    Medeek Wall Plugin
    1.5k Posts 27 Posters 1.1m Views 26 Watching
    • medeekM Offline
      medeek
      First look at "Pentagon" windows:
      https://aws1.discourse-cdn.com/sketchup/original/3X/6/b/6bd497e09085ab60b6274b9a2244ed99c2c79751.jpeg
      Note that if one sets the window height to zero you can also achieve an isosceles or equilateral triangle window (the degenerate cases).
      Since I'm fresh on windows right now I thought that it might be the opportune time to add in the pentagon picture window as well, one less monkey on my back. The only other significant window missing is probably the quarter circle.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Pentagon window with "Perimeter" style grill:
        https://aws1.discourse-cdn.com/sketchup/optimized/3X/f/3/f30fd874b1d23d5d273da5ff5336c9350284d5fd_2_690x396.jpeg
        design.medeek.com
        • medeekM Offline
          medeek
          First look at exterior trim with a Pentagon window:
          https://aws1.discourse-cdn.com/sketchup/original/3X/1/5/15e5f9516ad9cf074bb0dab085c8aeb18bdd9c92.jpeg
          design.medeek.com
          • medeekM Offline
            medeek
            First look at pentagon windows with the various casing options:
            https://aws1.discourse-cdn.com/sketchup/original/3X/8/f/8faa924f666154f3665db8c66c1fb89e6b7d80d2.jpeg
            design.medeek.com
            • medeekM Offline
              medeek
              First look at a gable wall with a combination of rectangular, trapezoid and pentagon windows:
              https://aws1.discourse-cdn.com/sketchup/original/3X/0/6/064fbbb315cc67374ecc6a740531ad816275d7b6.jpeg
              https://aws1.discourse-cdn.com/sketchup/original/3X/b/5/b53f59e34970f34239af920efdaa59ee32338f34.jpeg
              https://aws1.discourse-cdn.com/sketchup/original/3X/3/8/388ffbf9a5ed4c6fa179455742efe0e64b9c92cb.jpeg
              https://aws1.discourse-cdn.com/sketchup/original/3X/f/5/f5a8c75e6931185053c43957e02c85b82fe35c05.jpeg
              This type of gable wall would probably be used with a scissor truss set where the bottom pitch of the truss set aligns with the pitch/slope of the windows.
              View model here:
              3D Warehouse
              (3dwarehouse.sketchup.com)
              design.medeek.com
              • medeekM Offline
                medeek
                Version 2.0.8 - 05.05.2021
                • Added pentagon windows to the window draw and edit menus for all wall types: rectangular, gable, shed and hip.
                • Added isoceles/equilateral triangle windows to the window draw and edit menus for all wall types: rectangular, gable, shed and hip.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 2.0.8b - 05.06.2021
                  • Fixed a bug with exterior trim and wainscoting for trapezoid and pentagon windows.
                  http://design.medeek.com/resources/wallplugin/images/wall_su537_800.jpg
                  ***** CRITICAL BUG FIX *****
                  If you are using either trapezoid or pentagon windows with exterior trim or wainscoting this is a critical bug fix. It is highly recommended to upgrade to this latest release to address this issue.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Tutorial 20 - Trapezoid and Pentagon Windows (16:59 min.)
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 2.0.8c - 05.06.2021
                      • Minor update to the window draw and edit menus.
                      • Customized the wireframe preview for the Trapezoid and Pentagon window geometry.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        When a wall tees into another wall the “hide wall lines” algorithm does not remove those lines.
                        I’m fixing that algorithm so that all the top plate lines/edges are hidden and you end up with a result like this:
                        https://aws1.discourse-cdn.com/sketchup/original/3X/7/6/76630ea29bdbc73439f9242c6a06d1ca8d634630.jpeg
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 2.0.9 - 05.07.2021
                          • Improved the "hide wall lines" feature for all wall types: rectangular, gable, shed and hip.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 2.1.0 - 05.08.2021
                            • Added a 2D symbol for pocket doors to the top of the wall for the following wall types: rectangular, gable and shed.
                            • Introduced additional logic into the Custom Material Library to prevent users from using double or single quotes in custom material names.
                            http://design.medeek.com/resources/wallplugin/images/wall_su539_800.jpg
                            http://design.medeek.com/resources/wallplugin/images/wall_su540_800.jpg
                            design.medeek.com
                            • pbacotP Offline
                              You add a plate below some headers. When is that required?
                              • medeekM Offline
                                medeek
                                The plates below and on top of the header are not required however I have the request for both options so in order to make the plugin as flexible as possible I provide for all options.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 2.1.1 - 05.09.2021
                                  • Added an option for subtractive geometry into the Walls tab of the Global Settings.
                                  • Sub-groups within wall panels can be made persistent and "subtractive" by naming these groups to (subtract1, subtract2, subtract3, etc...)
                                  http://design.medeek.com/resources/wallplugin/images/wall_su542_800.jpg
                                  http://design.medeek.com/resources/wallplugin/images/wall_su541_800.jpg
                                  This is quite a major breakthrough for the wall plugin. I've been trying to think of a way to enable (manual) customization of the wall geometry for quite some time, specifically subtractive modifications. This system will now allow the user to achieve that goal.
                                  Naming a group within the wall assembly to include the key word "CUSTOM" (case insensitive) will allow it to persist upon rebuild.
                                  Naming a group within the wall assembly to include the key word "SUBTRACT" (case insensitive) will allow it to persist and boolean subtract from other groups within the assembly upon rebuild.
                                  The subtractive group needs to be a valid solid for it to function correctly and its entity name needs to contain the key word "subtract" or "SUBTRACT".
                                  What I like to do is create a special tag/layer for the subtraction geometry and then once I am done modifying or creating it I turn off the visibility of the layer/tag and only the holes or results in the wall geometry is shown.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 2.1.1b - 05.09.2021
                                    • Components within wall panels can also be made persistent and "subtractive" by naming the component instance to (subtract1, subtract2, subtract3, etc...)
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 2.1.2 - 05.10.2021
                                      • Added logic into the add and draw menus to prevent users from using single and double quotes in preset names.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 2.1.3 - 05.20.2021
                                        • Fixed a bug with pocket doors when using the "No Frame" or "CMU" wall framing mode.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 2.1.4 - 05.29.2021
                                          • Added an option for vertically offsetting text and symbols within the General tab of the Global Settings.
                                          • Annotation text and symbols for doors, windows, garage doors, columns, Simpson Strong walls, and shear walls can be vertically offset a custom amount from the bottom of the wall.
                                          http://design.medeek.com/resources/wallplugin/images/wall_su543_800.jpg
                                          http://design.medeek.com/resources/wallplugin/images/wall_su544_800.jpg
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 2.1.5 - 06.06.2021
                                            • Updated the Medeek Estimator to include lumber/member lengths in both feet-inches (fractional) and decimal inches when using imperial units.
                                            • Further optimized and organized the Medeek Estimator code base in preparation for expansion of its functionality.
                                            http://design.medeek.com/resources/wallplugin/images/wall_su545_800.jpg
                                            design.medeek.com
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 75
                                            • 76
                                            • 31 / 76
