    [Plugin] LordOfTheToolbars - v4.2a - 21 Oct 26
    558 Posts 101 Posters 689.7k Views 99 Watching
    • P
      PedroE
      appear this way
      • fredo6F
        There may be special characters in the path to icon files.
          rv1974
          Fredo, would it be possible please to substitute the toolbar's title bars (so much screen space wasted) to a tiny vertical element like this:
            rv1974
            Some bugs:
            () Episodically I have constant always-on-top phantom icons (of different tools used earlier). I can get rid of it by running Master Toobar Manager or simply restarting the program.
            https://drive.google.com/file/d/1DiAjP9D0IDQeR059icj7HmwuY9xgOuU_/view?usp=sharing
            ) Icons get lost when pulling toolbar edge inwards:
            https://drive.google.com/file/d/11QykXGIugJNmg6IAOv9IFcxI0MHtEbe7/view?usp=sharing
            • fredo6F
              Did you move icons from Palettes with the Shift key pressed?
              I think I have seen that in rare occasion. I'll have a look and fix it.
              • fredo6F
                @rv1974 said:
                Some bugs:
                (*) Icons get lost when pulling toolbar edge inwards:
                It seems you have a Line-break between the icons of
                • the LOTT Favorite Manager (with a red heart)
                • and the first icon of JointPushPull.
                  Just right-click on one of the icons and select "Remove line-break before (or after).
                  Icons are not lost. Mouse wheel will make them show.
                  rv1974
                  exactly! thanks a ton.
                  • fredo6F
                    @jdgarvin,
                    I don't have Big Sur on my Mac, and this works fine in Catalina on my laptop MacBook Pro.
                    Could you more explicit on the drag & drop 'disabled'. Where are you dragging from and to which target.
                    For multi-screen, could you open the Ruby console and type (or copy/paste) the following command:
                    G6.monitor_print
                    • P
                      PedroE
                      Problems with the reaction of the popup windows through shortcuts, it seems that the focus of the main sketchup window is lost, then by selecting the main sketchup window with the left click it reacts again normally.
                        jdgarvin
                        Here is the output from the > G6.monitor_print command:
                        Monitor 1: [0, 0, 1650, 1025] - [0, 0, 1650, 1050]
                        Monitor 2: [0, 1050, 1600, 875] - [0, 1050, 1600, 900]
                        UI Scale factor: 1.0
                        Virtual Screen: [1650, 1950]
                        MacBook Pro 16" 2019, 2.4 GHz 8-Core Intel Core i9, 32 GB RAM, Radeon Pro 5500M 8 GB.
                        • designerbursaD
                          designerbursa
                          When I go full screen, the status text bar at the bottom disappears.
                          • fredo6F
                            This should be fixed in the latest version of LOTT.
                            To make the status text bar reappear
                            • Open the Ruby Console
                            • type (or copy/paste) the following command: Sketchup.send_action 59393 and press Enter
                            • L
                              ltchest
                              Great plugin. Only trouble i have is that it never remembers the location of the toolbar. Every time i open sketchup i have to move the toolbar to the location that i want.
                              Also, it does not seem to recognise Vray.
                              Sketchup 21.2.332 (windows 10.0.19043 Build 19043)
                              RTX2070 + GTX1080, Driver 472.12
                              • fredo6F
                                What do you mean by 'toolbar'?
                                • favorite palette?
                                • Sketchup regular toolbar?
                                For VRay, which version do you have?
                                • JustinTSEJ
                                  JustinTSE
                                  At some point I closed the command stripe at the top of the page and I can't seem to get it back. I've updated LibFredo, unloaded and reloaded the extension, clicked all the buttons, etc.
                                  In addition, when I click the quick command finder button it's not doing anything.
                                  I'm on LibFredo 11.9C. I'm sure this is something simple that I'm missing
                                  Thanks so much for your work on this!
                                  • fredo6F
                                    Justin,
                                    Normally, the only way to discard the Vignette Stripe is to use the menu LordOfTheToolbars > Toggle Visibility of the Vignette Stripe, which is also a way to restore it. Is it what you did?
                                    If ever it is off-screen, use menu LordOfTheToolbars > Reset Vignette Stripe Position.
                                    For the Command Finder, it could also be off-screen or there is a bug.
                                    I suggest you keep the Ruby console opened to see if there are errors showing.
                                      rv1974
                                      Regarding this Vignette Stripe.. it causes lot of troubles - it tends to get lost (because I sporadically drag SU windows from one monitor to another and use the switch to jump to another PC with the same monitors). Recovering from preferences file and Show Vignette Stripe command don't help. Luckily LordOfTheToolbars > Reset Vignette Stripe Position works, but its not ideal solution.
                                      • fredo6F
                                        When you move the Sketchup window, do you see the Vignette Stripe and the palettes moving along the Sketchup window?
                                          rv1974
                                          I'll check later, currently machines are busy with tons of renderings.
                                          • JustinTSEJ
                                            JustinTSE
                                            Perfect! This is what I needed.
                                            I was looking for the menu in the wrong place - I suspected some sort of user error 😎
                                            • 27
                                            • 28
                                            • 4 / 28
