    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 731.8k Views 151 Watching
    • fredo6F
      @ronagoldberg said:
      I was using it today and got this odd geometry, it only happened on this side, the other side of this box laid out correctly. I realize it would run into the hole in the geometry but I was surprised at what it was doing and that it wasn't doing the same thing on both sides.
      Strange! Could you post the model so that I have a close look.
      • fredo6F
        NEW RELEASE: FredoCorner v1.6c - 20 Jun 19
        Requirement: LibFredo6 8.8a
        FredoCorner 1.6c extends validity.
        Please note that, in the current version of FredoCorner:
        • there are issues with some shortcut modifiers (Ctrl, Alt) on Mac)
        • there are known issues and bugs here and there. This concerns in particular Collisions, i.e. when the offset is too large.
        • Terminal corners (that is ending on a single edge) may present issues and bugs
        • No documentation yet, so watch the videos that I will publish.
        Please report issues, questions and any feedback in the present thread
        Home Page of FredoCorner for information and Download.
        Main post of this FredoCorner thread.
          MWH
          Hi, Fredo corner stopped working. It says "no good edges at face"or "NO match of edge properties) even with a new drawing and a simple box.
          I have reinstalled Fredo Corner v 1.6c and LibFredo6 ver 9.0A and have rebooted my computer. Still same problem.
          I´m using Sketchup 8 Pro on Mac OSX Mojave (10.14.5).
          Any tips?
          Mattias
            Your profile indicates you are using SketchUp 2018. Which one is correct?
            • fredo6F
              This may simply be normal. You have a filter to select edges
              Depending on the filter and what you select, FredoCorner may find that there is no effective edges.
              So make sure that the edges you select and the filter do match.
                MWH
                Thanks Fredo:)
                It was that simple. Unbelievable that I missed that.
                Dave R, you're right. I'm using 2018.
                Thanks again!
                M
                • deaneauD
                  deaneau
                  Hi Fredo Round Corner have some errors
                  this is a corner with 8 segments and 1mm radius
                  skp 2019
                  https://1drv.ms/u/s!AoU3tpJxqmvto3skG47ckoAVXMeP?e=nu42nx
                  skp2013
                  https://1drv.ms/u/s!AoU3tpJxqmvto3z6vD80Gvsyv0Vc?e=eIjFlT
                  https://i.ibb.co/KXbNynr/2019-08-19-12h11-28.png
                  • FrederikF
                    Frederik
                    Looking at the various errors you've posted recently, I assume that it's more a limitation of SU rather than a bug in the various plugins...
                    What usually helps is if you scale the model up - i.e. 10 times so one millimetre becomes one centimetre...
                    And once the plugins have made the job for you, you scale it down to the original size...
                    The detail you seem to want to accomplish is not something SU is good at...
                    Cheers
                    Kim Frederik
                    • PixeroP
                      Pixero
                      I usually make it a component then copy the component and scale it up 10-1000 times and make the tiny stuff on that copy. When done I just delete the copy and the original component is done.
                      • fredo6F
                        NEW RELEASE: FredoCorner v1.7a - 20 Sep 19
                        Requirement: LibFredo6 9.1b
                        FredoCorner 1.7a extends validity.
                          mrkidd
                          I am not able to get this to load in SU 2019...error message every time.
                            What's the error message?
                            Did you install the current version of LibFredo6 which is required by FredoCorner? See Fredo's post immediately before yours.
                            • fredo6F
                              NEW RELEASE: FredoCorner v1.7b - 02 Nov 19
                              FredoCorner 1.7b for bug fixing.
                                What was the exact error message? Did you also install the required LibFredo6 files?
                                • G
                                  gmintz1
                                  I was excited to use this plugin but after installing and restarting sketchup I got an error message stating there was an error loading, could not find loader file. Help!
                                  Yes, I installed the "lib" file.
                                  Error message:
                                  Error Loading File Fredo6_FredoCorner/__loader__FredoCorner
                                  Could not find included file 'Fredo6_FredoCorner/__loader__FredoCorner'
                                  • fredo6F
                                    NEW RELEASE: FredoCorner v1.7c - 21 Dec 19
                                    FredoCorner 1.7c for extenson of validity.
                                    • N
                                      nlipovac
                                      Hi Fredo,
                                      I get this message when using bevel (same for Round) when selecting three edges.
                                      Is this tool limit so it just can´t do or I am doing something wrong here?
                                      Also,
                                      Thank You very much for all the plugins you have created and made my work easier doing so.
                                      This is that part.
                                      Selecting two edges is fine but the third one gets me this message.
                                      • fredo6F
                                        This seems to be a limitation of FredoCorner. I can reproduce it on my computer.
                                        The message is not informative, because, when there is a problem in the geometry, FredoCorner assumes that it could come from an offset which is too large. I know where the error happens, but this seems to be an issue in the heart of the algorithm, which is quite complex for this type of geometry. So I put your model in the stack of models I have already for when I'll dig into FredoCorner deep core to see how to make it more robust.
                                        At a first glance, I am scratching my head on what could be the correct result with a selection of only 3 edges at this 6-edge corner, convex / concave.
                                        It works fine however if you select the 6 edges.
                                          mikedub
                                          HI, today I just installed latest FredoCorner 1.7c and the Library 9.5c (Fredo6_!LibFredo6) folder and ruby files in the proper location – User > Library > Application Support > SketchUp > Plugins.
                                          The Extension Manager says they are installed and active. And I see it in the Sketchup menu. But (after making a cube and selecting it, to test) when I click on the FredoCorner menu icon, or choose it from the menu, nothing happens. The FredoCorner menu does not come up at all.
                                          I tried uninstalling and reinstalling the plugins, quitting and restarting Sketchup a few times. Still nothing.
                                          Please help!
                                          Cheers,
                                          Mike
                                          • fredo6F
                                            Could you open the Ruby console to see if there are errors displayed.
                                            • 22
                                            • 23
                                            • 8 / 23
