    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    439 Posts 152 Posters 548.1k Views 150 Watching
    • N Offline
      noldo
      @fredo6 said:
      @noldo said:
      Hi Fredo, the plug-in fail with this geometry type.
      Roundcorner work correctly.
      It looks like there is a problem in the model.
      One of the face is actually spreading over 3 blocks
      [attachment=1:3klx88xg]<!-- ia1 -->Multi faces Corner.png<!-- ia1 -->[/attachment:3klx88xg]
      This creates an issue with FredoCorner, as you can imagine.
      [attachment=0:3klx88xg]<!-- ia0 -->Noldo - Corner - Untitled.skp<!-- ia0 -->[/attachment:3klx88xg]
      I'll try to detect this type of configuration in a next version.
      Thank's for your work Fredo!
        cskovago
        I have just updated to the latest version, because the plugin refused to work as the 1.6 version. Now, it is NON-WORKING order, I can not even copy the bug report (because the cursor turns semi-transparent on the bug-report tab), I can select the faces, edges, I can set the parameters, the plugin calculates the edges, but when I let it done the task, nothing happens, just the bug-report tab is red...
        Any idea or help, please?
        Win7, SketchUp 2017 latest
        • fredo6F Offline
          @cskovago said:
          In this kind of situation, it would be helpful to attach the model. Otherwise, this is difficult to find out.
          If you have the red notification, then there is an error. So, open the Ruby console before launching FredoCorner and check if there are errors displayed. That would also help.
            ronagoldberg
            Thank you so much for this plugin and the previous version.
            I was using it today and got this odd geometry, it only happened on this side, the other side of this box laid out correctly. I realize it would run into the hole in the geometry but I was surprised at what it was doing and that it wasn't doing the same thing on both sides.
            Ron
            • fredo6F Offline
              Strange! Could you post the model so that I have a close look.
              • fredo6F Offline
                NEW RELEASE: FredoCorner v1.6c - 20 Jun 19
                Requirement: LibFredo6 8.8a
                FredoCorner 1.6c extends validity.
                Please note that, in the current version of FredoCorner:
                • there are issues with some shortcut modifiers (Ctrl, Alt) on Mac)
                • there are known issues and bugs here and there. This concerns in particular Collisions, i.e. when the offset is too large.
                • Terminal corners (that is ending on a single edge) may present issues and bugs
                • No documentation yet, so watch the videos that I will publish.
                Please report issues, questions and any feedback in the present thread
                Home Page of FredoCorner for information and Download.
                Main post of this FredoCorner thread.
                  MWH
                  Hi, Fredo corner stopped working. It says "no good edges at face"or "NO match of edge properties) even with a new drawing and a simple box.
                  I have reinstalled Fredo Corner v 1.6c and LibFredo6 ver 9.0A and have rebooted my computer. Still same problem.
                  I“m using Sketchup 8 Pro on Mac OSX Mojave (10.14.5).
                  Any tips?
                  Mattias
                    Your profile indicates you are using SketchUp 2018. Which one is correct?
                    • fredo6F Offline
                      This may simply be normal. You have a filter to select edges
                      Depending on the filter and what you select, FredoCorner may find that there is no effective edges.
                      So make sure that the edges you select and the filter do match.
                        MWH
                        Thanks Fredo:)
                        It was that simple. Unbelievable that I missed that.
                        Dave R, you're right. I'm using 2018.
                        Thanks again!
                        M
                        • deaneauD Offline
                          deaneau
                          Hi Fredo Round Corner have some errors
                          this is a corner with 8 segments and 1mm radius
                          skp 2019
                          https://1drv.ms/u/s!AoU3tpJxqmvto3skG47ckoAVXMeP?e=nu42nx
                          skp2013
                          https://1drv.ms/u/s!AoU3tpJxqmvto3z6vD80Gvsyv0Vc?e=eIjFlT
                          https://i.ibb.co/KXbNynr/2019-08-19-12h11-28.png
                          • FrederikF Offline
                            Frederik
                            Looking at the various errors you've posted recently, I assume that it's more a limitation of SU rather than a bug in the various plugins...
                            What usually helps is if you scale the model up - i.e. 10 times so one millimetre becomes one centimetre...
                            And once the plugins have made the job for you, you scale it down to the original size...
                            The detail you seem to want to accomplish is not something SU is good at...
                            Cheers
                            Kim Frederik
                            • PixeroP Offline
                              Pixero
                              I usually make it a component then copy the component and scale it up 10-1000 times and make the tiny stuff on that copy. When done I just delete the copy and the original component is done.
                              • fredo6F Offline
                                NEW RELEASE: FredoCorner v1.7a - 20 Sep 19
                                Requirement: LibFredo6 9.1b
                                FredoCorner 1.7a extends validity.
                                  mrkidd
                                  I am not able to get this to load in SU 2019...error message every time.
                                    What's the error message?
                                    Did you install the current version of LibFredo6 which is required by FredoCorner? See Fredo's post immediately before yours.
                                    • fredo6F Offline
                                      NEW RELEASE: FredoCorner v1.7b - 02 Nov 19
                                      FredoCorner 1.7b for bug fixing.
                                        What was the exact error message? Did you also install the required LibFredo6 files?
                                          gmintz1
                                          I was excited to use this plugin but after installing and restarting sketchup I got an error message stating there was an error loading, could not find loader file. Help!
                                          Yes, I installed the "lib" file.
                                          Error message:
                                          Error Loading File Fredo6_FredoCorner/__loader__FredoCorner
                                          Could not find included file 'Fredo6_FredoCorner/__loader__FredoCorner'
                                          • fredo6F Offline
                                            NEW RELEASE: FredoCorner v1.7c - 21 Dec 19
                                            FredoCorner 1.7c for extenson of validity.
                                            • 21
                                            • 22
                                            • 8 / 22
