downloaded it yesterday, not tried it out yet), Round Corner. I used to have pipe along, which I think caused similar issues, but have not installed that in SU18. I am running the latest version of everything and Mac OS10.13.3 on a 2013 MacBook pro retina. (new iMac arriving tomorrow)
                                        Steuart
                                        @99hash said:
                                        Hi Fredo,
                                        Nick
                                        Hi Nick, I have printed a number of things from sketchup drawings and it works very well. Good luck! (and I am far from being an expert!!) Steuart
                                          Steuart
                                          Hi Fredo, (sorry - did not reply directly to your first reply - just learning the system) Thanks for fast reply. I have: Advanced Camera Tools, Dynamic Components, Sandbox, Trimble Connect (no idea what any of those do), plus your LibFredo6, Curviloft (looks great - only downloaded it yesterday, not tried it out yet), Round Corner. I used to have pipe along, which I think caused similar issues, but have not installed that in SU18. I am running the latest version of everything and Mac OS10.13.3 on a 2013 MacBook pro retina.
                                          (love the plugin by the way!)
                                          Steuart
                                          • fredo6F Offline
                                            Steuart,
                                            I suggest you install the latest version of LibFredo6 (v8.1d) and tell me if you get crashes any longer. I fixed some problems of random bugsplats for Curviloft, and it might well be the same origin as for RoundCorner.
                                            By curiosity,
                                            1. do you have Souvenir also installed?
                                            2. Does the crash happens when you launch RoundCorner right after you save the model
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 65
                                            • 74
                                            • 75
                                            • 63 / 75
