    [Plugin] LordOfTheToolbars - v4.0a - 22 Sep 26
    527 Posts 101 Posters 587.7k Views 99 Watching
    • fredo6F
      Can you open the Ruby Console before clicking on the LOTT palette. There may be errors displayed.
      • H
        Hypernurd
        I was really excited to add this essential plug-in to my SU installation. Unfortunately, it isn't functioning for me.
        My system :
        • iMac Pro (2017) - 32GB Ram, 3.2Ghz Xeon W
        • macOS Monterey (12.0.1)
        • Sketchup 2021 & 2020
        Problem :
        • Cannot drag and drop icons to custom tool palettes or toolbars.
        Initially I thought this was a SU2021 problem so I reinstalled 2020 but the problem persists. I have done a thorough system clean (Caches, etc) but still the problem persists in both versions of SU.
        Any help or advice would be appreciated.
        BWm,
        Hypernurd
        • fredo6F
          @hypernurd said:
          Problem :
          Could you open the Ruby console to see what is the error. Thanks
          • fredo6F
            NEW RELEASE: LordOfTheToolbars v1.6a - 27 Dec 21
            Requirements
            • LibFredo6: v12.3a or above
            LordOfTheToolbars 1.6a includes
            • Adjustments for future compatibility
            • Bug fixing and visual adjustments
            Home Page of LordOfTheToolbars for information and Download.
            Main post of this LordOfTheToolbars thread.
              rv1974
              Manipulations with large palettes became (so far) much more predictable and stable with latest release. Thank you very much Fredo 👍
              P.S. Could theoretically LOTT show user's shortcuts directly in tool tips and command search?
              • H
                haymaker
                Please help
                I have set up LOTT but the vignette strip is stuck on my laptop screen and will not drag to my 2nd larger screen where I use SU. I can solve this by making the 2nd screen the main screen in windows11 but then SU does not allow me to access the standard menus and SU freezes. I run lot s of pluggins and this is the first time I have had this issue. Having the vignette strip on the laptop screen also means The favourite pallets I have made open on that screen as well and the shortcuts don't work. This make LOTT un useable for me which would be a shame because it looks awesome.
                I would be extremely grateful if you cold help trouble shoot this issue.
                Kind regards
                Mike
                • H
                  haymaker
                  Further to previous post. It is worth noting that the LOTT toolbar is open on the main screen. The favourite, master and shortcut menus open on laptop and can be dragged to main screen but everything else is stuck on the laptop screen. Its like the vignette strip does not recognise the second screen.
                  I am using LOTT V1.6a and LIBfredo6 v12.3a. SU2021 all up to date.
                  • fredo6F
                    It's funny, because other users have complained that the Vignette Stripe does not follow Sketchup when the main SU window is moved to another monitor (hence the changes I made to keep the Vignette Stripe position relative to the Sketchup viewport).
                    I need to think a little bit to see how to accommodate all requirements.
                    • H
                      haymaker
                      Thanks for the prompt response.
                      Would it be possible for me to download an earlier version that would work?
                      Cheers
                      Mike
                        rv1974
                        Talking of moving to 2nd monitor.. I'm so pleased with rosette behavior - it preserves location perfectly and no more disappearings ☀
                        Hope one day palettes will be able to keep their relative location while manipulating SU viewport in precise manner as well.
                        • fredo6F
                          What is the rosette behavior again?
                            rv1974
                            I mean vignette. I got addicted to Stromae's Sante lately Haha
                            • fredo6F
                              Instead, I would suggest that you install LOTT V1.6b, which includes an option for setting or unsetting the stickiness of the Vignette Stripe to the Sketchup window (ON by default, so you would need to disable it in the Default Parameters).
                              • fredo6F
                                NEW RELEASE: LordOfTheToolbars v1.6b - 06 Jan 22
                                Requirements
                                LordOfTheToolbars 1.6b includes
                                • New parameter (in the Default Parameter dialog box) to enable / disable the stickiness of the Vignette Stripe to the Sketchup Window (default is enabled).
                                • H
                                  haymaker
                                  Hey.
                                  Great customer service.
                                  I have updated LOTT to 6b but the problem persists. The vignette strip and the favourite pallets that I have made are stuck on the main laptop screen. I also have the problem that whenever I enter text into a dialogue box then the shortcut keys are activated. For example when I make a component with the name 'nog' as soon as I type O the Edit pallet opens up.
                                  I have disabled all my other extensions but it makes no difference. Could this be an installation error. If delete the LOTT extension and reinstall it will I lose all my pallets and shortcuts.
                                  Thank you for your help so far. I am really looking forward to getting this sorted as your plugin will improve my workflow.
                                  Mike
                                  • fredo6F
                                    Did you disable the stickiness of the Vignette Stripe in the Default Parameters?
                                    For palettes, they are sticky. So I will make an option to release stickiness for them.
                                    Good catch. I will fix that.
                                    • H
                                      haymaker
                                      Error message on install
                                      Hey
                                      I deleted LOTT. I reinstalled it and have attached a screenshot of the error that showed up. I continued with the install and have the same issues. I am not sure if this error has anything to do with the problems I have or not.
                                      Mike
                                      • H
                                        haymaker
                                        Sure did, problem still persists, I can work around it by going into windows display settings and making my external screen the main screen however this seems to cause problems, mainly that if I try and open the Preferences or Model info then SU freezes?? So not really an option..
                                        Cheers
                                        Mike
                                        • fredo6F
                                          Cheers
                                          Mike
                                          I sent you a PM for the multiple issues you have
                                          • fredo6F
                                            NEW RELEASE: LordOfTheToolbars v1.6c - 08 Jan 22
                                            Requirements
                                            LordOfTheToolbars 1.6c includes
                                            • Bug fixing for palette and personal commands shortcuts
                                            • New parameter (in the Default Parameter dialog box) to enable / disable the stickiness of the Palettes to the Sketchup Window (default is enabled).
                                            • 26
                                            • 27
                                            • 7 / 27
