    1.3k Posts 299 Posters 2.9m Views 297 Watching
      rv1974
      Again, I suggested kind of more intelligent smoothing (similar to follow me or profile builder) IN plugin itself
      Edit: extra pic added to illustrate the problem
      • jgbJ Offline
        jgb
        The top back edge is also smoothed. If you unsmooth just that line and the one below (in the back) then the top will not be over smoothed.
        The only other way you can get less smoothed top surface is to create a small smoothed radius on the top & bottom back edges. The size of the radius will control how much smoothing you do want.
        jgb
          GrahamHowells
          Have used your plugins for years. Now I can't load them.
          Installation of Fredo6_Curiloft; Freddo6_FredoTools; Freddo6_Joint PushPull;
          Subfolder missing.
          Tried to install roundcorners from extension manager but it failed.
          Tried to install LibFredo6 11.8a. received error message:
          “undefined method ‘loadRBS’ for SCF:Module
          Any advice on what I should do.
            You might try updating the Sketchucation Extension Store installation. https://sketchucation.com/pluginstore?pln=SketchUcationTools
              GrahamHowells
              Tried that, then tried to load Roundcorners and got this result:
              UnZip Error: Could not unzip archive.
              What next???
                When you say you tried 'to load' RoundCorners, how did you do that ?
                There are two main ways...
                1. download its RBZ file and use the SketchUp Extension Manager dialog to Install it...
                2. auto-install it using the SketchUcation ExtensionStore³ dialog - find its entry and click to install.
                Also remember that Fredo's tools need his LibFredo installing...
                Also remember to restart SketchUp after the installations to ensure everything is synced...
                After it's all successfully installed there should be tool-menu entries and toolbars etc...
                PS: If you have recently updated your SketchUp installation it must be installed by selecting the downloaded installer's exe file, right-click, context-menu > "Run as administrator", with an existing installation choose 'Repair' when prompted...
                Installing Windows apps in any other way, e.g. by double-clicking the exe to 'run' it, can lead to all sorts un unpredictable issues, usually affecting folder permissions etc...
                Your normal user-account might have admin-powers but it it is not the same as doing it properly.
                It does no harm to do the 'Repair'...
                  GrahamHowells
                  Thanks for your help, however i have tried all that.
                  When I start Sketchup the first notice on screen is
                  "Installation of Fredo6_Curviloft is probably incorrect. Subfolder is missing."
                  I press OK and then get the same message for FredoTools; JointPushPull and
                  "Script ToolsOnSurface is loaded but menus will show up only at next startup of Sketchup."
                  So I start the program again and exactly the same messages occur.
                  Tried the autp-install again and got the same message again = "UnZip Error: Could not unzip archive."
                  I'm running 2020 version of Sketchup.
                  Cheers
                  Graham
                    The UnZIP error message suggests that the destination folder is not fully writable and SketchUp cannot unzip the RBZ archive into it ?
                    This can be a typical permissions error when an installation was not done using "Run as administrator"
                    You have not stated categorically that you have done the installation properly, or repaired it later...
                    Assuming you have repaired things but it's still not working then can you close SketchUp, and then find your Plugins folder which is in the folder
                    C:\Users\YOURUSERNAME\AppData\Roaming\SketchUp\SketchUp 2020\SketchUp\
                    It's hidden by default, but using its path in Windows Explorer should get you there...
                    Select the Plugins folder icon, right-click > context-menu > Properties > Security
                    There will be several Group/user names listed - e.g. SYSTEM, maybe-Unknown [SketchUp?], Your user-name and Administrators etc...
                    Use the Edit... button on each entry in turn.
                    The entry's Permissions must be ticked to 'Full Control' > under the Allow column
                    After fixing all of these OK to save the changes, the changes should ripple down to affect any subfolders/files etc...
                    Restart SketchUp and try reinstalling LibFredo RBZ and any desired RBZ extensions.
                    Restart SketchUp to sync everything...
                    Report back...
                      GrahamHowells
                      Thanks very much for helping me out Tig,
                      Unfortunately I followed all your instruction, turned everything off and restarted, Still have the same issue.
                      Sorry.
                      Graham
                        rv1974
                        I had the same Script "XXXX* is loaded but menus will show up only at next startup of Sketchup" nightmare (with all Fredo's plugins I have. Its not related to Admin rights (at least in my case). IIRC installing the latest FredoGhost helped.
                          In rare cases there have been reports like this that relate back to a corrupt windows-user-account...
                          To check this you could try making anew user-account on your computer.
                          Then install SketchUp for that [run-as-administrator etc].
                          Then install LibFredo and one of his extensions for that version of SketchUp.
                          Restart SketchUp and see if the issue is resolved...
                          If so we then need to look at ways of fixing your original windows-user-account, if possible...
                          If it's not working then the mystery deepens...
                          PS: You could also consider running a file-system check on Windows to see if it fixes anything...
                          https://support.microsoft.com/en-us/windows/using-system-file-checker-in-windows-10-365e0031-36b1-6031-f804-8fd86e0ef4ca
                          https://support.microsoft.com/en-us/topic/use-the-system-file-checker-tool-to-repair-missing-or-corrupted-system-files-79aa86cb-ca52-166a-92a3-966e85d4094e
                          etc...
                            CodeDaemon
                            Loft by spline doesn't work.
                            Sketchup 2021 Pro 21.1.332 64-bit
                            LibFredo6 12.2a - 01 Nov 21
                            Curviloft 1.8a - 31 Oct 18
                            https://trueimages.ru/thumb/2e/23/8f475e16.png
                            So it always stuck on 80% or 94% step... And nothing happens.
                            At same time "Skinning" way is works.
                              "Loft by spline doesn't work."
                              It actually does work with the correct set up. This was done in SketchUp 2021.
                              Click on the picture
                              Share the .skp file so we can see what you are working with.
                              • AibonewtA Offline
                                Aibonewt
                                I've been bashing away at this for hours now, and simply can't find a solution anywhere or work this out for myself. I'm so frustrated with this I've even considered switching to Blender, but wouldn't know where to start with a shape as wonky as this.
                                Smaller curves good, larger (newer) bad
                                The smaller (older) set of curves skin fine in Curviloft, but the others report an error. This is one of the side faces of a jewellery bail, something I've modelled using Curviloft many times over without issue. It strikes me that the curves that skin aren't as clean and smoothly defined as the new ones, but other than that I have no clue.
                                Any ideas?
                                Thanks in advance,
                                Thomas
                                  Since the arc at the left end is flat, you could put in an edge to fill that face.
                                  Then run Curviloft for the rest of it.
                                  Your smaller one has some stray edges sticking out and there are some strays off at a long distance from the rest of the model. One of them is over 100 meters from the origin. Might want to delete those things.
                                  • AibonewtA Offline
                                    Aibonewt
                                    [attachment=0:1af6ujpi]<!-- ia0 -->Screenshot - 2_4_2022 , 1_21_59 PM.png<!-- ia0 -->[/attachment:1af6ujpi]
                                    Dave, that is incredible, thank you! 😍
                                    Yeah, that took like under a minute to fix.
                                    I owe you one, seriously 😎
                                    Thomas
                                      Happy to know it got you sorted out.
                                      Because I'm nosy, what are you modeling?
                                      • AibonewtA Offline
                                        Aibonewt
                                        Hi Dave,
                                        I'm making resin pendants from 3D printed moulds, and the lofts are part of the bails that contain the cord. I've done hexagonal and circular previously, now I need to create one to fit the square (rotated 45°).
                                        Hexagonal
                                        Circular
                                        Square (Prototype)
                                        Thanks for you interest,
                                        Thomas (T/A @lightandmagik)
                                          Mattc25
                                          Hoping for some help with a project. I'm trying to make a scale aircraft nosecone. To try to match the contours precisely I've divided the nosecone into two front/back sections with four quadrants each. Overall view with quadrants skinned.  Crack is on the top left-right junction. I can easily skin each quadrant and this worked pretty well for the forward section. The problem is at some of the skin junctions between quadrants on the back section. With default skinning parameters I get a sharp corner transition between quadrants. Sharp corner at top-bottom junction When I "Swap rails and Profiles" the sharp transition goes away.Rail swap removes sharp corner but... However, I now get a weird "buttcrack effect" between the left and right quadrants. ![The "crack". Hard to capture but very noticeable when panning along the junction line.](/uploads/imported_attachments/1jFS_Crack.png "The "crack". Hard to capture but very noticeable when panning along the junction line.") It's faint and does not exist across the entire length of the junction but it is there and noticeable in the model. I've made sure that the cross section contours are flat horizontal or vertical across the junctions but I still get these effects. I'm using vertex-to-vertex matching but I've tried the other options as well with minimal effect on result. Any idea on what's causing the "crack" and how to resolve it?
                                          The model, skins mostly removed to fit under the 5Mb limit.
                                          • fredo6F Offline
                                            NEW RELEASE: Curviloft v1.9a - 13 Feb 22
                                            Curviloft 1.9a is a maintenance release for compatibility with 3D mouse devices.
                                            See Plugin Page of Curviloft for Download (or use the Sketchup PluginStore plugin for auto-installation.
                                            Main post of this thread
                                            • 60
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 65
                                            • 66
                                            • 62 / 66
