    [Plugin] LordOfTheToolbars - v3.0a - 21 Apr 26
    503 Posts 96 Posters 423.5k Views 94 Watching
      PedroE
      More errors detected: when you alternate the sketchup full screen with another window using a shortcut (ctrl + alt + tab) vignettes bar disappears, it only appears with popup the vignette stripe command.
      The palette windows do not retain the custom size when a shortcut popup is opened with a shortcut key, they adjust automatically.
        rv1974
        Some minor inconvenience here:
        I have some locked favorite toolbar put in some properplace before closing SU. After SU restarting I see it closed and I need to click the dedicated palette icon to restore the status. Could LOTT remember the toolbars position before SU closing?
        PS Exporting config file before SU exit doesn't help.
        • fredo6F Offline
          Thanks for signaling. Bug introduced in latest version (v1.4c) and fixed in next version.
          • fredo6F Offline
            Which key combination do you use. I don't observe the problem with Alt-Tab and Ctrl-Alt-Tab
            This is normal. When you use a shortcut to make a palette appear, LOTT display the palette expanded, so that you can see all command icons. When you click a command (or click in the empty space or press escape), the palette will automatically disappear.
              PedroE
              The problem is when you have many buttons and the window can be excessively large, if you could keep a custom window size, the most used buttons would be visible and the rest would appear by sliding with the mouse wheel.
              Extend
              Fit
              • fredo6F Offline
                Then, I can make it an option.
                Again, the shortcut is to make the palette temporarily show so that you can select a command icon. So, even if there are lot of icons, this is just for temporary selection.
                • fredo6F Offline
                  NEW RELEASE: LordOfTheToolbars v1.4d - 10 Jul 21
                  Requirements
                  • LibFredo6: v11.9c or above
                  LordOfTheToolbars 1.4d fixes various bugs related to shortcuts, permanent showing of palettes at startup, ....
                  Home Page of LordOfTheToolbars for information and Download.
                  Main post of this LordOfTheToolbars thread.
                    PedroE
                    Error with custom icons, this appears when you try to put one. The accept button that is at the bottom of the window also disappears because the icon path is very long and increases the black box.
                    • fredo6F Offline
                      Which image file did you select? There seems to be a problem with this file.
                        PedroE
                        I have loaded several png and the same thing happened
                        • fredo6F Offline
                          Could you post here one of the PNG.
                          Also, what do you see in the Icon Selector dialog box (the panel normally shows the latest PNG loaded)?
                            PedroE
                            appear this way
                            • fredo6F Offline
                              There may be special characters in the path to icon files.
                                rv1974
                                Fredo, would it be possible please to substitute the toolbar's title bars (so much screen space wasted) to a tiny vertical element like this:
                                  rv1974
                                  Some bugs:
                                  () Episodically I have constant always-on-top phantom icons (of different tools used earlier). I can get rid of it by running Master Toobar Manager or simply restarting the program.
                                  https://drive.google.com/file/d/1DiAjP9D0IDQeR059icj7HmwuY9xgOuU_/view?usp=sharing
                                  ) Icons get lost when pulling toolbar edge inwards:
                                  https://drive.google.com/file/d/11QykXGIugJNmg6IAOv9IFcxI0MHtEbe7/view?usp=sharing
                                  • fredo6F Offline
                                    Did you move icons from Palettes with the Shift key pressed?
                                    I think I have seen that in rare occasion. I'll have a look and fix it.
                                    • fredo6F Offline
                                      @rv1974 said:
                                      Some bugs:
                                      (*) Icons get lost when pulling toolbar edge inwards:
                                      It seems you have a Line-break between the icons of
                                      • the LOTT Favorite Manager (with a red heart)
                                      • and the first icon of JointPushPull.
                                        Just right-click on one of the icons and select "Remove line-break before (or after).
                                        Icons are not lost. Mouse wheel will make them show.
                                        rv1974
                                        exactly! thanks a ton.
                                        • fredo6F Offline
                                          @jdgarvin,
                                          I don't have Big Sur on my Mac, and this works fine in Catalina on my laptop MacBook Pro.
                                          Could you more explicit on the drag & drop 'disabled'. Where are you dragging from and to which target.
                                          For multi-screen, could you open the Ruby console and type (or copy/paste) the following command:
                                          G6.monitor_print
                                            PedroE
                                            Problems with the reaction of the popup windows through shortcuts, it seems that the focus of the main sketchup window is lost, then by selecting the main sketchup window with the left click it reacts again normally.
                                            • 25
                                            • 26
                                            • 4 / 26
