    How to assign a shortcut for the "reverse face" tool?
    8 Posts 6 Posters 6.6k Views 6 Watching
    • N Offline
      numerobis
      hi,
      i had assigned a shortcut for the "reverse face" command in the right click menu. i reinstalled sketchup and now i can't find the command in the shortcut anymore... πŸ˜’
      where can i define a shortcut for this tool?
      thanks!
      • jeff hammondJ Offline
        Select a face prior to going into the shortcut settings then it will show up in the list.
        • N Offline
          numerobis
          yes! it works!!! now i remember how i did it last time... πŸ’š
          Thank You for your quick reply! πŸ˜„
            You may also be interested in this plugin:
            http://forums.sketchucation.com/viewtopic.php?t=13380
            When activated, just "sweep through" the model and it will reverse all back faces it touches (even inside groups/components).
            • N Offline
              numerobis
              thanks for the hint Gaieus! πŸ˜„ i will test it.
              Looks very useful... I don't know how i could miss this one πŸ˜’ πŸ˜„
                JonathanD
                This worked!
                • Bryan KB Offline
                  I did not know this! Excellent tip!
                    slbaumgartner
                    This is true for all SketchUp tools that are context-sensitive: they won't show up in the shortcuts editor unless the appropriate context is activated, e.g. by selecting an edge, face, group, or component.
