    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.2m Views 28 Watching
    • medeekM
      medeek
      I've had a number of people recently ask me for the ability to apply a wood grain texture to the lumber (ie. studs, plates, blocking, etc...) This really isn't a big ask, so I am going to enable another couple parameters in the global settings (Material Tab) so that the user can apply a texture to lumber and pressure treated lumber. Here is a first look at what that will look like (compare the wood grain wall to the solid colored wall):
      https://aws1.discourse-cdn.com/sketchup/original/3X/e/8/e8a17a6986f2003f2bf497d25e9b232e8df3ec14.jpeg
      I've tried to be very subtle with the wood grain texture so that it approximates my default lumber color but as you can see it is a slightly darker shade. I'm not sure I am entirely happy with it yet but it is a start.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Comparison between the solid coloring and with the textures enabled (Lumber and PT Lumber):
        https://aws1.discourse-cdn.com/sketchup/original/3X/6/c/6ce5fcf33db5130d8b3a8dff791296a996723d5c.jpeg
        I am quite happy with the way the pressure treated texture came out.
        design.medeek.com
        • medeekM
          medeek
          Version 1.8.8 - 02.17.2021
          • Enabled options for wood grain texture for lumber and pressure treated lumber in the global settings.
          http://design.medeek.com/resources/wallplugin/images/wall_su482_800.jpg
          http://design.medeek.com/resources/wallplugin/images/wall_su481_800.jpg
          design.medeek.com
          • medeekM
            medeek
            Version 1.8.9 - 02.22.2021
            • Added a "Cedar Siding" built-in material (vertical) into the material library.
            http://design.medeek.com/resources/wallplugin/images/wall_su483_800.jpg
            http://design.medeek.com/resources/wallplugin/images/wall_su484_800.jpg
            design.medeek.com
            • medeekM
              medeek
              Version 1.9.0 - 02.24.2021
              • Fixed a bug with the end stud height for Shed Walls with an "Inset Outside Corner".
              design.medeek.com
              • medeekM
                medeek
                mdkBIM Introduction (Japanese - 日本語)
                A brief introduction of the mdkBIM bundle in Japanese.
                mdkBIMバンドルの日本語での簡単な紹介です。
                design.medeek.com
                • medeekM
                  medeek
                  Version 1.9.1 - 02.27.2021
                  • Added one additional parameter to the "User Interface" section of the General tab of the global settings. This allows the customization (color) of the text of the HTML buttons.
                  http://design.medeek.com/resources/wallplugin/images/wall_su486_800.jpg
                  This should also resolve the issue with the "white" text of the HTML buttons for MacOS.
                  design.medeek.com
                  • medeekM
                    medeek
                    First look at the new Custom Beam Library. This will allow the user to create custom sized lumber, SCL or Timber beams:
                    https://aws1.discourse-cdn.com/sketchup/optimized/3X/1/0/10c6b11a1d350603d484b733907e154087f1f649_2_690x485.jpeg
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 1.9.2 - 03.01.2021
                      • Added a Custom Beam Library/Manager in the Beams tab of the Global Settings.
                      • Enabled custom sizes for Sawn Lumber, Timber and SCL(PSL,LSL,LVL) beams.
                      This may seem like a rather minor update but there actually is quite a bit of code behind any of these custom libraries (within the global settings) and their menu systems, hence the three days of programming that was required.
                      Since glulam beams use a different sizing system I did not enable custom sizes for that beam type. Additionally, all of the steel profiles are also quite a bit more complicated than a simple width x depth profile (rectangle) so they were also not included in this update. If there are specific wide flange steel beam sizes etc... that you would like to see me add, please feel free to contact me.
                      design.medeek.com
                      • jujuJ
                        juju
                        :: OFF TOPIC ::
                        Happy cake day Nathaniel.
                        • medeekM
                          medeek
                          Yup, I'm 49 today, my kids say I'm oooold. I'll probably still be working on this plugin when I'm 60 at the rate I'm going. 😄
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 1.9.2b - 03.02.2021
                            • Fixed the framing bug with the top plates of rectangular walls so that they are not cut out when a tee intersection is created with non-rectangular walls.
                            http://design.medeek.com/resources/wallplugin/images/wall_su488_800.jpg
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 1.9.2c - 03.02.2021
                              • Fixed a bug with tee intersection blocking for gable, shed and hip walls.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 1.9.3 - 03.03.2021
                                • Added the ability to set the lower and upper wall heights of a shed wall within the edit menu.
                                http://design.medeek.com/resources/wallplugin/images/wall_su489_800.jpg
                                Note that the relation between the upper and lower wall heights is a function of the wall length. Therefore if you adjust the wall length the menu will adjust the upper wall height while maintaining the lower wall height.
                                Adjusting the lower wall height will cause the upper wall height to be calculated, based on the current length.
                                Adjusting the upper wall height will cause the lower wall height to be calculated, based on the current length.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 1.9.4 - 03.05.2021
                                  • Minor adjustment to the tee intersection algorithm (tee blocking and top plate cut outs) for all wall types.
                                  This update addresses some issues with tee intersections and walls of differing heights. I think this latest update is an improvement over the previous algorithm however I am still open to further tuning and refinement if there is further call for it.
                                  As always I appreciate the constant feedback and testing being performed by the passionate and invested user base, without this valuable feedback the plugin(s) would certainly not have advanced as far as they have.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 1.9.5 - 03.07.2021
                                    • Added an option for "Geometry Guides" at the start and end of all wall types.
                                    • Added the "Start / End Marker" parameter to the General tab of the Global Settings.
                                    http://design.medeek.com/resources/wallplugin/images/wall_su490_800.jpg
                                    http://design.medeek.com/resources/wallplugin/images/wall_su491_800.jpg
                                    http://design.medeek.com/resources/wallplugin/images/wall_su492_800.jpg
                                    The reason for this "Geometric Guide" feature is to help people understand how wall corners connect to each other (or don't connect). You can turn this on in the global settings and it will help you understand how to connect your wall panels at the ends/corners. I've had a lot of questions on wall corners lately so I hope this will help answer some of those questions.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 1.9.6 - 03.09.2021
                                      • Added a layer for "symbols" to the miscellaneous layer/tag options (Layer tab of the Global Settings).
                                      • Fixed a minor bug in the shed wall edit menu.
                                      This update moves the symbols for windows, doors, garage doors, shearwalls, in-wall columns and holdowns to the "wall_symbol" layer/tag.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 1.9.7 - 03.12.2021
                                        • Fixed a bug involving gable, shed and hips walls that are created adjacent to rectangular walls.
                                        • Fixed a minor bug involving regeneration of dissimilar wall types at the same type.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 1.9.8 - 03.13.2021
                                          • Added an extra (Trim Top Plate) parameter to the "Start" and "End" configurations of rectangular walls.
                                          http://design.medeek.com/resources/wallplugin/images/wall_su494_800.jpg
                                          **** CAUTION ****
                                          This update adds two new parameters to the rectangular walls and will require the user to delete and recreate any rectangular wall presets. This upgrade does not affect gable wall or any other presets (ie. windows, door, garage, gable wall, shed wall, hip wall).
                                          This parameter (for the start and end of the wall) should normally be assigned to a value of "YES", this is also its default behavior. However, in certain cases (such as a corner with a shed or gable wall) it may be useful to configure its value as "NO", as shown in the image above.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            I’ve had some recent interest in a log siding/cladding similar to the shiplap cladding I enabled recently:
                                            https://aws1.discourse-cdn.com/sketchup/original/3X/8/8/8848f4df76b98d11aa7ecb6c0b5050cd0db5b92e.jpeg
                                            Thoughts?
                                            design.medeek.com
                                            • 49
                                            • 50
                                            • 51
                                            • 52
                                            • 53
                                            • 80
                                            • 81
                                            • 51 / 81
