    SketchUcation 4.2... causing right click hangup
    extensions
    13 Posts 4 Posters 4.4k Views 4 Watching
      First report of this...
      There's nothing in the SketchUcation tools themselves that uses 'RightClick', and even it it did it'd only happen if one of its tools was open...
      Very few extensions' tools invoke RightClick...
      The only possible culprit could be the changes to the SCF Licensing which is in RBE, so I can't check that... so with the SCF License extension disabled do you still get this issue ??
      Have you remapped any mouse-clicking etc on your MAC ?
      Perhaps Fredo can comment...
        dave p
        @TIG - Thanks for the reply. When I disable the SketchUcation plugin, the issue disappears. Just to clarify, this occurs when context clicking with the right mouse button. I'm not using a 3D mouse either. Everything on my mouse is default mapping.
        Double checked that all the other plugins are up to date and they are.
        The only way to get out of Sketchup once this happens is to force quit the app through Finder or Activity Monitor.
          Am I right in assuming that you do not have any of the SketchUcation tools / dialogs running when you right-click ?
          As I said previously, only the encrypted RBE SCF-licensing code might contain any right-click elements.
          Fredo [who's the author] can cover this better...
          If you disable the SCF-licensing extension [which the EM lists as separate from SketchUcation tools] and restart SketchUp is this weird the issue still there ??
          • fredo6F Offline
            SCFLicense has no interference with the Right-click in Sketchup.
            What is exactly the symptom?
            In which context does the right-click works and does not work?
              dave p
              Here's how I'm getting the issue, same result with SU2022.
              Open either version (21,22) context click on empty screen and menu shows up.
              Draw anything (line, rectangle, circle ect.) and try and context click on it and no menu appears and a beachball hang for Sketchup.
              This vid shows the blank screen working but not the rectangle. Green circles around the cursor are context clicks causing and after the freeze.
              SketchUcation 4.2.3 Freeze.mov
                If you open the Ruby Console before doing any of this, is anything printed ?
                  dave p
                  @TIG It's empty.
                    dave p
                    Another update on this issue...
                    I downloaded the latest updates to the plugin store and @Fredo's plugins from the weekend. Still caused the same crash.
                    Decided to do another process of elimination run on my installed plugins and traced it to Clothworks. It had been working fine prior so I ignored it when I checked previously. But that seems to be the culprit. I'll give Anton an email and see if he can offer any guidance on fixing it.
                      dave p
                      Situation update for anyone interested. Anton of Clothworks was able to replicate the same issue I am experiencing on his mac running OS X 10.13.6 with SU2021. His M1 machine running SU2022 didn't suffer the same hangup. He's messaged the sketchUcation team to look at a potential licensing issue.
                      Additionally for me all the the newly licensed Fredo plugins except FredoCorner have stopped working. This is the message I get in the Ruby Console when I select any of the FredoCorner tools.
                      Error: #<LoadError: dlopen(/Users/davidpinter/Library/Application Support/SketchUp 2022/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_27/SUEX_SCFLibrary.bundle, 9): no suitable image found. Did find:
                      /Users/davidpinter/Library/Application Support/SketchUp 2022/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_27/SUEX_SCFLibrary.bundle: cannot load 'SUEX_SCFLibrary.bundle' (load command 0x80000034 is unknown)
                      /Users/davidpinter/Library/Application Support/SketchUp 2022/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_27/SUEX_SCFLibrary.bundle: cannot load 'SUEX_SCFLibrary.bundle' (load command 0x80000034 is unknown) - /Users/davidpinter/Library/Application Support/SketchUp 2022/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_27/SUEX_SCFLibrary.bundle>
                      /Applications/SketchUp 2022/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.7.1/lib/ruby/2.7.0/rubygems/core_ext/kernel_require.rb:92:in require' /Applications/SketchUp 2022/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.7.1/lib/ruby/2.7.0/rubygems/core_ext/kernel_require.rb:92:in require'
                      /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe:156:in load_binary' /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe:71:in dynamic_token'
                      /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1741:in tem_context' /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:751:in activate'
                      /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:194:in select_tool' /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:194:in launch'
                      /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:176:in action__mapping' /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:142:in call'
                      /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:142:in launch_action' /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:244:in launch_action'
                      /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_fredocorner/bootstrap_fredocorner.rbe:103:in launch_action' /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_fredocorner/bootstrap_fredocorner.rbe:118:in block in startup'
                      /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1460:in command_invoke' /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1441:in block (2 levels) in build_config_commands'
                      /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1378:in block in add_command' Error: #<LoadError: dlopen(/Users/davidpinter/Library/Application Support/SketchUp 2022/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_27/SUEX_SCFLibrary.bundle, 9): no suitable image found. Did find: /Users/davidpinter/Library/Application Support/SketchUp 2022/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_27/SUEX_SCFLibrary.bundle: cannot load 'SUEX_SCFLibrary.bundle' (load command 0x80000034 is unknown) /Users/davidpinter/Library/Application Support/SketchUp 2022/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_27/SUEX_SCFLibrary.bundle: cannot load 'SUEX_SCFLibrary.bundle' (load command 0x80000034 is unknown) - /Users/davidpinter/Library/Application Support/SketchUp 2022/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_27/SUEX_SCFLibrary.bundle> /Applications/SketchUp 2022/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.7.1/lib/ruby/2.7.0/rubygems/core_ext/kernel_require.rb:92:in require'
                      /Applications/SketchUp 2022/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.7.1/lib/ruby/2.7.0/rubygems/core_ext/kernel_require.rb:92:in require' /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe:156:in load_binary'
                      /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe:71:in dynamic_token' /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1741:in tem_context'
                      /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1709:in tem_launcher' /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:119:in launch_action'
                      /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:244:in launch_action' /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe:87:in launch_action'
                      /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe:135:in block in declare_command' /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1460:in command_invoke'
                      /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1441:in block (2 levels) in build_config_commands' /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1378:in block in add_command'
                      /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1741:in tem_context' /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1709:in tem_launcher'
                      /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:119:in launch_action' /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:244:in launch_action'
                      /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe:87:in launch_action' /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe:135:in block in declare_command'
                      /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:76:in launch_action' /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:91:in block in startup'
                      /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:244:in launch_action' /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:76:in launch_action'
                      /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:92:in block in startup' /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1460:in command_invoke'
                      /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:76:in launch_action' /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:93:in block in startup'
                      /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:93:in block in startup' /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1460:in command_invoke'
                      /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:76:in launch_action' /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:92:in block in startup'
                      /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:91:in block in startup' /users/davidpinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1460:in command_invoke'
                      • fredo6F Offline
                        Very likely, there is an incompatibility of Sketchucation ExtensionStore when you have both
                        • MacOS 10.13 (or even 10.14.6 Mojave)
                        • and SU2021 or SU2022
                        We are looking into the problem.
                          ramohn
                          Hello All,
                          I need assistance as I can't log into ExtensionStore v4.2.4 (inside Sketchup) to authenticate the FredoScale I recently purchased.
                          I use MacOs 10.14 and Sketchup 2017 Make.
                          I beg anyone could help me with my issue or I'll request refund of plugin purchased recently
                          Thanking you in advance.
                          Ramon Asensi
                            Please install the newer v4.2.5, and restart SketchUp - this might help...
