    [Plugin] LordOfTheToolbars - v2.9c - 20 Dec 24
    481 Posts 92 Posters 356.1k Views 91 Watching
    • fredo6F Offline
      @cmeed said:
      I've attached a little video of my problem with Palette line breaks, copying of icons and deleting them
      I'd guess this is not expected behaviour? or Have i go this completely wrong....
      All I'm trying to do is create a few rows of plugins, I also am attempting to move them about to suit my needs.
      The problems when inserting and deleting icons and line-breaks should be fixed in LOTT v1.8a.
      • fredo6F Offline
        @aismebel said:
        With "LordOfTheToolbars" I'm having trouble loading the tabs I've created.
        These problems started after my SU crashed. Resetting the settings and reinstalling the plugin can not solve the problem (((
        Loading tabs starts only after clicking on any icon of the LordOfTheToolbars plugin.
        Very inconvenient (Icons constantly fly off from the places where I installed them (
        Could you first confirm which SU version you have (SU2018?).
        Then be more precise on the problem. And could you keep the Ruby console opened when dealing with LOTT, in case there are some error messages displayed.
        I would also recommend that you upgrade to LOTT V1.8a just published.
          AISmebel
          Hey Freddo. First I want to thank you for your work, your extensions are very helpful.
          https://youtu.be/EWKnFRXS1NE
            AISmebel
            Now I use SU 2020. The plugin version is the latest and I update it regularly as soon as a new version appears.
            Reinstalling the plugin didn't help.
            • fredo6F Offline
              If you do not see the Vignette Stripe at start up, it maybe be stuck off-screen (I guess you have multiple monitors).
              Could you go to the menu Tools > Fredo6 Collection > LordOfTheToolbars > Reset the Vignette Stripe position.
                AISmebel
                I made a screen recording with another program.
                https://youtu.be/e6jSXIc9Dvo
                Reset the Vignette Stripe position did not help me 😞
                • fredo6F Offline
                  Could you display the Vignette Stripe? (go to menu Tools > Fredo6 Collection > LordOfTheToolbars > Toggle Visibility of the Vignette Stripe)
                    AISmebel
                    Hello. The plugin itself works correctly. It just doesn't load icons.
                    Yesterday I installed SketchUp 2022. I installed fresh LordOfTheToolbars for it. Problem still exists. So it's not in the plugin itself and not in SU. Maybe the problem is on my PC. Could this happen?
                    • fredo6F Offline
                      You seem to have 2 problems
                      1. The Vignette Stripe does not display
                      2. The custom toolbars are not showing at startup, but later on
                      I don't have an explanation for that. I will probably need to send you a special version with traces to find out what is the problem.
                      In the meantime, could you
                      • Open the Ruby console
                      • Close Sketchup with the Ruby console opened
                      • restart Sketchup
                      • Check if some errors appear in the Ruby console
                        AISmebel
                        1. The custom toolbars are not showing at startup, but later on
                        • restart Sketchup
                        "Add help menu!"
                        "create new"
                        "created"
                        #Sketchup::Menu:0x0000023c232015f0
                        This inscription appeared a minute after the launch of SU. And after I opened the console on my own.
                        Ruby console didn't open automatically!
                        • fredo6F Offline
                          Is this something happening only in SU2022.?
                            AISmebel
                            The problem first appeared on SU 2020. A week later I installed SU 2022. And migrated all the plugins to SU 2022, uninstalled LordOfTheToolbars and reinstalled it with the latest version of the plugin. SU 2022 and SU 2020 have the same problem.
                            • fredo6F Offline
                              @AISmebel
                              I sent you a modified version of LOTT by Private message. This version includes traces at startup, so that I can find out what is going on.
                                rv1974
                                Somehow I completely missed πŸ˜„ the the feature of custom toolbars (I thought the palettes were the only option for icons).. Anyway I built a custom toolbar of 50 icons and experienced very long loading times (approx 1+ sec for icon) - so it took 1 minute to load this toolbar.
                                Palettes loading times are much better.
                                  AISmebel
                                  You're right. Long loading panels are a little annoying)))
                                  But this version of the panels suits me better.
                                  • fredo6F Offline
                                    This is a known problem in Sketchup, which has already been logged to Trimble. Displaying a custom toolbar outside of the startup sequence takes long on Windows. I have the same issue on my laptop. There is no workaround currently.
                                    • fredo6F Offline
                                      NEW RELEASE: LordOfTheToolbars v1.8d - 02 Feb 22
                                      Requirements
                                      • LibFredo6: v12.4a or above
                                      LordOfTheToolbars 1.8d includes
                                      • Bug fixing for palette and personal commands shortcuts (which could make palette popup when typing in tray dialogs)
                                      Home Page of LordOfTheToolbars for information and Download.
                                      Main post of this LordOfTheToolbars thread.
                                        AISmebel
                                        Hello. Forgive me for torturing you, but in addition to the old error, I found another new error. I can't press the "menu" button. Can't create new icons and can't edit old ones((
                                        Error: #<RangeError: invalid codepoint 0xD83D in UTF-8>
                                        c:/programdata/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:5383:in all_menus' c:/programdata/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:5383:in menu_mapping'
                                        c:/programdata/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:5459:in menu_structured_list' c:/programdata/sketchup/sketchup 2020/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:1056:in menu_compute_list'
                                        c:/programdata/sketchup/sketchup 2020/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:480:in dialog_format_menu_list' c:/programdata/sketchup/sketchup 2020/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:411:in dialog_format_properties'
                                        c:/programdata/sketchup/sketchup 2020/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:329:in dialog_prepare_html' c:/programdata/sketchup/sketchup 2020/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:263:in dialog_load_html'
                                        c:/programdata/sketchup/sketchup 2020/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:181:in dialog_invoke' c:/programdata/sketchup/sketchup 2020/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmanager.rbe:4959:in perso_dialog_invoke'
                                        c:/programdata/sketchup/sketchup 2020/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmasterdialog.rbe:4453:in perso_new_command' c:/programdata/sketchup/sketchup 2020/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmasterdialog.rbe:2465:in dialog_callback_exec'
                                        c:/programdata/sketchup/sketchup 2020/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmasterdialog.rbe:2322:in dialog_callback' c:/programdata/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2385:in call'
                                        c:/programdata/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2385:in master_callback' c:/programdata/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2173:in j_action'
                                        c:/programdata/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2132:in j_callback' c:/programdata/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2118:in block in j_dispatch'
                                        c:/programdata/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2110:in each' c:/programdata/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2110:in j_dispatch'
                                        • fredo6F Offline
                                          This UTF8 error is puzzling.
                                          I don't know if it is related to your Cyrillic environment.
                                          Also, which version of Windows do you run?
                                            AISmebel
                                            After all, there were no problems before (((
                                            Windows 10 Pro v.20H2
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 24
                                            • 25
                                            • 15 / 25
