    Medeek Wall Plugin
    1.6k Posts 29 Posters 1.4m Views 28 Watching
    • medeekM Offline
      medeek
      Version 1.8.5 - 02.07.2021
      • Enabled the "Wall Copy" tool within the Medeek Wall Tools toolbar.
      http://design.medeek.com/resources/wallplugin/images/wall_su477_800.jpg
      Note I've only enabled this tool for rectangular walls. After I am fully confident that it is working well and I've addressed any bugs or issues I will set it up for all the other (gable,shed and hip) wall types.
      Please try out this new tool and provide any feedback or comments directly to nathan@medeek.com
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        I think the new Copy Wall tool will prove to be quite useful. As I am thinking about it this morning I realized that a similar tool for Doors and Windows would also be quite useful.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 1.8.5b - 02.08.2021
          • Fixed a bug with the top plate cut out algorithm when walls meet in a "cross" configuration.
          http://design.medeek.com/resources/wallplugin/images/CROSS_WALL.gif
          Each wall teeing into the primary wall has had its corner offset set to 1/2 the thickness of the primary wall.
          design.medeek.com
          • medeekM Offline
            medeek
            Version 1.8.6 - 02.11.2021
            • Added the following Simpson Strong-Tie hangers to the beam hanger library: LUS26-2Z, LUS28-2Z, LUS210-2Z.
            design.medeek.com
            • medeekM Offline
              medeek
              Version 1.8.7 - 02.15.2021
              • Added an option for the garage door track in the global settings.
              http://design.medeek.com/resources/wallplugin/images/GARAGE_TRACK.gif
              Currently you cannot set this parameter per garage door, it can only be set globally (in the Garage Door tab).
              https://aws1.discourse-cdn.com/sketchup/original/3X/d/6/d6de770ea518f789cfb4231df07ac10520668ee7.jpeg
              design.medeek.com
              • medeekM Offline
                medeek
                I've had a number of people recently ask me for the ability to apply a wood grain texture to the lumber (ie. studs, plates, blocking, etc...) This really isn't a big ask, so I am going to enable another couple parameters in the global settings (Material Tab) so that the user can apply a texture to lumber and pressure treated lumber. Here is a first look at what that will look like (compare the wood grain wall to the solid colored wall):
                https://aws1.discourse-cdn.com/sketchup/original/3X/e/8/e8a17a6986f2003f2bf497d25e9b232e8df3ec14.jpeg
                I've tried to be very subtle with the wood grain texture so that it approximates my default lumber color but as you can see it is a slightly darker shade. I'm not sure I am entirely happy with it yet but it is a start.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Comparison between the solid coloring and with the textures enabled (Lumber and PT Lumber):
                  https://aws1.discourse-cdn.com/sketchup/original/3X/6/c/6ce5fcf33db5130d8b3a8dff791296a996723d5c.jpeg
                  I am quite happy with the way the pressure treated texture came out.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 1.8.8 - 02.17.2021
                    • Enabled options for wood grain texture for lumber and pressure treated lumber in the global settings.
                    http://design.medeek.com/resources/wallplugin/images/wall_su482_800.jpg
                    http://design.medeek.com/resources/wallplugin/images/wall_su481_800.jpg
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 1.8.9 - 02.22.2021
                      • Added a "Cedar Siding" built-in material (vertical) into the material library.
                      http://design.medeek.com/resources/wallplugin/images/wall_su483_800.jpg
                      http://design.medeek.com/resources/wallplugin/images/wall_su484_800.jpg
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 1.9.0 - 02.24.2021
                        • Fixed a bug with the end stud height for Shed Walls with an "Inset Outside Corner".
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          mdkBIM Introduction (Japanese - 日本語)
                          A brief introduction of the mdkBIM bundle in Japanese.
                          mdkBIMバンドルの日本語での簡単な紹介です。
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 1.9.1 - 02.27.2021
                            • Added one additional parameter to the "User Interface" section of the General tab of the global settings. This allows the customization (color) of the text of the HTML buttons.
                            http://design.medeek.com/resources/wallplugin/images/wall_su486_800.jpg
                            This should also resolve the issue with the "white" text of the HTML buttons for MacOS.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              First look at the new Custom Beam Library. This will allow the user to create custom sized lumber, SCL or Timber beams:
                              https://aws1.discourse-cdn.com/sketchup/optimized/3X/1/0/10c6b11a1d350603d484b733907e154087f1f649_2_690x485.jpeg
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 1.9.2 - 03.01.2021
                                • Added a Custom Beam Library/Manager in the Beams tab of the Global Settings.
                                • Enabled custom sizes for Sawn Lumber, Timber and SCL(PSL,LSL,LVL) beams.
                                This may seem like a rather minor update but there actually is quite a bit of code behind any of these custom libraries (within the global settings) and their menu systems, hence the three days of programming that was required.
                                Since glulam beams use a different sizing system I did not enable custom sizes for that beam type. Additionally, all of the steel profiles are also quite a bit more complicated than a simple width x depth profile (rectangle) so they were also not included in this update. If there are specific wide flange steel beam sizes etc... that you would like to see me add, please feel free to contact me.
                                design.medeek.com
                                • jujuJ Offline
                                  juju
                                  :: OFF TOPIC ::
                                  Happy cake day Nathaniel.
                                  • medeekM Offline
                                    medeek
                                    Yup, I'm 49 today, my kids say I'm oooold. I'll probably still be working on this plugin when I'm 60 at the rate I'm going. 😄
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 1.9.2b - 03.02.2021
                                      • Fixed the framing bug with the top plates of rectangular walls so that they are not cut out when a tee intersection is created with non-rectangular walls.
                                      http://design.medeek.com/resources/wallplugin/images/wall_su488_800.jpg
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 1.9.2c - 03.02.2021
                                        • Fixed a bug with tee intersection blocking for gable, shed and hip walls.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 1.9.3 - 03.03.2021
                                          • Added the ability to set the lower and upper wall heights of a shed wall within the edit menu.
                                          http://design.medeek.com/resources/wallplugin/images/wall_su489_800.jpg
                                          Note that the relation between the upper and lower wall heights is a function of the wall length. Therefore if you adjust the wall length the menu will adjust the upper wall height while maintaining the lower wall height.
                                          Adjusting the lower wall height will cause the upper wall height to be calculated, based on the current length.
                                          Adjusting the upper wall height will cause the lower wall height to be calculated, based on the current length.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 1.9.4 - 03.05.2021
                                            • Minor adjustment to the tee intersection algorithm (tee blocking and top plate cut outs) for all wall types.
                                            This update addresses some issues with tee intersections and walls of differing heights. I think this latest update is an improvement over the previous algorithm however I am still open to further tuning and refinement if there is further call for it.
                                            As always I appreciate the constant feedback and testing being performed by the passionate and invested user base, without this valuable feedback the plugin(s) would certainly not have advanced as far as they have.
                                            design.medeek.com
                                            • 49
                                            • 50
                                            • 51
                                            • 52
                                            • 53
                                            • 77
                                            • 78
                                            • 51 / 78
