[Plugin] Universal Importer - v1.2.4 - 28 April 2024
Hi, Samuel! I'm very exciting to start using this plugin. I keep getting this error message though. Already tryied installing the Microsoft Visual C++ library but it still doesnt work. How can i fix it?
Hi Luiz. Your problem is maybe related to glTF... Can you please share with us .gltf file and textures you are trying to import?
I have a problem while importing step in sketchup 2020
[img]file:///C:/Users/Administrator/Downloads/fail%20report.jpg[/img]
Compatibility with STEP models isn't very good. Unfortunately, I don't have a solution for the moment.
Hello Samuel,
I installed your latest release on sketchupmake2017 and can not use it as it is unsigned, please update your extension with a signed version.
Cheers Mate!
@mikeg73 said:
I installed your latest release on sketchupmake2017 and can not use it as it is unsigned...
Unsigned does not make it unusable unless you set the loading policy to prevent it.
Please update your profile. It says you are using Sketchup 8.
Thank you for your reply, however, I do I know or turn off this loading policy? So I won't have any issues?? And I have updated my profile, thank you!
Cheers Mate!
I presume you mean, "I do not know how to turn off this loading policy." Is that correct. Go to Window>Extension Manager and click on the gear icon in the upper right corner. Choose Unrestricted for the loading policy. Restart SketchUp.
Hello Samuel/folks,
It appears that I am having the same issue with converting models, I looked at previous posts but still can't make sense of it all; as the file I downloaded from the warehouse was a 2017skp I tried to reduce the size but kept getting the same error messages as above.
I then exported the original skp file to 3ds and tried it again and got the same error message, as it looks like UI is still looking at this file as an obj and not a 3ds import. Is there a video/fix to this ongoing issue or am I just missing something!?
Cheers!
Hello Mike,
Don't mind about OBJ It's used as intermediate format during process...
Could you please provide us the link to the tank you're trying to simplify?
Did you try with other models?
Hello Samuel,
Here is the link to the Panther, and no I haven't tried your extension on any other model as of yet as I was immersed in this model at the time of my postings; but I will try it again soon.
Cheers Mate!
Hello Samuel,
Were we able to find out anything on this model? or do I need to download something similar and try that route?
Cheers Mate!
Hello Mike,
On my Windows 10 computer with SketchUp 2017, process hangs at 50% when plugin imports simplified "Panther" model. So yes, I suggest you to try with other models.
Samuel - I have had a great deal of difficulty importing obj files into Sketchup. Here are two examples of error messages. Can you help? I tried to upload the obj files but I couldn't. Thanks.
@BklynBoy, could you please upload these OBJ files somewhere? This way I could also try on my PC.
Hello Samuel.
I'm sorry but I am having another issue with your importer and need your advice, I recently bought some models from Turbosquid and downloaded/saved them as obj files which thankfully I can convert them over with your wonderful extension; however when I try to convert the models your extension seems to only use some textures and not all of them.
So should/can I upload the mtl files when I am converting these models?
Cheers Mate
Hello Mike, Could you please send me a (temp) link to these OBJ and MTL files in a private message?
Hello Samuel,
First, thanks for the plugin, the idea is very cool.
The only problem I encountered is that when I try to reduce the polygon count, instead they will increase (together with the size of the 3D model) and it's the opposite result of what I'm trying to achieve. What do you suggest?
Face count before reduction: 261609
Face count after reduction: 4544015My target was 80000
Samuel, thanks for creating and sharing this plugin.
Question: is it possible to to implement the original scale, units and origin respect (in fbx at least)? -
@autumnwind said:
Hello Samuel,
Hello Autumn Wind,
Try to start with a greater target (eg. 200000) then decrease...
