    [Plugin][$] FredoGhost - v2.1a - 01 Apr 24
    56 Posts 20 Posters 61.1k Views 20 Watching
    • uwesketchU Offline
      uwesketch
      Hi Fredo
      The plugin is very useful.
      I want to use it for switching between high and low poly components. However there is one thing that prevents me for using it in many models.
      If I do a section cut, then the section cut plane is huge. This is because of the hidden objects you place far away in the FREOO tag.
      Is there a way to prevent this huge section cut plane?
      • fredo6F Offline
        @uwesketch said:
        Hi Fredo
        Would you have a model to show me the problem. I don't understand what you mean by "the hidden objects you place far away in the FREOO tag".
          uwesketch
          Hi Fredo
          below an example print screen.
          The Sketchup model is attached.
          When unhiding the FredoGhost tag, we see, that the plane is that huge, due to the hidden FredoGhost objects.
          Section Cut Plane without any Fredo Ghost defined:
          Section Cut plane without Fredo Ghosts defined
          Section Cut plane with Fredo Ghost proxy defined:
          SectionCut With FredoGhost Proxy defined
          FredoGhost and Section Cut skp model
            uwesketch
            Hi Fredo
            I used the Bounding Box Ghosts in all three modes for a nested component.
            I am using FredoGhost 1.8a on SketchUp 2021 Jan release.
            The original object contains nested components (5 levels). Only the inner most component contains geometry (3 faces). Each components contains 3 sub-components. In total there are 5 components and 120 instances. There are only 81 Faces (3^4) with each 4 edges.
            When generating Bounding Boxes "by grouped object" and "by sub-object", then far too many bounding boxes are created. There are many duplicates (roughly 729 = 3^6).
            See the attached model.
            The mode "by grouped object" created 59094 faces.
            The mode "by sub-object" created 63609 faces.
            Shows duplicated BB objects
            Ghosted with Bounding boxes - too many BB generated
              rv1974
              Fredo, I have constant troubles after it became $$. The Ghost constantly (after short period of time) complains it can't find it the license. I feed it, and in a couple of days it starts again.
              And now, it refuses to start and demands upgrade (though I already upgaraged and restarted SU several times). Suggestions?
              P.S. I have several other commercial ones from you- none of them cause issues
              • fredo6F Offline
                Did you upgrade to Skethucation ExtensionStore v4.1.0?
                There were problems with the previous version.
                  rv1974
                  it didn't help.
                  • fredo6F Offline
                    My fault. I left a check of validity in the code. Nothing to do with the license.
                    Please ugrade to FredoGhost v1.9a. Should solve the issue.
                    And thanks for signaling it.
                      rv1974
                      Many many thanks- it fixed the issue
                      • V Offline
                        VallviFly
                        Buenas tardes, llevo unos días intentando resolver el problema de licencia. la compré, la usé y un dia dejó de funcionar, no se que hacer. ¿pueden ayudarme por favor?
                        Es urgente
                        Gracias
                        URGENTE
                          https://sketchucation.com/forums/viewtopic.php?p=672822#p672822
                          See other thread for reply
                          • V Offline
                            VallviFly
                            Resuelto, muchísimas gracias!!!!
                              rv1974
                              Fredo, would it be possible for ghosts (at least in global-proxy mode) have separate proxy material (based on initial component name) assigned automatically? Example: A component XXX after switching to ghost (a proxy triangular face, default material) would get FredoGhost_XXX material assigned.
                              P.S. the goal is to convert components to triangular faces and export them to other programs (Max) where I can scatter objets one object per one triangular face. The specialty of this workflow is the exporter merges everything into one mesh based on material assignment, one mesh per one material
                              Edit: by mistake I've found workaround! All is needed is to assign some material to upper level of given component - this will paint the proxy (if original proxy is with default material)
                                ThiloKönig
                                Hello!
                                For some time now, Fredo extensions have been telling me to use the latest version of the Sketchucation Extension Store.
                                I do. All Fredo extensions are also running in the latest version.
                                With FredoScale, for example, I close the message and the extension still works.
                                However, Fredo Ghost no longer reacts at all.
                                That is, the hint is displayed, then I press OK and then nothing happens.
                                What can I do?
                                I have reinstalled FredoGhost and done everything possible but it just won't run anymore.
                                I am currently still using SketchUp Pro 2021.
                                Is this a common problem that several users are facing?
                                If so, can it be fixed?
                                Many greetings,
                                Thilo
                                  aiden
                                  I purchased the plugin -
                                  thank you for making it.
                                  I really want to use it on a very large model I am building, but when I click on the Ghost Studio icon, nothing happens.
                                  I now have the same problem with the FredoTools launcher and other launchers you made.
                                  Your thoughts?
                                    pibuz
                                    Hi! I have to report a strange behaviour: fredoghost plugin doesn't work properly, but this seem to be a random behaviour (sometimes it does, sometimes it doesn't) and it doesn't seem to be related to "run as administrator's" permissions.
                                    At launch, in the consolle I get the following error:
                                    Error: #<NoMethodError: undefined method advanced_features?' for nil:NilClass> c:/users/filippo scarso/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredoghost/fredoghosttool.rbe:2622:in top_process'
                                    c:/users/filippo scarso/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredoghost/fredoghosttool.rbe:264:in startup' c:/users/filippo scarso/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredoghost/fredoghosttool.rbe:115:in launch_after'
                                    c:/users/filippo scarso/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredoghost/fredoghosttool.rbe:96:in block in launch' c:/users/filippo scarso/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1807:in block in tem_context'
                                    c:/users/filippo scarso/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1891:in tem_context' c:/users/filippo scarso/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredoghost/fredoghosttool.rbe:96:in launch'
                                    c:/users/filippo scarso/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredoghost/fredoghosttool.rbe:84:in action__mapping' C:/Users/Filippo Scarso/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles/data6.rb:65:in call'
                                    C:/Users/Filippo Scarso/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles/data6.rb:65:in launch_action' c:/users/filippo scarso/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:240:in launch_action'
                                    c:/users/filippo scarso/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredoghost/bootstrap_fredoghost.rbe:97:in launch_action' c:/users/filippo scarso/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredoghost/bootstrap_fredoghost.rbe:233:in block in declare_command'
                                    c:/users/filippo scarso/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1464:in command_invoke' c:/users/filippo scarso/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1444:in block (2 levels) in build_config_commands'
                                    c:/users/filippo scarso/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1385:in `block in add_command'
                                    I'm running the trial version (installed yesterday) on SU2022. Thanks in advance!
                                    WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                                      @pibuz said:
                                      I'm running the trial version (installed yesterday) on SU2022, sketchucation plugin 4.2.3.
                                      First update the Sketchucation Tool. The current version is 4.2.9 (looks like you've missed a few updates) and make sure LibFredo6 is also up to date.
                                        pibuz
                                        Hi DaveR! Thanks for your support!
                                        I updated everything and tried a clean install of the plugin but I get the error message i attach... What could it be?
                                        • fredo6F Offline
                                          NEW RELEASE: FredoGhost v2.0a - 25 Dec 22
                                          Requirements:
                                          • LibFredo6 13.6
                                          • Sketchucation ExtensionStore v4.2.9
                                          FredoGhost 2.0a extends validity.
                                          Home Page of FredoGhost for information and Download.
                                          Main post of this FredoGhost thread.
                                            Armstead
                                            Before I purchase, I have one question. Can you use the styles with FredoGhost like normal SketchUp styles and save scenes with differing styles? I have been using the outdated Grayscale Plugin for years in my 2D elevations but have to save a separate file to use in Layout. If I can "white out" the textures in my model, save it as a scene, and then have my perspectives in full color in other scenes, that would be awesome.
                                            Super cool plugin! Fingers crossed! Thanks!
                                            • 2 / 3
