    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    452 Posts 111 Posters 596.5k Views 112 Watching
    • samuel_tS Offline
      samuel_t
      @nc3d said:
      Samuel
      Seems like a great plug-in, thanks for sharing this!
      We have an fbx we are trying to bring in but we are not sure how to get it to be placed exactly where we want it and at the right scale. I think we could find the right scale factor to get it right but unfortunately I can not type in an accurate enough number (only integers allowed) into the dialogue box.
      Is there a better way or different way we could have our model drop in more accurately?
      Kind Regards,
      Greg Hamilton
      Hello, There's no solution for the moment. Maybe I'll publish a more accurate plugin version in the future. Best regards.
      • N Offline
        Noire0891
        Sketchup 2016 will be implemented?
        • samuel_tS Offline
          samuel_t
          I don't think so.
          • X Offline
            xinhengxie
            Your software is very useful!! Thanks a million!! BTW, I don't know if you have thought of adding an function that it can import OSGB file format, it would be cool!!
            Merry Christmas!!!!!!
            • samuel_tS Offline
              samuel_t
              1.1.6 version improves scaling accuracy during import and fixes file permissions issue on MacOS.
              Download latest Universal Importer plugin from SketchUcation PluginStore.
              Happy new year!
                azgcz
                @samuel_t said:
                @rspierenburg said:
                I'm trying to import an OBJ. I want to keep the existing model scale but the plugin keeps asking for the height of the model. Is there a way to ignore that?
                Hello. You can't ignore that.
                I would like to add this feature"cancel /height of the model/ will keep the existing model scale"although I can do it the other way around:
                SU toolbar--Windows--Administration panel--Component--Homepage--Select import component you want-Deploy this component which keep the existing model scale:)
                Add the feature will be more convenient for me, thanks!
                  dolfek
                  Hello,
                  please, where is a problem? I have sketchup 2021.
                  Thank you for your answer.
                  • samuel_tS Offline
                    samuel_t
                    @dolfek said:
                    Hello,
                    Hello.
                    It seems you are trying to import an .obj file that references a non-existent .mtl file. Can you please share with us these .obj and .mtl files?
                      luiz_m11r
                      Hi, Samuel! I'm very exciting to start using this plugin. I keep getting this error message though. Already tryied installing the Microsoft Visual C++ library but it still doesnt work. How can i fix it?
                      • samuel_tS Offline
                        samuel_t
                        Hi Luiz. Your problem is maybe related to glTF... Can you please share with us .gltf file and textures you are trying to import?
                          catchen5890
                          I have a problem while importing step in sketchup 2020
                          [img]file:///C:/Users/Administrator/Downloads/fail%20report.jpg[/img]
                          • samuel_tS Offline
                            samuel_t
                            Compatibility with STEP models isn't very good. Unfortunately, I don't have a solution for the moment.
                            • MikeG73M Offline
                              MikeG73
                              Hello Samuel,
                              I installed your latest release on sketchupmake2017 and can not use it as it is unsigned, please update your extension with a signed version. ๐Ÿ˜Ž
                              Cheers Mate!
                                @mikeg73 said:
                                I installed your latest release on sketchupmake2017 and can not use it as it is unsigned...
                                Unsigned does not make it unusable unless you set the loading policy to prevent it.
                                Please update your profile. It says you are using Sketchup 8.
                                • MikeG73M Offline
                                  MikeG73
                                  Thank you for your reply, however, I do I know or turn off this loading policy? So I won't have any issues?? And I have updated my profile, thank you!
                                  Cheers Mate! ๐Ÿ˜Ž
                                    I presume you mean, "I do not know how to turn off this loading policy." Is that correct. Go to Window>Extension Manager and click on the gear icon in the upper right corner. Choose Unrestricted for the loading policy. Restart SketchUp.
                                    • MikeG73M Offline
                                      MikeG73
                                      Hello Samuel/folks,
                                      It appears that I am having the same issue with converting models, I looked at previous posts but still can't make sense of it all; as the file I downloaded from the warehouse was a 2017skp I tried to reduce the size but kept getting the same error messages as above.
                                      I then exported the original skp file to 3ds and tried it again and got the same error message, as it looks like UI is still looking at this file as an obj and not a 3ds import. Is there a video/fix to this ongoing issue or am I just missing something!? ๐Ÿ˜ฎ ๐Ÿ˜•
                                      Cheers! ๐Ÿ˜Ž
                                      • samuel_tS Offline
                                        samuel_t
                                        Hello Mike,
                                        Don't mind about OBJ ๐Ÿ˜‰ It's used as intermediate format during process...
                                        Could you please provide us the link to the tank you're trying to simplify?
                                        Did you try with other models?
                                        • MikeG73M Offline
                                          MikeG73
                                          Hello Samuel,
                                          Here is the link to the Panther, and no I haven't tried your extension on any other model as of yet as I was immersed in this model at the time of my postings; but I will try it again soon.
                                          Cheers Mate! ๐Ÿ˜Ž
                                          3D Warehouse
                                          (3dwarehouse.sketchup.com)
                                          • MikeG73M Offline
                                            MikeG73
                                            Hello Samuel,
                                            Were we able to find out anything on this model? or do I need to download something similar and try that route?
                                            Cheers Mate!
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 22
                                            • 23
                                            • 13 / 23
