    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    460 Posts 145 Posters 892.4k Views 144 Watching
      menes
      Hello,
      I need help!
      I'm puzzled and I can't get on top of this issue
      this great plugin from the time I've installed the new 2020 SU it's not working as it was effectively before...
      I attach some files maybe someone understands what's going on
      thanks, everybody will be going to help
      Alberto
      initial status of isolines
      preview
      terrain created...not correct!
      • fredo6F
        I would suggest you do not select the quadrangular base contour, just the isocontours.
        Best would be that you attach the model.
          menes
          Hello,
          thank you very much for your reply...
          "I would suggest you do not select the quadrangular base contour, just the isocontours.
          Fredo"
          I didn't included the base contour...but the problem remains
          I add here the file , thank you
          Best
          Alberto
          TOPO 3D CLEANED.skp
          • fredo6F
            Actually, it's a matter of scale. Your model is far too small (height is 30 cm).
            So scale it by a factor of 1000 and it will give give normal results.
              menes
              LOL .... 🀣
              you're right...sometimes we getting lost with the most stupid thing...
              thank you very much...sorry.
              Best regards
              Alberto
                menes
                I've just imported from Autocad from a Topographer...and I didn't scale it at all πŸ˜†
                Thank you again
                  menes
                  ah ...by the way
                  You are great Fredo ...admiration!
                    sgb1456
                    I keep getting an error while using the extension with Sketchup 2021. Ill post the text below:
                    Date: 03-Mar-21 10:06:57
                    An error occurred in CLEANSING
                    The operation is fully aborted
                    cannot hide layer that is a part of the active path
                    body_lib6tool.rbe: 2538 -- visible=
                    body_lib6tool.rbe: 2538 -- block in switch_to_temp_layer
                    body_lib6tool.rbe: 2537 -- each
                    body_lib6tool.rbe: 2537 -- switch_to_temp_layer
                    toposhapertool.rbe: 1391 -- change_view
                    toposhapertool.rbe: 1358 -- set_preview_working
                    toposhapertool.rbe: 544 -- cleansing_processing
                    toposhapertool.rbe: 523 -- after_selection
                    toposhapertool.rbe: 493 -- notify_edge_picked
                    body_lib6edgepicker.rbe: 539 -- call
                    body_lib6edgepicker.rbe: 539 -- notify_action
                    body_lib6edgepicker.rbe: 595 -- terminate_current_selection
                    toposhapertool.rbe: 658 -- execute_validate
                    toposhapertool.rbe: 387 -- handle_initial_selection
                    toposhapertool.rbe: 319 -- activate
                    toposhapertool.rbe: 133 -- select_tool
                    toposhapertool.rbe: 133 -- action__mapping
                    lib6plugin.rbe: 129 -- call
                    lib6plugin.rbe: 129 -- launch_action
                    lib6plugin.rbe: 227 -- launch_action
                    bootstrap_toposhaper.rbe: 83 -- launch_action
                    bootstrap_toposhaper.rbe: 136 -- block in startup
                    lib6plugin.rbe: 1347 -- command_invoke
                    lib6plugin.rbe: 1328 -- block (2 levels) in build_config_commands
                    lib6traductor.rbe: 1377 -- block in add_command
                    Should I just reinstall Sketchup 2020? I can't live without this extension!
                    • fredo6F
                      You do NOT need to reinstall Sketchup. Maybe relaunch it and try again.
                      Otherwise, if you could post or PM me the model, this would help.
                      • G
                        Grey24601
                        Hi Fredo,
                        Brilliant plugin.
                        What am I doing wrong here? When I select cloud I get a yellow triangle warning as if the guide points have not been selected? It worked earlier without any problems?
                        Thanks in advance.
                          Maybe you could upload the .skp file so we can see what you're working with?
                          • fredo6F
                            You need to enclose the guide points in a group and then select this group before launching TopoShaper cloud.
                            • fredo6F
                              NEW RELEASE: TopoShaper v2.6a - 24 Apr 21
                              Requirement: LibFredo6 11.6a
                              TopoShaper 2.6a is a technical release for performance of contextual selection menu.
                              Home Page of TopoShaper for information and Download.
                              Main post of this TopoShaper thread.
                              • E
                                emrecy
                                I have SU2017 and fredo lib 6 and some fredo tools. I need Topo shaper. I have downloaded extension file (TopoShaper_v2.6a - the one for the SU2017 and later versions)I have installed it from extension manager. It said menus will appear after I restart SU. But nothing happened. I have restarted whole computer several times, checked if it was installed actually. I see Toposhaper in extension manager list. I have checked AppData Roaming Plugin folder. Toposhaper is there as well. But no menu is showing up. It is as if it was never downloaded. I have tried the old version for the ones before SU2017. Surprisingly toposhaper menus have showed up. But one of two icons do not work. I could not use it. Now I am going for a trial SU2020 to make it work. But I need to solve the issue for SU2017 as its my paid licensed software. Anyone any ideas?
                                • T
                                  TeKnoel
                                  @fredo6 said:
                                  @teknoel said:
                                  Hi this is still a very valuable plugin and one of the most powerful ways of transforming CAD typographical information into 3d. It would be even more powerful if we could get it to output meshes that were compliant with the new Quad workflow that subdivision surfaces utilizes. I imagine you're familiar with the requirements. would it be a big job to update?
                                  Are you referring to the properties of the diagonal of quads?
                                  Hi Fredo
                                  Sorry I never saw your reply. Every time I have to generate topology I think about a quad workflow so I rechecked this post. your exactly right about the diagonal of the quads. If they are soft, smooth and cast no shadows then the quadface plugin will recognize them for accurate subdivision. One could ideally generate a pretty large format grid from toposhaper and then subdivide with subdivision surface for extra detail and editability. you could also export to blender for texturing really easily.
                                    jschwaiger
                                    I have also been receiving the error that sgb1456 outlined (a few minor differences in the numbers are highlighted in red). I am able to get the plugin to work successfully on very simple setups, but not anything more complex. I uninstalled and re-installed all the Fredo plugins I use, but still get the error. I can PM the file if that would help. Thank you for all your wonderful plugins!
                                    Date: 30-Jun-21 11:10:48
                                    bootstrap_toposhaper.rbe: 149 -- block in startup
                                    lib6plugin.rbe: 1360 -- command_invoke
                                    lib6plugin.rbe: 1341 -- block (2 levels) in build_config_commands
                                      jschwaiger
                                      I was able to copy my linework into a new sketchup file and get it to work - not sure what the issue was before - I have been getting similar cleansing errors for some time, but never created a log, so not sure how similar they are...
                                        @jschwaiger said:
                                        I have also been receiving the error...
                                        What version of SketchUp are you using? Please complete your profile.
                                          jschwaiger
                                          Sketchup Pro 2021 on Windows 10.
                                          • H
                                            horsewithnoname
                                            Hey guys,
                                            Is there a way to make changes to the terrain after it as been generated?
                                            Like making an undergound level.
                                            Also, is there a way to make a step and not join two lines with a slope?
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 20 / 23
