    [Plugin][$] FredoGhost - v2.1a - 01 Apr 24
    56 Posts 20 Posters 63.2k Views 20 Watching
    • fredo6F Offline
      NEW RELEASE: FredoGhost v1.3a - 19 Oct 19
      Requirement: LibFredo6 8.9
      FredoGhost 1.3a extends validity.
      Home Page of FredoGhost for information and Download.
      Main post of this FredoGhost thread.
      • fredo6F Offline
        NEW RELEASE: FredoGhost v1.3b - 22 Jan 20
        FredoGhost 1.3b extends validity.
        • OxerO Offline
          Oxer
          Spanish Language File
          FredoGhost_ES.lang.zip
          • fredo6F Offline
            Thank you very much.
            • fredo6F Offline
              NEW RELEASE: FredoGhost v1.4a - 21 May 20
              Requirements:
              • LibFredo6 10.4
              FredoGhost 1.4a fixes bugs and extends validity.
              • fredo6F Offline
                NEW RELEASE: FredoGhost v1.5a - 19 Aug 20
                Requirement: LibFredo6 11.0
                FredoGhost 1.5a fixes bugs and extends validity.
                  rezvan23
                  Hi Fredo.
                  Could you add a feature that is like 3ds max's "Display as Box" option, which shows the object as a box in viewport, and shows the actual geometry in render?
                  I don't mean vrayproxy, that's not editable.
                  I don't know if that's possible.
                  Thanks for your great sketchup extensions.
                  • fredo6F Offline
                    FredoGhost is not aware of the rendering. So, just before rendering, you need to swap the objects from box to their 'real' version.
                    • fredo6F Offline
                      NEW RELEASE: FredoGhost v1.6a - 20 Nov 20
                      FredoGhost 1.6a fixes bugs and extends validity.
                      • fredo6F Offline
                        NEW RELEASE: FredoGhost v1.7a - 06 Jan 21
                        FredoGhost 1.7a fixes bugs and extends validity.
                        • fredo6F Offline
                          NEW RELEASE: FredoGhost v1.8a - 27 Jan 21
                          Requirement: LibFredo6 11.6
                          FredoGhost 1.8a becomes a paid plugin.
                          There is a Free trial period of 15 days from activation, with full features. Then, you need to license the extension on Sketchucation:
                          • Perpetual License: 17 €
                          • Rush License (21 days from purchase date): 5 €
                            See this post for instructions to license an extension on Sketchucation.
                          Note: the previous version v1.7a will naturally expires on 31 Jan 21
                          • uwesketchU Offline
                            uwesketch
                            Hi Fredo
                            The plugin is very useful.
                            I want to use it for switching between high and low poly components. However there is one thing that prevents me for using it in many models.
                            If I do a section cut, then the section cut plane is huge. This is because of the hidden objects you place far away in the FREOO tag.
                            Is there a way to prevent this huge section cut plane?
                            • fredo6F Offline
                              @uwesketch said:
                              Hi Fredo
                              Would you have a model to show me the problem. I don't understand what you mean by "the hidden objects you place far away in the FREOO tag".
                                uwesketch
                                Hi Fredo
                                below an example print screen.
                                The Sketchup model is attached.
                                When unhiding the FredoGhost tag, we see, that the plane is that huge, due to the hidden FredoGhost objects.
                                Section Cut Plane without any Fredo Ghost defined:
                                Section Cut plane without Fredo Ghosts defined
                                Section Cut plane with Fredo Ghost proxy defined:
                                SectionCut With FredoGhost Proxy defined
                                FredoGhost and Section Cut skp model
                                  uwesketch
                                  Hi Fredo
                                  I used the Bounding Box Ghosts in all three modes for a nested component.
                                  I am using FredoGhost 1.8a on SketchUp 2021 Jan release.
                                  The original object contains nested components (5 levels). Only the inner most component contains geometry (3 faces). Each components contains 3 sub-components. In total there are 5 components and 120 instances. There are only 81 Faces (3^4) with each 4 edges.
                                  When generating Bounding Boxes "by grouped object" and "by sub-object", then far too many bounding boxes are created. There are many duplicates (roughly 729 = 3^6).
                                  See the attached model.
                                  The mode "by grouped object" created 59094 faces.
                                  The mode "by sub-object" created 63609 faces.
                                  Shows duplicated BB objects
                                  Ghosted with Bounding boxes - too many BB generated
                                    rv1974
                                    Fredo, I have constant troubles after it became $$. The Ghost constantly (after short period of time) complains it can't find it the license. I feed it, and in a couple of days it starts again.
                                    And now, it refuses to start and demands upgrade (though I already upgaraged and restarted SU several times). Suggestions?
                                    P.S. I have several other commercial ones from you- none of them cause issues
                                    • fredo6F Offline
                                      Did you upgrade to Skethucation ExtensionStore v4.1.0?
                                      There were problems with the previous version.
                                        rv1974
                                        it didn't help.
                                        • fredo6F Offline
                                          My fault. I left a check of validity in the code. Nothing to do with the license.
                                          Please ugrade to FredoGhost v1.9a. Should solve the issue.
                                          And thanks for signaling it.
                                            rv1974
                                            Many many thanks- it fixed the issue
                                            • 2 / 3
