    [Plugin] Selection Toys
    594 Posts 121 Posters 587.6k Views 121 Watching
    • MatheronM
      Matheron
      It would be good if Selection Toys could have the option to use a selection of any containers (components and groups) and convert each into a group:
      Selection Toys
      Instances -> Convert into groups
      Right now, Selection Toys has the ability to convert groups into components. However, sometimes the reverse is needed - to convert all components into groups (or make them individually unique components).
      I have not come across this functionality in any other extension.
      Use case: Several other extensions, e.g. some boolean tools, rely on geometry that is unique for correct operation. For example, when using a large solid volume to subtract from several hundreds of solid components at once, where the resulting intersections may cut each component at different places, some boolean tools will not work well with components. But they do work well with groups, since they are already unique.
      It is a fringe case, but sometimes it is needed and it should be easy to implement.
      • BoxB
        The late great Honoluludesktop has a plugin for this.
        https://sketchucation.com/pluginstore?pln=make_all_unique
        • jujuJ
          juju
          You can also take a look at nz_ConvertMe, not free but won't break the bank either, I've used it and was satisfied.
          • MatheronM
            Matheron
            Thank you for the extension links.
            Even more elegant would be if "convert into groups" would be baked into Selection Toys.
            However, the much more important wish is in my previous post - to make Selection Toys able to filter for solids and nonsolids.
              Semik
              Dear, I have problem with Selection Toys floating toolbar. I lost it when I dragged it to the edge of screen. Now I can use only menu on right mouse button. I tried to remove and reinstall the plugin but I still can't see the toolbar. I use SketchUp 2018 Pro at MacPro with High Sierra. Does anybody has the idea (trick) how to solve this problem?
              • JClementsJ
                JClements
                Do you have dual monitor? If so and you are only using one, then connect to a second monitor and then drag the entire toolbar into the first monitor,
                  Semik
                  Thank you! I did it. I was using a tablet with video cable which was connected to computer. Computer detected the second monitor.
                  • E
                    Einstein
                    Hi!
                    I'd have a couple ideas for selection methods.
                    One would be selecting edges by crease, which is SubD parameter - one could select only creased or non-creased edges or even the ones within certain crease range (0-1), for example: select only edges with crease value from 0.5 to 1. This would significantly improve subdivision modelling workflow.
                    Another is adding "sharp edges" definition next to soft, smooth and hidden edges. I know this is achievable by reversing selection and subtracting faces from selection, but it adds a couple of extra steps. I'd gladly assign hotkey for selecting only sharp edges cuz I do it a lot.
                    Filtering out solid groups/ components would also be a cool feature!
                    • E
                      Einstein
                      "Select (only)/ deselect stray edges" would be very useful too!
                      The definition of a stray edge would be the same as in Clean Up tools.
                      • E
                        Einstein
                        Hello,
                        Is this thread totally dead?
                        I was wondering if there's a chance of implementing my suggestions πŸ˜„
                        • I
                          icpu
                          Bug report for SketchUp 2023
                          Convert Group into components behaves weirdly in SketchUp 2023
                          After converting:
                          Selected Group not immediately change to component in entity info
                          All copy group when selected is not shown in entity info when selected
                          as if there is no object selected, but it is selected in viewport (blue bounding box)
                          It also creates new exactly same item on the first copy ever created,
                          reulting in 2 object exactly the same, the group and the component
                          • I
                            icpu
                            Bug report in SketchUp 2023
                            Convert group behaves weirdly.
                            1. Converted group when converted is not shown in entity info
                            2. All copy of the group, including those are not selected are converted to component
                            3. It creates a duplicate of the group on the first ever copy of the group ever created,
                              resulting in 2 exact looking object but 1st on is a group, the 2nd is a component
                            • designerbursaD
                              designerbursa
                              When I install this plugin "ae_LaunchUp"; I get the console error
                              C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/tt_selection_toys/json.rb:39:in each' C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/tt_selection_toys/ui_manager.rb:280:in build_menus'
                              C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/tt_selection_toys/ui_manager.rb:262:in `block (2 levels) in build_ui'
                              • C
                                carlosmgilp
                                Hello how are you.
                                First, thank you for this great tool and the collaboration for everyone.
                                What is the difference between Border Edges and Selection Border?
                                You could add icons for Border Edges and Selection Border.
                                And so I can add it to the toolbar.
                                I also wanted to ask you, if you can add a new border selection tool with vertices.
                                If you can help me, I would appreciate it with all my heart.
                                Greetings.
                                  roberG66
                                  a little late to the game (by 20 yrs or so) 😊 but that "Selection Toys is ON-POINT!! thanks man!
                                  • akynxsA
                                    akynxs @thomthom
                                    @thomthom said in [Plugin] Selection Toys:
                                    Hello ThomThom,
                                    I would like to report a possible compatibility issue with the Selection Toys plugin when using SketchUp 2026.
                                    After updating to SketchUp 2026, Selection Toys no longer behaves as expected. In my case (and according to other user reports), the plugin causes problems related to the interface and toolbars, such as tools not appearing correctly or toolbar customization not working properly. When Selection Toys is disabled or removed, SketchUp 2026 appears to function normally again.
                                    This issue seems to be related to changes introduced in SketchUp 2026 rather than a specific workflow error, as the plugin works correctly in previous versions.
                                    I wanted to bring this to your attention in case it helps with investigation or future updates.
                                    Thank you very much for your work and for maintaining such an essential extension for the SketchUp community.
                                    My workflow on my college projects is:
                                    Sketchup2022 (Educational) + V-Ray 5 (Educational)
                                    • 26
                                    • 27
                                    • 28
                                    • 29
                                    • 30
                                    • 30 / 30
