    [Plugin] LordOfTheToolbars - v4.0a - 22 Sep 26
    527 Posts 101 Posters 587.6k Views 99 Watching
      rv1974
      Some bugs:
      () Episodically I have constant always-on-top phantom icons (of different tools used earlier). I can get rid of it by running Master Toobar Manager or simply restarting the program.
      https://drive.google.com/file/d/1DiAjP9D0IDQeR059icj7HmwuY9xgOuU_/view?usp=sharing
      ) Icons get lost when pulling toolbar edge inwards:
      https://drive.google.com/file/d/11QykXGIugJNmg6IAOv9IFcxI0MHtEbe7/view?usp=sharing
      • fredo6F
        Did you move icons from Palettes with the Shift key pressed?
        I think I have seen that in rare occasion. I'll have a look and fix it.
        • fredo6F
          @rv1974 said:
          Some bugs:
          (*) Icons get lost when pulling toolbar edge inwards:
          It seems you have a Line-break between the icons of
          • the LOTT Favorite Manager (with a red heart)
          • and the first icon of JointPushPull.
            Just right-click on one of the icons and select "Remove line-break before (or after).
            Icons are not lost. Mouse wheel will make them show.
            rv1974
            exactly! thanks a ton.
            • fredo6F
              @jdgarvin,
              I don't have Big Sur on my Mac, and this works fine in Catalina on my laptop MacBook Pro.
              Could you more explicit on the drag & drop 'disabled'. Where are you dragging from and to which target.
              For multi-screen, could you open the Ruby console and type (or copy/paste) the following command:
              G6.monitor_print
              • P
                PedroE
                Problems with the reaction of the popup windows through shortcuts, it seems that the focus of the main sketchup window is lost, then by selecting the main sketchup window with the left click it reacts again normally.
                  jdgarvin
                  Here is the output from the > G6.monitor_print command:
                  Monitor 1: [0, 0, 1650, 1025] - [0, 0, 1650, 1050]
                  Monitor 2: [0, 1050, 1600, 875] - [0, 1050, 1600, 900]
                  UI Scale factor: 1.0
                  Virtual Screen: [1650, 1950]
                  MacBook Pro 16" 2019, 2.4 GHz 8-Core Intel Core i9, 32 GB RAM, Radeon Pro 5500M 8 GB.
                  • designerbursaD
                    designerbursa
                    When I go full screen, the status text bar at the bottom disappears.
                    • fredo6F
                      This should be fixed in the latest version of LOTT.
                      To make the status text bar reappear
                      • Open the Ruby Console
                      • type (or copy/paste) the following command: Sketchup.send_action 59393 and press Enter
                      • L
                        ltchest
                        Great plugin. Only trouble i have is that it never remembers the location of the toolbar. Every time i open sketchup i have to move the toolbar to the location that i want.
                        Also, it does not seem to recognise Vray.
                        Sketchup 21.2.332 (windows 10.0.19043 Build 19043)
                        RTX2070 + GTX1080, Driver 472.12
                        • fredo6F
                          What do you mean by 'toolbar'?
                          • favorite palette?
                          • Sketchup regular toolbar?
                          For VRay, which version do you have?
                          • JustinTSEJ
                            JustinTSE
                            At some point I closed the command stripe at the top of the page and I can't seem to get it back. I've updated LibFredo, unloaded and reloaded the extension, clicked all the buttons, etc.
                            In addition, when I click the quick command finder button it's not doing anything.
                            I'm on LibFredo 11.9C. I'm sure this is something simple that I'm missing
                            Thanks so much for your work on this!
                            • fredo6F
                              Justin,
                              Normally, the only way to discard the Vignette Stripe is to use the menu LordOfTheToolbars > Toggle Visibility of the Vignette Stripe, which is also a way to restore it. Is it what you did?
                              If ever it is off-screen, use menu LordOfTheToolbars > Reset Vignette Stripe Position.
                              For the Command Finder, it could also be off-screen or there is a bug.
                              I suggest you keep the Ruby console opened to see if there are errors showing.
                                rv1974
                                Regarding this Vignette Stripe.. it causes lot of troubles - it tends to get lost (because I sporadically drag SU windows from one monitor to another and use the switch to jump to another PC with the same monitors). Recovering from preferences file and Show Vignette Stripe command don't help. Luckily LordOfTheToolbars > Reset Vignette Stripe Position works, but its not ideal solution.
                                • fredo6F
                                  When you move the Sketchup window, do you see the Vignette Stripe and the palettes moving along the Sketchup window?
                                    rv1974
                                    I'll check later, currently machines are busy with tons of renderings.
                                    • JustinTSEJ
                                      JustinTSE
                                      Perfect! This is what I needed.
                                      I was looking for the menu in the wrong place - I suspected some sort of user error 😎
                                      • JustinTSEJ
                                        JustinTSE
                                        So...sorry to bug you again. Whenever I click the quick command finder button in the vignette stripe, nothing happens on the page. In the ruby console I get the following error.
                                        Error: #<RangeError: invalid codepoint 0xD83C in UTF-8>
                                        c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:5283:in all_menus' c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:5283:in menu_mapping'
                                        c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:5359:in menu_structured_list' c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsfinddialog.rbe:215:in prepare_data'
                                        c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsfinddialog.rbe:134:in dialog_invoke' c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmanager.rbe:5266:in minifind_invoke'
                                        c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsvignettedialog.rbe:859:in minifind_invoke' c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsvignettedialog.rbe:590:in dialog_callback_exec'
                                        c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsvignettedialog.rbe:565:in dialog_callback' c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2297:in call'
                                        c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2297:in master_callback' c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2086:in j_action'
                                        c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2045:in j_callback' c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2031:in block in j_dispatch'
                                        c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2023:in each' c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2023:in j_dispatch'
                                        c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:1332:in `block in create_dialog'
                                        I'm currently running LibFredo 11.9c and LordofTheToolbars 1.4d.
                                        If I click the quick command finder in the toolbar on the screen, I get this error and it hides the vignette stripe
                                        c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/bootstrap_lordofthetoolbars.rbe:351:in launch' c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/bootstrap_lordofthetoolbars.rbe:303:in action__mapping'
                                        c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:129:in call' c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:129:in launch_action'
                                        c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:227:in launch_action' c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/bootstrap_lordofthetoolbars.rbe:249:in launch_action'
                                        c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/bootstrap_lordofthetoolbars.rbe:285:in block in declare_command' c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1382:in command_invoke'
                                        c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1363:in block (2 levels) in build_config_commands' c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1377:in block in add_command'
                                        c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/controller_lordofthetoolbars.rbe:142:in `block in new'
                                        • fredo6F
                                          @Justin,
                                          Looks like there a plugin with an exotic menu entry (Chinese or so) and this is creating an error.
                                          I'll see if I can either solve the problem or protect the code against this type of error.
                                            rv1974
                                            Well it appears that LOTT hates when SU window is dragged from one monitor to another.
                                            *) The Vignette Palette (VP) completely disappears. 'Toggle VP visibility' and reset VP position' commands sometimes help sometimes don't. Pop up VP command works consistently well. Typically restarting SU restores UI order, but its kind of so-so solution.
                                            *) If I have some lockedfavorite toolbar(s) and VP logically I'd expect them to be moved with SU window (=glued), now it's not happening.
                                            *) the location of locked toolbars is messed when SU window come back to it's original place.
                                            • 26
                                            • 27
                                            • 4 / 27
