    Opening plugin
    6 Posts 5 Posters 6.8k Views 5 Watching
      Billygo247
      Im new to this site.
      Once I download a plugin to my desktop - it appears to be saved as SU file.
      How do I get it into my SU 2017 windows?
      thanks,
      Billy
        Please help us by giving some more [useful] info...
        Where did you download the 'plugin' from ?
        What is it ?
        Let's assume it's one of the PluginStore's files...
        It should arrive onto your computer as an RBZ file.
        Then in v2017 you use the Window > Extension Manager dialog's 'Install Extension' red-button, find the RBZ and it's installed automatically for you.
        Extensions are a subset of Plugins... these can be enabled/disabled using the Extensions Manager...
        A few complex Extensions also need a helper Lib installing - it's explained in their usage notes.
        Although it's not always necessary, restarting SketchUp after installing an RBZ will ensure everything gets properly synced...
        Also note that not all Extensions/Plugins appear in the Extension menu, some are in Draw or Tool etc, also many have Toolbars...
        So read the usage notes so you understand how each tool works...
          djh
          I see the installed,enabled extension in Extension Manager, but I can't find it on my menu. I can't activate it.
            samodelkin_77
            what is the name of the plugin?
            • BoxB Offline
              It has been addressed elsewhere, it was Make all unique, and it is found in the context menu.
                samodelkin_77
                if name of the plugin "Deep Make unique", is available in the context menu, and only when there are more than one components in the project.
