    Townhouses: Updated
    25 Posts 6 Posters 4.0k Views 6 Watching
    • pbacotP Offline
      Very nice! How are you doing the plants?
      • Bryan KB Offline
        Thanks pbacot. πŸ‘
        The plants are stock from the warehouse. In this instance, they came with the model. I did no further modification. In fact, I had to take some out in order to work on the model as they made the file too big.
        The sky and background plant foliage on the right is an HDRI.
        • Bryan KB Offline
          Update.
            Very effective render, better with each render. πŸ‘
            • Bryan KB Offline
              Thanks Mike.
              Practice, practice, practice. I've put more RAM in my PC and it has helped. Still takes 30+ minute to get a good render and some still take hours. But it's no longer hours and days. πŸ‘
              • tuna1957T Offline
                tuna1957
                πŸ‘
                • Bryan KB Offline
                  Thanks tuna. πŸ‘
                    Hi Bryan, nice but the trees in the forground are pretty ordinary, I would control this with Depth of field πŸ˜‰
                    • Bryan KB Offline
                      Yeah, I was thinking the sort of the same thing that the foreground trees were not working.
                      I'll play around with that.
                      • Bryan KB Offline
                        Final render. Somehow, the files, both skp and Raylectron, have become corrupt. I suspect it's the ridiculously long file name. I'll investigate it at some later time, For now, I'm satisfied. But probably not for long. πŸ˜†
                        Changed many thing. For one, the car was floating! πŸ˜† How I did I miss that?! I changed the lighting. I was using both sun and HDRI dome. I just used the HDRI this time.
                        I took L I am's advice and got rid of the foreground trees. Changed the road textures. Increased the bump on many textures. Increased the saturation. Changed the camera angle. Fixed the retaining wall in front of each house. I did not even know there was a wall there! I thought it was grass! Fiddled and fiddle some more with the lighting.
                        I started changing the geometry and found out it was a mess, so left it original.
                        So this is it. For now. πŸ˜‰
                          Hi Bryan, wher55e did you get the skydome?
                          • Bryan KB Offline
                            Web Server's Default Page
                            (www.nordicfx.net)
                            • 2 / 2
