    Medeek Wall Plugin
    1.6k Posts 29 Posters 1.9m Views 28 Watching
    • medeekM Offline
      medeek
      Version 2.0.6c - 04.30.2021
      • Fixed a critical bug with the shutter module.
      ******* CRITICAL FIX *******
      If you downloaded and installed Version 2.0.6b then you will want to immediately uninstall and download Version 2.0.6c. The previous version introduced a minor bug to the shutter module which will causes errors with any windows that have shutters. Installation of Version 2.0.6c is highly recommended.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        I am very excited with the solid progress made on the Wall plugin these last few weeks and months, especially with the recent addition of both trapezoid and triangular windows. In light of the recent progress and in hopes of allowing more users access to the features of the plugins I will be immediately offering 40% off of the mdkBIM bundle price using the coupon codeMOTHERSDAY21. (May 1, 2021 thru May 10, 2021).
        This will reduce the bundle price from $170.00 USD to $102.00 USD. This promo code does not apply to any of the extensions purchased separately or to the electrical plugin. The offer ends on May 10th and no rain checks will issued thereafter.
        http://design.medeek.com/ads/MOTHERSDAY21_BANNER_800.jpg
        design.medeek.com
        • medeekM Offline
          medeek
          Version 2.0.7 - 05.01.2021
          • Fixed a bug with the tee intersection gypsum cutout algorithm for shed walls.
          http://design.medeek.com/resources/wallplugin/images/wall_su527_800.jpg
          A similar fix will probably be required for gable and hips walls but I haven't dug into that section of the code just yet.
          design.medeek.com
          • medeekM Offline
            medeek
            Version 2.0.7b - 05.01.2021
            • Fixed a bug with the tee intersection gypsum cutout algorithm for gable and hip walls.
            design.medeek.com
            • medeekM Offline
              medeek
              Here is an interesting framing situation. You have two internal walls that tee into a wall which has a pocket door that bisects the tee:
              https://aws1.discourse-cdn.com/sketchup/original/3X/d/c/dc68eb13e7f0091900a65f5d36253a119f51a479.jpeg
              Overall no major problems the three walls can be configured correctly with "tee" intersections and the offset can be set to 1.75" for the two tee walls so that they meet properly at the top plate.
              The only issue is the that the gypsum backer studs are drawn full length and should be truncated at the header (hence the clash). The offending gypsum backer is colored red in the screenshot.
              The manual work around is to use the Trim Tool (Medeek Truss) and quickly trim the gypsum backers. I will have to examine this situation further and see if some additional logic can remedy this clash. This is not a huge deal breaker/ hot item in my opinion but it is a special framing case that needs a second look.
              The other obvious (simple) solution is to turn off the tee intersection backers in the global settings but this is really not a good option since it will disable the gypsum backers for all the walls in the model, not just this one.
              View model here:
              3D Warehouse
              (3dwarehouse.sketchup.com)
              design.medeek.com
              • medeekM Offline
                medeek
                First look at "Pentagon" windows:
                https://aws1.discourse-cdn.com/sketchup/original/3X/6/b/6bd497e09085ab60b6274b9a2244ed99c2c79751.jpeg
                Note that if one sets the window height to zero you can also achieve an isosceles or equilateral triangle window (the degenerate cases).
                Since I'm fresh on windows right now I thought that it might be the opportune time to add in the pentagon picture window as well, one less monkey on my back. The only other significant window missing is probably the quarter circle.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Pentagon window with "Perimeter" style grill:
                  https://aws1.discourse-cdn.com/sketchup/optimized/3X/f/3/f30fd874b1d23d5d273da5ff5336c9350284d5fd_2_690x396.jpeg
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    First look at exterior trim with a Pentagon window:
                    https://aws1.discourse-cdn.com/sketchup/original/3X/1/5/15e5f9516ad9cf074bb0dab085c8aeb18bdd9c92.jpeg
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      First look at pentagon windows with the various casing options:
                      https://aws1.discourse-cdn.com/sketchup/original/3X/8/f/8faa924f666154f3665db8c66c1fb89e6b7d80d2.jpeg
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        First look at a gable wall with a combination of rectangular, trapezoid and pentagon windows:
                        https://aws1.discourse-cdn.com/sketchup/original/3X/0/6/064fbbb315cc67374ecc6a740531ad816275d7b6.jpeg
                        https://aws1.discourse-cdn.com/sketchup/original/3X/b/5/b53f59e34970f34239af920efdaa59ee32338f34.jpeg
                        https://aws1.discourse-cdn.com/sketchup/original/3X/3/8/388ffbf9a5ed4c6fa179455742efe0e64b9c92cb.jpeg
                        https://aws1.discourse-cdn.com/sketchup/original/3X/f/5/f5a8c75e6931185053c43957e02c85b82fe35c05.jpeg
                        This type of gable wall would probably be used with a scissor truss set where the bottom pitch of the truss set aligns with the pitch/slope of the windows.
                        View model here:
                        3D Warehouse
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 2.0.8 - 05.05.2021
                          • Added pentagon windows to the window draw and edit menus for all wall types: rectangular, gable, shed and hip.
                          • Added isoceles/equilateral triangle windows to the window draw and edit menus for all wall types: rectangular, gable, shed and hip.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 2.0.8b - 05.06.2021
                            • Fixed a bug with exterior trim and wainscoting for trapezoid and pentagon windows.
                            http://design.medeek.com/resources/wallplugin/images/wall_su537_800.jpg
                            ***** CRITICAL BUG FIX *****
                            If you are using either trapezoid or pentagon windows with exterior trim or wainscoting this is a critical bug fix. It is highly recommended to upgrade to this latest release to address this issue.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Tutorial 20 - Trapezoid and Pentagon Windows (16:59 min.)
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 2.0.8c - 05.06.2021
                                • Minor update to the window draw and edit menus.
                                • Customized the wireframe preview for the Trapezoid and Pentagon window geometry.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  When a wall tees into another wall the “hide wall lines” algorithm does not remove those lines.
                                  I’m fixing that algorithm so that all the top plate lines/edges are hidden and you end up with a result like this:
                                  https://aws1.discourse-cdn.com/sketchup/original/3X/7/6/76630ea29bdbc73439f9242c6a06d1ca8d634630.jpeg
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 2.0.9 - 05.07.2021
                                    • Improved the "hide wall lines" feature for all wall types: rectangular, gable, shed and hip.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 2.1.0 - 05.08.2021
                                      • Added a 2D symbol for pocket doors to the top of the wall for the following wall types: rectangular, gable and shed.
                                      • Introduced additional logic into the Custom Material Library to prevent users from using double or single quotes in custom material names.
                                      http://design.medeek.com/resources/wallplugin/images/wall_su539_800.jpg
                                      http://design.medeek.com/resources/wallplugin/images/wall_su540_800.jpg
                                      design.medeek.com
                                      • pbacotP Offline
                                        You add a plate below some headers. When is that required?
                                        • medeekM Offline
                                          medeek
                                          The plates below and on top of the header are not required however I have the request for both options so in order to make the plugin as flexible as possible I provide for all options.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 2.1.1 - 05.09.2021
                                            • Added an option for subtractive geometry into the Walls tab of the Global Settings.
                                            • Sub-groups within wall panels can be made persistent and "subtractive" by naming these groups to (subtract1, subtract2, subtract3, etc...)
                                            http://design.medeek.com/resources/wallplugin/images/wall_su542_800.jpg
                                            http://design.medeek.com/resources/wallplugin/images/wall_su541_800.jpg
                                            This is quite a major breakthrough for the wall plugin. I've been trying to think of a way to enable (manual) customization of the wall geometry for quite some time, specifically subtractive modifications. This system will now allow the user to achieve that goal.
                                            Naming a group within the wall assembly to include the key word "CUSTOM" (case insensitive) will allow it to persist upon rebuild.
                                            Naming a group within the wall assembly to include the key word "SUBTRACT" (case insensitive) will allow it to persist and boolean subtract from other groups within the assembly upon rebuild.
                                            The subtractive group needs to be a valid solid for it to function correctly and its entity name needs to contain the key word "subtract" or "SUBTRACT".
                                            What I like to do is create a special tag/layer for the subtraction geometry and then once I am done modifying or creating it I turn off the visibility of the layer/tag and only the holes or results in the wall geometry is shown.
                                            design.medeek.com
                                            • 52
                                            • 53
                                            • 54
                                            • 55
                                            • 56
                                            • 79
                                            • 80
                                            • 54 / 80
